October 4th, 2011, 05:50 PM | #1 |
[motorcyclistonline] - Battery Chargers | Tools 101
Many of the parts on your motorcycle wear out in direct correlation to use. Ride more and your tires, brake pads and chain will deteriorate sooner.Many of the parts on your motorcycle wear out in direct correlation to use. Ride more and your tires, brake pads and chain will deteriorate sooner. Batteries are exactly the opposite: Providing your machine’s charging system is operating correctly, and the terminals and connections are clean, your battery will likely live longer if you ride every day than if you ride every few weeks. Motorcycle designers walk a tightrope between battery capacity, physical size and weight, which means a motorcycle battery doesn’t have as much reserve as an automobile battery. To get the most out of your battery, you’ll need a trickle charger in your garage—ideally with a plug hard-wired to the machine so it can be connected easily and often. Photo Gallery: Battery Chargers | Tools 101 - Motorcyclist Magazine Battery Chargers | Tools 101 | Digg It | Add to del.icio.us Click here for full story...
[motorcyclistonline] - Hammered! | Tools 101 | Ninjette Newsbot | Motorcycling News | 0 | April 16th, 2012 11:10 PM |
[motorcyclistonline] - Allen Wrenches | Tools 101 | Ninjette Newsbot | Motorcycling News | 0 | March 27th, 2012 08:20 PM |
[motorcyclistonline] - Thread Repair Tools | Tools 101 | Ninjette Newsbot | Motorcycling News | 0 | February 27th, 2012 08:20 PM |
[motorcyclistonline] - Motorcycle Brake Bleeding Tools | Tools 101 | Ninjette Newsbot | Motorcycling News | 0 | February 2nd, 2012 11:00 PM |
[motorcyclistonline] - Deland Fl. Deltran Battery Tender Battery Chargers | Ninjette Newsbot | Motorcycling News | 0 | December 9th, 2009 05:50 PM |
