#1 |
Join Date: Nov 2013 Motorcycle(s): 2008 Ninja 250r Posts: 24
leaking oil D:
Hey guys, recently did a oil change. A few days later I went to the bank and the next day I noticed a few oil spots under my bike. I had some trouble placing the big o ring in the spot when doing the change. I used the one in the fram filter box. Is that all that could be causing this?
#2 |
Hm I did just make an observation. Stumbled upon a bolt that was kinda loose next to the oil filter. Not sure what that bolt even goes to but i tightened it up.
#3 |
Join Date: Sep 2009 Motorcycle(s): 2009 Kawasaki Ninja 250R, 2008 Suzuki GSX-R600, 2006 Suzuki GSX-R600 Posts: 31
Both could be causing it - did you wipe clean engine oil on the o-ring before installing it? That helps it seal better. Also, ensure that the filter plate/bolt was torqued correctly.
Wipe and clean up the areas in question and pin-point where the oil is coming from - that should tell you what needs fixing, as there should be oil residue coming from the problematic part. |
#4 | ||
Join Date: Apr 2012 Motorcycle(s): '12 ninja 250r Posts: 762
You should be good to go now ![]() Last futzed with by broilmebk; December 3rd, 2013 at 01:44 PM. |
#5 |
Yeah that bolt was what I was talking about, that probably was leaking too, but I took the filter out and the O ring had a big chunk missing from it, so it must have snagged when putting it on the last time, this time I didn't press the metal plate all the way down, I pushed it up into the bike and tightened the bolt and I believe that did the trick, started it and let it run for 10 mins and no leak. thanks for all the help as usual fellas, best forums.
Leaking oil where there shouldn't be any | Trailerboy531 | 2008 - 2012 Ninja 250R Tech Talk | 21 | October 13th, 2014 05:43 PM |
Coolant leaking into oil and oil leaking out of somewhere. | Monkeytofu | 1986 - 2007 Ninja 250R Tech Talk | 31 | May 25th, 2013 04:09 PM |
Gas Leaking into oil | swsh23815 | 2008 - 2012 Ninja 250R Tech Talk | 18 | February 4th, 2013 08:53 AM |
oil leaking on right fork | mctran | 2008 - 2012 Ninja 250R Tech Talk | 26 | July 16th, 2012 11:08 PM |
HELP! oil leaking heavily, smoking | Clearlynotstefan | 1986 - 2007 Ninja 250R Tech Talk | 9 | May 8th, 2011 09:53 PM |
