September 9th, 2013, 01:14 PM | #1 |
Fighting Texas Aggie '05
Fork oil question
Going to slap in some springs for my weight. At some point in the future I will be putting in emulators but since I am on a budget they will have to wait.
Should I use the stock 10w or a higher 15w for a little heavier dampening. Strictly track bike, I am 200 lbs geared up. |
September 9th, 2013, 01:32 PM | #2 |
Gear crash test dummy
Join Date: May 2011 Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r Posts: A lot.
15w and probably .8 race tech springs
CVMA #531 |
September 9th, 2013, 02:01 PM | #3 |
Join Date: May 2012 Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike) Posts: 748
15W, but keep in mind, if you use Belray, get 10W. If you use Torco, get 20W. Everything else like Spectro, Maxima, Racetech, etc should be spot on with true viscosity ratings
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear |
September 10th, 2013, 05:15 AM | #4 |
I already have the springs I need so I am good there, and I use a viscosity table to select the fluid. My question was geared towards the stock damper rods with higher rate springs.
September 10th, 2013, 05:33 AM | #5 |
^^^ specifically the rebound dampening has to deal pretty much only with the spring as opposed to the compression dampening having to deal will me, my crappy riding, and the surface of the track (lol ). Does the increase in viscosity, and the resulting increase in dampening slow the fork action down too much and cause issues with feel?
September 10th, 2013, 07:45 AM | #6 | |
Kawi Girl
Join Date: Dec 2012 Motorcycle(s): '10 Ninja 250R Green SE, '13 Ninja 636 Pearl White Posts: 245
^^^ I'm curious about this as well.
Perspective: Everything looks better from the inside of a motorcycle helmet |
September 12th, 2013, 01:15 PM | #7 |
sail away
Join Date: Jul 2012 Motorcycle(s): gixxer (sold), ninjette (upgrade!) Posts: 964
Without emulators you cannot adjust compression and rebound damping independently other than by drilling the rods. So, unless you are going to do that I wouldn't worry about the differences between the two until you can get the emulators. It's seems like extra brain damage. Sure the increased viscosity will definitely have a affect on the fork, but there are a lot of other variables in play. Maybe too many to know realistically if the slow down is "too much" until you try it under your particular set of variables. I think the probability of hitting the nail on the head with the first rework of the forks is pretty low.
For what it's worth, I have used 15W before with the stock spring, stock damper rods, and no emulators and had no problems with feel. Although I did end up lowering the viscosity to 10W after I installed the emulators, drilled rods, and stiffer springs. Anyway, I think 15W is a pretty standard upgrade with these forks. Race tech recommends 15W. I am sure you can see where this is headed. Remember, when you get emulators installed, you may need to tweak the fork oil again anyway.
Unregistered found this post helpful. Track Day Preparation Checklist 1. Financial 2. Mental 3. Physical 4. Gear / Bike |
September 13th, 2013, 04:00 AM | #8 |
^^ I agree and I think I am going to put in some 15W and swap back to 10W when the emulators go in. As a track only bike there are not a whole lot of big hard sharp edged bumps on the racetrack where the orifice dampening gets really ugly on the compression side with a higher viscosity oil. The benefit long term is I have ridden my brothers race bike that had a front end setup I REALLY liked, so long term I have a target/baseline.
DIY- Replace fork seals, dust seals and fork oil | shortstuff | 2008 - 2012 Ninja 250R Tech Talk | 212 | November 6th, 2023 10:53 AM |
Fork oil question | MattP3 | 2008 - 2012 Ninja 250R Tech Talk | 7 | April 10th, 2015 10:20 PM |
Question about Fork Oil | thisisbenji | General Motorcycling Discussion | 16 | February 23rd, 2015 08:40 AM |
fork oil question | mikedabike64 | 2008 - 2012 Ninja 250R Tech Talk | 16 | August 19th, 2014 06:40 PM |
Fork Oil | nexus | 2008 - 2012 Ninja 250R Tech Talk | 2 | March 20th, 2011 08:42 PM |
