Old November 23rd, 2021, 07:35 PM   #1
Vansaki
Motorcycle(s): 2007 Kawasaki 250
Cush Dive Free Play
Is there any factory data on the limit of free play on the cush drive ? I seem to have around .25" of free play. Seems like way too much. I will be shimming the cush drive but was just wondering if there was any factory specs on this?
Thanks
Vansaki is offline   Reply With Quote
Old November 23rd, 2021, 07:42 PM   #2
The manual says "Replace the damper if it appears damaged or deteriorated." Not much of a spec.
Old November 23rd, 2021, 07:51 PM   #3
Vansaki
Nice... LOL
Thanks Jim
Old November 24th, 2021, 07:03 AM   #4
Shim it as much as you can and still get it together.
There doesn't need to be any "slack", just enough to get it assembled.
In case you haven't seen it - https://faq.ninja250.org/wiki/How_to...the_cush_drive
I've used ABS plastic.
Makes a big difference, especially in on/off/on throttle transitions. Much better.
Old November 24th, 2021, 07:31 AM   #5
Inner tube rubber comes to mind.
Old November 24th, 2021, 09:48 AM   #6
I think I tried it once, and to my surprise - it worked its way out.
Old November 24th, 2021, 10:06 AM   #7
Vansaki
Thanks to all that replied. I will probably try some plastic.
Thanks
Old November 25th, 2021, 07:34 PM   #8
Beware that lots of info in FAQ is incomplete, outdated or just outright wrong.
In this case, it's partially incomplete. Rather than shimming all 12 spots, shim backside uncompressed rubbers. So when chain spins sprocket-carrier forward, it compresses normal unshimmed rubber cushions. Shims should only go on backside rubbers that's compressed much less when you let up throttle and use engine-braking. This results in much less pressure on shimmed stack and lots less squirming.
Old November 29th, 2021, 04:50 PM   #9
Vansaki
Thank you for all your advice.
Old January 5th, 2022, 08:04 AM   #10
spent_too_much
spent_too_much's Avatar
I've had luck with a newer, used one, from a newgen 250 / 300. It was a perfect fit, and nice and snug.
[motorcyclistonline] - How To Check And Adjust Clutch Lever Free Play Ninjette Newsbot Motorcycling News 0 May 4th, 2018 08:01 AM
[motorcyclistonline] - MC Garage Video: How To Set Throttle Free Play and Why It’s Im Ninjette Newsbot Motorcycling News 0 December 30th, 2016 03:11 PM
Rear Cush drive play and bearing noise? BenzDr 2008 - 2012 Ninja 250R Tech Talk 3 July 10th, 2016 09:28 AM
[motorcycle.com] - How To Adjust Throttle Free Play and Why Ninjette Newsbot Motorcycling News 0 March 9th, 2016 03:10 PM
Connecting rod free play n4mwd 1986 - 2007 Ninja 250R Tech Talk 24 August 5th, 2012 12:21 PM
