Old April 11th, 2009, 04:32 PM   #1
KVR
BALANCE:::GRACE:::CONTROL
KVR's Avatar
Motorcycle(s): (08 Ninja 250R Kawi Green but currently a project since Jan 31, 09;) 2007 Honda CBR 600RR White
slip-on exhaust
is it required to have a FP jet kit when running a slip-on exhaust? Im more worried about engine life than performance. Running a slip-on without a FP jet versus with a FP jet kit. which set up maximizes engine life?
Thank You
KVR is offline   Reply With Quote
Old April 11th, 2009, 05:35 PM   #2
I'd say a jetting change will help engine longevity by helping the engine to run at a less lean (hot) condition. These engines are set pretty lean from the factory as it is...adding a slip on leans it out even more.
No need for a jet kit, though... shimming the needles will richen the mixture where it needs it most... in the low and midrange.
have you read this?
http://www.ninjette.org/forums/showthread.php?t=9465
Old April 11th, 2009, 07:40 PM   #3
mike_sema
mike_sema's Avatar
Motorcycle(s): ninja 250r
08 250R: sportisi VR full exhaust, Dynojet, custom seat, kleen air rmvd, rim tape, grips, fender chop,zg db windscreen,k&n air filter,15t front sprocket,sportisi-usa clipons,solo seat cowl
mike_sema is offline   Reply With Quote
Slip-On Exhaust Mrudloff 1986 - 2007 Ninja 250R Tech Talk 8 October 11th, 2014 01:19 PM
How to remove stock exhaust and install aftermarket Slip-On Exhaust System Ninja 300 SON1C 2013 - 2017 Ninja 300 Tech Talk 4 August 14th, 2014 05:45 PM
slip on exhaust? NinjaLINY 2008 - 2012 Ninja 250R Tech Talk 7 April 30th, 2014 07:00 AM
Looking for a Slip-on exhaust? mariorivera830 2008 - 2012 Ninja 250R Tech Talk 32 August 26th, 2012 01:16 PM
what slip on exhaust bandit_fosky 2008 - 2012 Ninja 250R Tech Talk 14 July 30th, 2012 07:13 PM
