Old December 12th, 2009, 09:01 PM   #121
Delta107
Delta107's Avatar
Motorcycle(s): 2009 Ninja 250R - BLUE
bump
Delta107 is offline   Reply With Quote
Old December 12th, 2009, 10:22 PM   #122
250Rocket
250Rocket's Avatar
Motorcycle(s): '09 Ninja 250R
Kawi OEM Filter with Motul 5100 15W-50. Figure the manual says that 10W-XX is good until -10C and 20W-XX is good until 0C so I figured I don't run under freezing so the extra bit of 15W-50 will give me enough come spring but the 50 will assure optimal performance in the summer heat. Lol, it get to be 35C(95F) max here in summer time so I have 15 degrees of breathing room instead of 5.
Back on the road again Season 2010 Dam it feels good!
250Rocket is offline   Reply With Quote
Old December 12th, 2009, 10:55 PM   #123
beowuff
beowuff's Avatar
Currently running Shell Rotella 5w 40. I'm switching back to the Mobil 1, though. Seems like my bike ran a lot better on it. Shifting was a lot smoother too.
beowuff is offline   Reply With Quote
Old December 12th, 2009, 11:16 PM   #124
smcbride11
smcbride11's Avatar
Motorcycle(s): '95 BMW K75
I just changed to Rotella 15w-40, but haven't had a chance to ride on it yet - though I'm intending to move to 5w40 synthetic once it warms up again. Wix filters.
smcbride11 is offline   Reply With Quote
Old December 13th, 2009, 11:50 AM   #125
patw
patw's Avatar
Motorcycle(s): 2009 Ninja 250 SE
Castrol Syntec - oddly enough, it's the one that says it's designed for European high performance vehicles. It just happened to be on sale
K&N oil filter.
Worked well so far, I'll probably do the same next time.
2013 CRF250L
1985 GL1200 Interstate
patw is offline   Reply With Quote
Old December 13th, 2009, 01:26 PM   #126
bob706
bob706's Avatar
mobile 1 synth and fram filter.
Old December 14th, 2009, 05:57 PM   #127
gnfreak
gnfreak's Avatar
Motorcycle(s): 1980 Kawasaki Z1-G1 Classic, 2008 Kawasaki Ninja 250
synthetic shell rotella and wix filter.
Keith LaCombe
Normal, IL
gnfreak is offline   Reply With Quote
Old December 14th, 2009, 10:43 PM   #128
Rayme
Rayme's Avatar
Motorcycle(s): '04 sv650s
Expensive amsoil and a K&N Filter
There's 2 types of people in this world, those who complain and those who act.
Rayme is offline   Reply With Quote
Old December 19th, 2009, 03:19 PM   #129
ASecretNinja
ATGATT Squid Killer
ASecretNinja's Avatar
Motorcycle(s): '06 CBR600
Be careful with Fram.
I use Rotella synthetic and Purolator oil filters (ML16812 for pre-gen 250s) are great, and the prices are even better. Purolator makes a solid filter. But it doesn't really matter, most important thing is changing your oil regularly.
ASecretNinja is offline   Reply With Quote
Old December 29th, 2009, 07:27 PM   #130
Sailariel
Sailariel's Avatar
NAPA (WIX) and Rotella T Synthetic 5W40
Old January 11th, 2010, 11:28 AM   #131
JessyBee
JessyBee's Avatar
Motorcycle(s): 2009 Kawasaki Ninja 250r
That sounds scarily risky. Is it okay to do it with just a kick stand? Just make sure it doesnt get stuck in any crevices? PM the answer to my question to me please!
JBo, time to roll!
JessyBee is offline   Reply With Quote
Old January 11th, 2010, 11:36 AM   #132
you can do an oil/filter change with the bike on it's kickstand. a rear stand makes it a little bit easier, but certainly not necessary.
Old February 20th, 2010, 02:08 PM   #133
JokerSeven
Ride it like you stole it
JokerSeven's Avatar
Motorcycle(s): '09 Ninja 250R, '04 R6(sold)
When I first got my 250R I changed the oil at 50 miles.
I used Valvoline 10w-40 motorcycle oil and a WIX #24941 filter.
http://valvoline.com/products/consum...cle-atv-oil/13
Using the same brand oil and filter, I changed the oil again at 100 miles, 300 miles, 600 miles, and 1000 miles.
At 1500 miles I changed to Shell Rotella T Synthetic 5w-40 and I still used the WIX filter.
http://www.shell.com/home/Framework?...t6_detail.html
I have spent countless hours studying up on mototcycle oil. I was so skeptical about using diesel truck oil at first. After I spent some time looking in to it, the choice was very clear. Shell Rotella T all the way !!
They actually have their own Shell Rotella T motorcycle forum. Check it out.
http://www.shellusserver.com/ubbthre...Board=9&page=1
JokerSeven is offline   Reply With Quote
Old February 20th, 2010, 02:17 PM   #134
2WheelGuy
2WheelGuy's Avatar
Oil is critical on these motors. I burned up a motor on the track when I was using dinosaur oil and didn't know about the oil system problems in these motors. Since then I have used Shell Rotella T synthetic oil and religiously keep it right at the full mark. I dribble in a few ounces whenever needed. I have done many dozen track days and races since the switch and haven't lost a single motor.
I am sold on Shell Rotella t synthetic. I use whatever filter: Fram, K&N, Emgo. They all look like they come from the same factory.
AFM #278
Old February 21st, 2010, 11:37 AM   #135
Samer
Samer's Avatar
Motorcycle(s): 09 Ninja 250R SE
Rotella Synthetic and Fram. I'm at ~1200 miles and I've never noticed the oil level drop. Knock on wood
Samer is offline   Reply With Quote
Old March 2nd, 2010, 12:49 PM   #136
Timm3h
Lightbulb What kind of Oil does everyone use?
I need to do an oil change in a few days and I was wondering what everyone runs.
Also what kind of oil filter do you use and do you change it every time?
P.S. I tried doing a search for similar threads but 'oil' is too short.
Timm3h is offline   Reply With Quote
Old March 2nd, 2010, 01:06 PM   #137
singlecoillover
singlecoillover's Avatar
Motorcycle(s): 09 Ninja EX250-J Special Edition
Valvoline 10w40 4-stroke motorcycle oil. Kawasaki filter I got from my dealer. (14 dollar filter!!!)
I've heard of people running from 5w30 to 20w50 in their 88-07 ninjettes.
I'm not really sure what the factory recommendations are for the newer gens.
singlecoillover is offline   Reply With Quote
Old March 2nd, 2010, 01:13 PM   #138
00v_Lucky
00v_Lucky's Avatar
Motorcycle(s): '09 Candy Thunder Blue Ninja 250R
and a crush washer, then you're good!
00v_Lucky is offline   Reply With Quote
Old March 2nd, 2010, 01:17 PM   #139
Ramen
Frak It
Ramen's Avatar
Rotella 5w-40 fullsynthetic. Fram filter - though some on here poo poo them.
I change the filter everytime.
Ramen is offline   Reply With Quote
Old March 2nd, 2010, 01:27 PM   #140
Timm3h
Do you really notice a difference switching to synthetic?
And thats diesel engine oil?
Old March 2nd, 2010, 01:33 PM   #141
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
Mobile One Full Synthetic Motorcyle Oil
Yes, big difference with synthetic. Bike now runs like a 1000.
Old March 2nd, 2010, 01:42 PM   #142
stealth250
Gearhead
stealth250's Avatar
Valvoline 20W50 4 stroke motorcycle oil and Wix #24941 filter. I change mine every 1000-1500 miles. The O'reilly Auto Parts by me always has the filter in stock.
Here's another thread sort of related to this subject...
http://www.ninjette.org/forums/showthread.php?t=22318
stealth250 is offline   Reply With Quote
Old March 2nd, 2010, 01:44 PM   #143
/moved to new-gen tech
Old March 2nd, 2010, 01:46 PM   #144
Ramen
Frak It
Ramen's Avatar
Oil is oil, it's the viscosity (5W-40) that matters. Big rigs happen to use 40 weight oil and so do our bikes.
I'm not sure if I noticed the difference or not. Primarily, I use synthetic oil in my car and bike so I don't have to change it as often.
Old March 2nd, 2010, 01:55 PM   #145
CC Cowboy
CC Cowboy's Avatar
So there is no difference in regular oil and synthetic except the time between changes?
Why does some oil say for motorcycles? If oil is oil should it work for everything?
Old March 2nd, 2010, 02:36 PM   #146
Reswob
Reswob's Avatar
Motorcycle(s): 2008 Triumph Bonneville Black
I use whatever brand the kawi dealer sells, and Kawi oil filters. Pretty reasonable suprisingly.
Reswob is offline   Reply With Quote
Old March 2nd, 2010, 02:45 PM   #147
JokerSeven
JokerSeven's Avatar
Lots of info here, check it out
http://www.ninjette.org/forums/showthread.php?t=13033
To quote myself, this is what I posted in that thread.
Old March 2nd, 2010, 02:49 PM   #148
ninja man
ninja man's Avatar
Motorcycle(s): ninja250r , zrx1200r, vfr800, cb1300s.
i use putoline 10w/40 semi synth £3.45Litre and gen kwak oil filter £4.20
i will change oil and filter every 1500miles ..
ninja man is offline   Reply With Quote
Old March 2nd, 2010, 03:00 PM   #149
Greg_E
Motorcycle(s): 90 Suzuki gsx600f Katana, 03 Buell XB9R
Start here:
http://www.badweatherbikers.com/buel...tml?1267398133
continue here:
http://www.badweatherbikers.com/buel...tml?1267414404
The problem with just any oil is the friction modifiers in the newest version of car oils may decrease clutch life.
Greg_E is offline   Reply With Quote
Old March 2nd, 2010, 04:00 PM   #150
Snake
Snake's Avatar
I use Mobile 1 full synthetic 10w-40 Motorcycle oil.
Old March 2nd, 2010, 06:29 PM   #151
g21-30
g21-30's Avatar
As mentioned in one of the "stickies":
http://www.vfrworld.com/tex_vfr/tech/oil.htm
Old March 2nd, 2010, 07:19 PM   #152
MKlein3004
Fighting Texas Aggie '08
MKlein3004's Avatar
Motorcycle(s): 2008 Ninja 250r (Race), 2005 Kawasaki Ninja ZX-6R 636 (Track), 2005 Ducati Monster 620 (Street)
MKlein3004 is offline   Reply With Quote
Old March 2nd, 2010, 07:21 PM   #153
Greg_E
That's the short version, in the first link I gave is a link to the full article, took a while to read but I consider it time well spent.
OK different authors but same good info:
http://motorcycleinfo.calsci.com/Oils1.html
Old March 2nd, 2010, 07:35 PM   #154
miks
I'm lovin' it.
miks's Avatar
Motorcycle(s): '09 Black 250R
Valvoline 10W-40 Full Synthetic Engine Armour & Kawasaki oil filter, but will be switching to the K&N oil filter in my next oil change. Going to start changing oil and filter every 5000kms.
A question about the filter, when you guys change it do you guys change both O-rings or the big one only?
Son: When I grow up I want to ride a motorbike.
Father: You can't do both son.
miks is offline   Reply With Quote
Old March 2nd, 2010, 07:37 PM   #155
2WheelGuy
2WheelGuy's Avatar
I highly recommend using a high quality synthetic oil. I use Shell Rotella T synthetic.
250 Ninja motors have a design flaw that can cause a loss of oil pressure when run hard. I don't know if this has been corrected in the new motors or not but I doubt it.
I have seen many 250s with spun bearings. I've even lost a motor myself before I got anal about oil. I was running dinosaur oil and letting the oil level get down to the lower level mark.
Since burning up my (my girlfriends) motor I switched to Shell Rotella T and have maintained the oil level at the full mark at all times. Since then I have ridden many dozens of days at the track with no engine failures.
AFM #278
Old March 2nd, 2010, 09:34 PM   #156
Ramen
Frak It
Ramen's Avatar
My meaning is that they are interchangable.
The only difference between motorcycle oil and standard automotive oil is $5/quart.
Old March 3rd, 2010, 06:29 AM   #157
stealth250
Gearhead
stealth250's Avatar
Not true. Automotive engine oils contain friction modifiers and some contain moly. This will effect the clutch performance in wet clutch applications. You are much better off using motorcycle specific oil. Even though it costs more than automotive oil, you only need to buy 2 quarts. The way I look at it, it's cheaper to spend a few more bucks on the correct oil than replacing the clutch prematurely.
Old March 3rd, 2010, 07:30 AM   #158
mrkyo
Motorcycle(s): 08 Kawi Green 250R
Motul 5100 Semi-synthetic 10w-40, with emgo filter, no complains so far...
mrkyo is offline   Reply With Quote
Old March 3rd, 2010, 08:25 AM   #159
Greg_E
You need to read the articles linked
Old March 3rd, 2010, 09:38 AM   #160
Momaru
Momaru's Avatar
Royal Purple 10w-40, synthetic since break-in and WIX filters. No complaints thusfar.
Proud member of the Blue Army
Oil filter crosses over with Honda filter smokinsingle 2008 - 2012 Ninja 250R Tech Talk 4 April 19th, 2014 08:47 AM
Loss of oil and Air filter soaked in Oil 08ninja250 2008 - 2012 Ninja 250R Tech Talk 19 August 9th, 2010 05:35 PM
change oil filter, without draining oil? peter330 2008 - 2012 Ninja 250R Tech Talk 5 May 30th, 2010 01:08 PM
Which Oil Filter? g21-30 2008 - 2012 Ninja 250R Tech Talk 38 March 23rd, 2010 03:48 PM
