Old September 22nd, 2014, 06:35 PM   #1
ninja2007
Motorcycle(s): 2007 Ninja
Left side Pre-gen turn signal...
The rubber on mine cracked up on a ride the other day, and now is drooping down...
Anyone have a good left front turn signal they want to part with?
Thanks,
Zach
ninja2007 is offline   Reply With Quote
Old September 25th, 2014, 07:28 PM   #2
Kruse08
Kruse08's Avatar
Motorcycle(s): 99 Ninja 250
I can take a look when I get home, I have a pair of front turn signals.
Everything you’ve ever wanted is on the other side of fear. –George Addair
Kruse08 is offline   Reply With Quote
Old September 25th, 2014, 07:56 PM   #3
Hero Danny
Inline 4!!!
Hero Danny's Avatar
Actually, I may still have mine, only thing is I cut the wire, so you'll have to use your own bulb + wire, but the housing is completely fine.
Be careful. Remember you are
invisible
Old September 29th, 2014, 07:48 AM   #4
ninja2007
Cool,
The housing is good on mine, just the rubber section is torn!
Thanks,
Zach
Old September 30th, 2014, 03:31 PM   #5
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
FWIW, the rubber bit is the same for all four corners. The LF and RR lenses are the same, as are the RF and LR. The housings swap the same as the lenses. The bases on fronts can be removed in order to use the signals on the rear.
Pre-gen left footpeg Milsparro Items Wanted 4 December 5th, 2014 01:29 PM
WTB pre-gen left handlebar in SoCal TONIGHT cookiebug79 Items Wanted 20 February 27th, 2013 11:56 PM
WTB: Left side turn signal/clutch lever/ shift lever/fairing (green/red or black) daedrick Items Wanted 0 April 3rd, 2012 12:44 PM
Turn signal left side or right side? Yasko 1986 - 2007 Ninja 250R Tech Talk 7 May 27th, 2011 11:06 AM
Pre Gen Side Fairings 20ninja03 Motorcycle-related 1 April 24th, 2011 08:47 PM
