Old April 19th, 2012, 04:31 PM   #1
Exeter250
Motorcycle(s): Zrr 250
Unhappy Trouble refitting the rear wheel!
Hi,
I removed my rear wheel so the shop could replace the brake rotor for me, as the previous owner had rounded off the bolts, and I'm having trouble fitting it back on to the bike.
the problem is, when I fit the wheel the disk grinds on the pin that holds the larger of the brake pads in place. I have made sure the new pads are in the right place.
I'm sure I have the spacers correct, Looking from the back of the bike, the smaller one is on the left hand side and the one with the larger half is on the right hand side, between the wheel and the brake.
Does anyone have an idea what could be causing this?
Exeter250 is offline   Reply With Quote
Old April 19th, 2012, 04:46 PM   #2
Jono
Jono's Avatar
Did you reset the piston in the caliper before you put the new pads on?
Old April 19th, 2012, 05:19 PM   #3
Are your slack adjusters facing the correct way?
This diagram shows the correct orientation
Old April 23rd, 2012, 01:32 PM   #4
Exeter250
The pads are fitted correctly, and the brake rotor goes between the pads correctly, but it hits the pins which hold the larger pad in place, its almost as if the brake rotor is over sized by a couple of mm.
My adjusters dont look like those in the diagram, they fit inside the end of the swingarm. I left them in the swingarm when I took the wheel off to make sure i didnt loose them
Old April 23rd, 2012, 01:42 PM   #5
oops! Didn't notice you have a zzr, not a pregen.
Old April 23rd, 2012, 02:22 PM   #6
take photos
Old April 23rd, 2012, 06:51 PM   #7
Exeter250
Will try to take some pictures tomorrow if it stops raining...
Old April 24th, 2012, 05:57 AM   #8
cbdallas
cbdallas's Avatar
Motorcycle(s): 2007 Ninja 650R
It'll be easier if you take off the caliper before re-installing the wheel. 2 bolts & done. Then re-fit it when the wheel is mounted.
cbdallas is offline   Reply With Quote
Old May 5th, 2012, 04:23 PM   #9
Exeter250
I finally got around to taking the caliper off, and I can now get the wheel back on, but I'm still having the issue with the Disk hitting the back of the caliper:
http://imageshack.us/photo/my-images/502/imag0021r.jpg/
http://imageshack.us/photo/my-images...mag0022ut.jpg/
http://imageshack.us/photo/my-images/99/imag0023f.jpg/
Does anyone have any ideas on how to sort this?
Rear Brake Light Trouble Devita818 2008 - 2012 Ninja 250R Tech Talk 16 April 18th, 2015 07:50 PM
Rear Brake Bleeding Trouble dwright0723 2008 - 2012 Ninja 250R Tech Talk 14 May 7th, 2014 07:26 PM
08+ rear wheel, right rear set, rear brake system, seat cuong-nutz Items Wanted 2 October 6th, 2013 05:37 PM
Rear wheel spitting up onto the fender & rear seat. Solutions? uKER 2013 - 2017 Ninja 300 Farkles 21 July 29th, 2013 01:00 PM
Trouble aligning rear wheel and chain CmichRider 1986 - 2007 Ninja 250R Tech Talk 11 June 20th, 2012 10:18 AM
