August 17th, 2009, 09:19 PM | #1 |
ATGATT Squid Killer
Join Date: May 2009 Motorcycle(s): '06 CBR600 Posts: 189
Battery died, won't hold full charge?
So like an idiot, I accidentally put my bike into "P" instead of "Off--Lock" when I parked it a couple of days ago, thus leaving the rear light on...
Fast forward to today, I go out and hop on my bike to head to work and after monkeying with the key and wondering why it won't turn to on, I realize that it was on "P" the entire weekend, sucking my battery dry. Luckily I live close enough to walk to work, so after getting home, I bump started the bike, let it warm up and went for a 25 minute ride. Parked for two hours, came back out to the bike, and the ignition would come on, and make a strange electrical noise but would NOT turn the engine over. So I bump started it again, and this time took the LONG way home hoping to charge the hell out of the battery, but we'll see tomorrow if its holding enough juice to kick the engine over. My question is, what's the deal with the charging system? Is there a certain amount of time that the bike needs to be running in order to fully charge? Apparently my bike's system isn't as efficient as my car's |
August 17th, 2009, 10:33 PM | #2 |
Join Date: Jun 2009 Motorcycle(s): Red '08 250 Posts: 233
I left my key in one day and drained the battery, jumped it with my car and that worked great
sorry if this information isnt helpful heh |
August 17th, 2009, 10:35 PM | #3 |
25 minutes may not be enough to revive a stone dead battery. If the battery was in good shape before this happened, it's likely able to be revived, but the best way to do it is to hook up a battery tender (~ $30 or so) to it. If you need to recharge it only by running the bike, I'd think it may take as many as 2 - 3 hours on the freeway to get it fully topped off.
August 17th, 2009, 11:16 PM | #4 |
Join Date: May 2009 Motorcycle(s): 2009 blue ninja 250R Posts: 742
whats the diff between a battery tender and a battery charger?
August 17th, 2009, 11:34 PM | #5 |
A battery tender is a type of charger, that's all. The tender has the smarts to not overcharge a battery; it's safe to leave on continuously and it will just keep the battery topped off. In the past, chargers without those electronics could fry batteries if people left them on too long. I don't think those old-style chargers are common anymore, and it's likely that most modern chargers for car or bike batteries would have similar electronics.
http://www.batterytender.com/
August 18th, 2009, 08:28 AM | #6 |
motorcycle rider
Join Date: Apr 2009 Motorcycle(s): '14 Yamaha V-Star 650 Custom (silver) Posts: A lot.
If the battery is less than a couple of years old, you can probably put it on a battery tender overnight and it will be fine.
If the battery is more than say two or three years old, it may be toast after being drained to death, and might need replacement. Bike batteries just don't have the same lifespan as a larger, higher capacity car battery.
'14 Yamaha V-Star 650 Custom (silver) |
August 18th, 2009, 10:58 PM | #7 |
Thanks for the note. I figured as such but wanted to be sure Take care |
August 18th, 2009, 11:35 PM | #8 |
Join Date: Jan 2009 Motorcycle(s): '08 250R (sold), '05 ZX6R / 636 Posts: 355
Hey Don,
I had similar issues.. bike died, bump started, ran for about 25-30 minutes (the norm for most car batters I think) and that wasn't enough to charge up the battery sufficiently. Bump started again and went on a ride that lasted a little over an hour and I was good to go after that. You may just need to keep it running to juice it up sufficiently? Good luck! |
August 19th, 2009, 10:02 PM | #9 |
ATGATT Squid Killer
Just wanted to update this. I had the exact same experience as muffin. The 25-min ride wasn't enough to fully charge it. So I bump started it again, went for about a 30-35 min. ride, and when I went out to ride the next morning, the bike was good to go. I'm thinking a good solid 1 hour ride could be sufficient to charge it enough.. I'm not about to test that hypothesis though, haha.
August 19th, 2009, 10:13 PM | #10 |
Be sure to read the good advice that Bruce wrote, too, or you might end up surprised one day if the battery is more than a few years old.
August 20th, 2009, 06:26 PM | #11 |
ATGATT Squid Killer
Thank god for bump starts The thing is easier to bumpstart any dirtbike I've ever owned, and i've owned a handful. My battery looks pretty new.
Video- Ninja won't hold charge | 2003ninja | 1986 - 2007 Ninja 250R Tech Talk | 45 | January 13th, 2013 01:23 PM |
killed battery now won't start - shorted something. | pezlow010 | 1986 - 2007 Ninja 250R Tech Talk | 38 | December 10th, 2011 07:17 PM |
My Bike's Battery Died, What Should I Do? | Jiggles | General Motorcycling Discussion | 28 | November 18th, 2011 03:04 AM |
New battery, still won't start | frankfong | 1986 - 2007 Ninja 250R Tech Talk | 9 | January 12th, 2011 10:08 AM |
bike died, and now won't start | davidgz | 1986 - 2007 Ninja 250R Tech Talk | 13 | August 31st, 2010 06:01 PM |
