August 29th, 2012, 10:29 AM | #1 |
Track Clown
MOTM - Sep '15
Weight reductions
I am starting preparations for setting my bike up for the 2013 Pikes Peak Hill Climb.
1. I plan on losing 10-15 pounds my self, going from 175-180 to 160-165. 2. Race body work is coming possibly over winter. 3. I have removed the air box and replaced it with a K&N universal filter. 4. Re-jetted and dynoed everything is pretty smooth. 5. Muzzy slip-on pipe. 6. GSXR rear shock, looking at getting dog bones from rexbo, just waiting to get paid. 7. need to do some front suspension work, probably going to raise triples to the top of the forks. 8. my bike needs a diet, but i dont know where to start, I have heard of people getting down to 300#s. |
August 29th, 2012, 10:57 AM | #2 |
Join Date: Dec 2011 Motorcycle(s): 2009 Ninja 250R Posts: 145
We should make a sticky to reference all "weight loss" programs, since the search yields scattered results.
The challenge is losing weight while keeping a bike compliant to class rules. If you do not have rules to adhere by, let your imagination run wild... But a few off the top of my head: -Track plastics to delete lights, mirrors, & rear seat -Lose all misc/unnecessary brackets (Passenger pegs, exhaust hanger, wire clips, etc) -Lose anything with a lock (gas tank lock, seat lock if using track plastics, ignition switch) -Remove misc/unnecessary covers (Sprocket, chain guard, battery cap) -LiPo battery -Clip-ons & rearsets -Lose the OEM exhaust for a full system or slip on -Lose the radiator fan -Lose the OEM coolant overflow for a smaller contraption -Lose the rear brake fluid reservoir for tygon tubing + plug -415 chain setup -Lose stock cluster + front fairing stay -Lose airbox -Lose emissions system and cap of SAI system -Aftermarket wheels -Lose speedo gear/cable -Lose your left side handle bar controls -Run enough fuel in your tank for your purpose Last futzed with by jp129; August 29th, 2012 at 12:20 PM. |
August 29th, 2012, 12:18 PM | #3 |
CVMA / AFM / M1GP #250
Join Date: Sep 2009 Motorcycle(s): 2009 Ninja 250r, 2011 Zero S, 2009 KLR 650 Posts: A lot.
you can cut the rear subframe right behind the rear seat where the two frame tubes come together, lose like 10 lbs that way. Also cut the kickstand mount off, trim the front fairing stay, lose random brackets that hold stuff like the OEM coolant reservoir, lose the front sprocket cover, get rid of all the stuff on the wiring harness you don't need, etc.
August 29th, 2012, 12:40 PM | #4 |
Join Date: Nov 2010 Motorcycle(s): '09 250 Street, '09 250 Race, '13 300 Race Posts: A lot.
You could mill or drill out the rear rotor.
CVMA #55 |
August 29th, 2012, 12:42 PM | #5 |
CVMA #74 WSMC #750
Join Date: Oct 2009 Motorcycle(s): All of them Posts: A lot.
Is this for a race org? If so, make sure all those weight reductions are legal. Some classes do not allow you to make any modifications as suggested.
August 29th, 2012, 01:53 PM | #6 |
in addition to the above you can also replace coils and plug wires with coilover plugs (-5lbs), and lose the extra cooling utils (thermostat and temp sender unit, about 2lbs- you dont need it when you dont have gauges)
August 29th, 2012, 10:29 PM | #8 |
Track Clown
MOTM - Sep '15
I just skimmed through the 2012 rule book for the Pikes Peak hill climb and there are no restrictions on weight. but i noticed in the 250 class that most bikes were Super Motos.
August 29th, 2012, 10:48 PM | #9 |
Humble Observer
Join Date: Mar 2009 Motorcycle(s): 2009 Yamaha XT250 Posts: 612
Pikes Peak used to have gravel.
Everything I post is "IN MY HONEST OPINION". Why is "Parking Lot Enduro" not a thing? |
August 29th, 2012, 11:20 PM | #10 |
One of our local Guys just back from Pikes peak I'll see if I can cross link the thread. Later
August 29th, 2012, 11:27 PM | #11 |
Just removed my left controls, ignition tumbler, wiring harness, that was almost 4lbs there.
August 29th, 2012, 11:29 PM | #12 |
Ambrosia.
Join Date: Aug 2011 Motorcycle(s): 1974 Honda CB550K0 W.I.P. Posts: A lot.
Remove all the fluids. The "dry weight" is always way less than the "wet weight."
Life's better on the Mountain. |
August 30th, 2012, 12:08 AM | #13 | ||
Just out of curiosity, is an FI system preferred given the elevation changes?
CVMA #55 |
August 30th, 2012, 05:42 AM | #14 | |
Join Date: Jul 2012 Motorcycle(s): 2012 Ninja 250R, 1993 CBR900RR, 1974 CB360T Posts: 17
Yea I'm thinkin the carb'd bike is really going to run out of breath climbing that high. Sometimes I ride through the mountains in blue ridge parkway (approx. 3-4000 ft) and the bike really does have a hard time. |
August 30th, 2012, 05:55 AM | #15 |
August 30th, 2012, 10:40 AM | #16 |
@cbinker: http://www.motohouston.com/forums/sh...ght=pikes+peak
@Rexbo: http://www.ninjette.org/forums/showt...t=triple+clamp
August 30th, 2012, 10:53 AM | #17 |
jet it so it pulls like a mofo. then go down one main jet size? that would split the difference maybe?
August 30th, 2012, 10:42 PM | #19 |
Track Clown
MOTM - Sep '15
I checked out the 415 chains, and what i found recommends 18 front and 57 rear, are they that light weight you can go up 4 in the front and 12 in the rear?
August 31st, 2012, 05:42 AM | #20 |
Since the 415 pitch is vastly different from the 520 in size, the recommended ratio will get you close to the stock 520 ratio.
IIRC, they said the weight difference is around 2~3lbs. |
[motorcyclistonline] - Weight, Weight, Don’t Tell Me | Cranked | Ninjette Newsbot | Motorcycling News | 0 | July 17th, 2014 09:40 AM |
[sportrider - latest stories] - Significant insurance rate reductions for AMA-sanctio | Ninjette Newsbot | Motorcycling News | 0 | February 29th, 2012 05:20 PM |
[hell for leather] - Husqvarna 900: power, weight and power-to-weight | Ninjette Newsbot | Motorcycling News | 0 | June 29th, 2011 09:20 PM |
Weight Reductions | spencerkro | 2008 - 2012 Ninja 250R Tech Talk | 13 | April 6th, 2011 07:22 PM |
[visordown.com] - MV Agusta announce price reductions | Ninjette Newsbot | Motorcycling News | 0 | March 31st, 2009 08:50 AM |
