March 4th, 2015, 04:45 PM | #1 |
Join Date: May 2013 Motorcycle(s): 2019 Ninja 400, Sold 2012 Ninja 650, Sold 2009 Ninja 250r, Sold 2007 DRZ400s Posts: 628
coil and plug wire help
OK guys, I pulled my plug wires off the coil and they broke. I wasn't rough, just seemed brittle. Did I do something wrong? And how am I going to get the rest of the wire out of the coil socket?
March 4th, 2015, 05:03 PM | #2 |
OK so it seems I ha e ruined my wires. I only see the coil and wire sold together. Is there anything other than OEM?? I'm seeing them in the $30 range on fleabay. Any member have an extra set to sell?
March 4th, 2015, 05:17 PM | #3 |
Let's call for help:
@PartsNinja
March 4th, 2015, 06:48 PM | #4 |
if i remember right, the coil side is a screw-in type connection so you should be able to cut an inch or so off the cable and simply twist it back onto the screw
March 4th, 2015, 08:16 PM | #5 |
If the NewGen is the same as PreGen, the ignition wire is replaceable, it's a 7mm stranded core wire, pretty common at most real auto parts store.
In the coil where the wire goes into that a compression type fitting, on the plug boot end it just threads into the wire itself.
March 5th, 2015, 06:15 AM | #6 |
so I should be able to reuse the wires? good. I really didn't want to have to buy new right now with only 8k miles
March 5th, 2015, 06:35 AM | #7 | |
Ninja Parts Master
Join Date: Aug 2013 Motorcycle(s): 2011 Ducati Streetfighter 1098, 2014 Honda CB1100 Cafe, 2007 SV1000S, Quite a few 2008-2012 Ninja 250s Posts: 366
Add me on Instagram: @d_jalb Or follow me on eBay: PartsNinja |
March 5th, 2015, 07:50 AM | #8 | ||
The wire itself is cheap enough, and you only need about a foot, cut it in half, and your cover for a very long time for renewable the ends. I personally do mine at the start of each season, along with cleaning the caps. For those whom are scratching their heads, Quote:
Ignition coil wire leads | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 7 | June 25th, 2014 05:59 PM |
top of spark plug stuck in coil | Nova46 | 2008 - 2012 Ninja 250R Tech Talk | 18 | June 10th, 2014 07:00 PM |
[kropotkin thinks...] - 2014 COTA Moto3 Race Result: A Wire To Wire Win | Ninjette Newsbot | Motorcycling News | 0 | April 13th, 2014 10:10 AM |
Coil Wire Inquiry | Greyfox | 2008 - 2012 Ninja 250R Tech Talk | 5 | January 23rd, 2013 05:01 PM |
Change to Coil over plug | Choter | 2008 - 2012 Ninja 250R Tech Talk | 7 | January 7th, 2011 11:03 AM |
