Old January 10th, 2011, 09:04 PM   #1
scotty
scotty's Avatar
Motorcycle(s): Yahama v star 650 classic
Lifting Front?
I have no idea how thses things work. Lol I need to lift the front up. The box they came with have no instructions, and the pictures on the box are to hard to make out. I looked in the DIY posts, but they did not have stands with these.
scotty is offline   Reply With Quote
Old January 10th, 2011, 09:29 PM   #2
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
Use them like that. One of the black pads should be under the forks, while the other one is on the backside of the fork tube.
k-os is offline   Reply With Quote
Old January 10th, 2011, 09:31 PM   #3
scotty
scotty's Avatar
Got it! Thanks Andy!
Old January 11th, 2011, 08:59 AM   #4
kamikaze
ex-ninjette.org guru :o
kamikaze's Avatar
Motorcycle(s): 2003 SV1000 S
I've got a front stand like that, and it sucks. be very careful that the forks don't slip off those fingers or the front end is coming down in a hurry. just ordered a head lift stand instead, the one where the pin goes up and into the steering stem of the triple clamp.
kamikaze is offline   Reply With Quote
Old January 11th, 2011, 09:01 AM   #5
scotty
scotty's Avatar
Yeah, that is the kind that I want. I may just break down and buy anther one. I don't feel to confident with that one I have.
Old January 11th, 2011, 09:35 AM   #6
Flashmonkey
Professional belly dancer
Flashmonkey's Avatar
Motorcycle(s): 1992 GSX-R 750
It'll also come in handy when you want to work on your forks.
Old January 11th, 2011, 12:18 PM   #7
llenta
llenta's Avatar
Motorcycle(s): 2010 Daytona 675 SE
those are certainly easier to use then the ones that lift from the triple tree, but i have more confidence in the triple tree ones. pros and cons to each.
i think if you need to work on your suspension, you have to lift the bike from the triple tree. i'm not sure what you can do if your front forks are compressed and holding the bike up.
llenta is offline   Reply With Quote
Old January 11th, 2011, 02:17 PM   #8
kamikaze
kamikaze's Avatar
once I get the headlift stand, I'm going to see about modding the other front stand. apparently there are holes in the bottom of the fork tubes, and assuming there's nothing to damage in there, i might see about making some pins that fit in there and support it that way for those times where you just need a quick lift to wash the bike or do oil changes etc.
Old January 11th, 2011, 02:24 PM   #9
austexjg
austexjg's Avatar
Motorcycle(s): '09 zx6r Green/Black, (ex-)Diablo Black '09 Ninja 250r
I have both types of front stands (front pin and under front forks) - each have some negatives. The Vortex front pin stand seems to hit the bottom of the front cowling and pushes up against the headlight assembly. I have only used it once, so human error could be a variable.
Last futzed with by austexjg; January 11th, 2011 at 03:28 PM.
austexjg is offline   Reply With Quote
Old January 11th, 2011, 02:33 PM   #10
scotty
scotty's Avatar
Yeah they sell stands that go into the hols on the bottom there. Seems as that would be the easiest way to lift the bike up.
Old January 11th, 2011, 09:51 PM   #11
Flashmonkey
Mine does this to my gixxer all the time. Unless you start hearing cracking, it's no big deal.
Disclaimer: I will not be held responsible for broken fairings.
Old January 11th, 2011, 10:40 PM   #12
Deanohh
Motorcycle(s): Ninja 250, Honda Sabre 1300
I'd add one washer at a time to the pin until it didn't hit anymore.
Deanohh is offline   Reply With Quote
Old January 12th, 2011, 09:50 AM   #13
austexjg
austexjg's Avatar
Great idea...
Old January 12th, 2011, 10:21 AM   #14
Jinx250
Smoker
Motorcycle(s): Guess....
Make sure you buy a sturdy one, like PitBull. Might cost more up front, but you won't have to buy another one. Ever.
Only if you do not know what you're doing. With the one the OP hsa now, you have to make sure the bike doesn't walk off the stand. With the pin type, insert pin in hole, lift. And if you do it properly (and didn't buy a cheap eBay knock off) it should NEVER hit any bodywork. The only con to a PitBull is the cost. But someone once said "only a rich man can afford to buy cheap tools."
Jinx250 is offline   Reply With Quote
Old January 12th, 2011, 04:21 PM   #15
I've got a Pit Bull front and rear, and it does nudge the bottom of fairing below the headlight. Doesn't put much force on it, doesn't leave any scratches or any other damage/blemish, but it definitely makes contact with the bodywork during lifting and while resting on the stand.
Old January 12th, 2011, 08:32 PM   #16
scotty
scotty's Avatar
Well, me and the wife went to three differnt motorcycle shops around town. We found some nice front stands, but boy are they some money! $179.99 was the cheapest we found. Is that about what you all paid? They wern't Pit Bull stands. Any who, I did get the bike up with out any problems! (Crappy picture to follow for proof!!)
Old January 12th, 2011, 08:42 PM   #17
k-os
If they weren't Pit Bulls I wouldn't recommend buying them for that much. I use a T-Rex stand on my bikes and they've worked fine. I also have the triple tree lift for my 250.
Old January 12th, 2011, 08:44 PM   #18
wild-bill
seeking twisties
wild-bill's Avatar
Motorcycle(s): '07 Ninja 650R, '09 250R special edition
Hope you don't mind Scotty, I did some Photoshop work and brought out more detail.
Bill
wild-bill is offline   Reply With Quote
Old January 12th, 2011, 08:48 PM   #19
scotty
scotty's Avatar
Sweet! Thanks Bill! Gotta love cell phone cameras!
Andy, yeah, I can't see myself spending that much on some unknown name stands. I think I may turn to Ebay and find some Pit's to buy.
Lifting The 250R Onto Service Stands kkim 2008 - 2012 Ninja 250R Tech Talk 104 September 29th, 2021 12:22 PM
[superbikeplanet.com] - Lorenzo Fastest In Fog Lifting Third Practice At Laguna Seca Ninjette Newsbot Motorcycling News 0 July 28th, 2012 11:20 AM
Lifting the rear wheel?? Ptdoughnut General Motorcycling Discussion 13 July 16th, 2012 05:26 PM
[superbikeplanet.com] - Espargaro's Team Appeals Lifting Of Marquez Penalty Ninjette Newsbot Motorcycling News 0 June 6th, 2012 12:40 PM
quick question i am off for work about lifting front of the bike reaperw 2008 - 2012 Ninja 250R Tech Talk 26 January 13th, 2012 11:47 AM
