Old July 20th, 2014, 11:04 AM   #201
gantt
gantt's Avatar
Motorcycle(s): 2019 Ninja 400, Sold 2012 Ninja 650, Sold 2009 Ninja 250r, Sold 2007 DRZ400s
OK so I rode around the neighborhood for a bit. Initial bite is OK. I used the pads that came with the caliper. I'm sure new pads would be amazing. Definitely has more braking power. Easier to lock up front tire. It seems to be building more heat than normal. I know the disc brakes with slightly touch all the time. But it feels like there is too much resistance. With the front tire in the air I can spin it but it stops sooner than it used to. Maybe my caliper is misaligned? Doesn't appear to be. Any thoughts or tips??
gantt is offline   Reply With Quote
Old July 20th, 2014, 11:10 AM   #202
Rassie
Motorcycle bon vivant...
Rassie's Avatar
Motorcycle(s): 300 Ninja, 250R Ninja, SV650S, CB350, GT750, Aprilia RS250, Triumph Street Triple R
Mount the caliper without the pads, make sure it is exactly in the middle of the caliper opening. I usually do this with the front end off the bike, not and option in this case, so I recommend you get the bike up high enough so you can look at it from below and above. Also check the alignment with a straight edge. The caliper must run 100% aligned with the rotor and 100% in the center otherwise it will produce the effect you are describing.
NESBA 13, 300 Ninja, 250r Ninja, 06 SV650, Ninja ex250, CB350, CL90 ,GT750, Aprilia RS250, Triumph Street Triple R www.mybikeproject.com
Rassie is offline   Reply With Quote
Old July 20th, 2014, 01:29 PM   #203
gantt
gantt's Avatar
Thanks rassie. I'm going t take the other bike to work until I have time to double check everything. The rotor is definitely getting too hot. Thanks for the information. So far the caliper rocks!!!
Old July 21st, 2014, 03:51 AM   #204
gantt
gantt's Avatar
Well I lost the keys to the 650 so I had to take the 250. I think the heat I felt was from how hard I was using the front brake yesterday. Still want to double check things but I think its OK. This thing feels good. Also show the weakness of the stock irc tire.
Old July 21st, 2014, 07:14 AM   #205
bruce71198
bruce71198's Avatar
Just found this thread, good info.
Here is the setup I built for my track bike which I tested for the first time this weekend.
320mm rotor with a 2002 GSXR600 caliper. It worked well, the only thing that I want to do is bump up a millimeter or 2 in master cylinder bore diameter to fine tune the brake feel.
[IMG][/IMG]
Old July 23rd, 2014, 11:43 AM   #206
gantt
gantt's Avatar
^^^^bruce, I like how your caliper bracket is behind the fork mount. for me to do that I would have to thread the bracket. that's not an issue to do. after I trim down the current bracket and I'm still not happy i'll make another and thread it. gives that area a much cleaner look. People are so caught up in "making it faster" that they never look into the things that really count. it's not all about straight line speed. I much prefer a good turn over triple digits in a straight.
Old August 9th, 2014, 07:32 PM   #207
ninja250r81
ninja250r81's Avatar
Motorcycle(s): 2012 ninja 250r se
Some more ideas
http://www.ebay.com.au/itm/Brembo-Fr...item51c13f42e6
http://www.ebay.com.au/itm/Brembo-CN...item51c01e82f6
Maybe can use for a dual rotor setup (300mm rotors).
Could mount the ER6 right caliper as an upgrade
http://www.ebay.com.au/itm/KAWASAKI-...item3cd8166b3a
ninja250r81 is offline   Reply With Quote
Old August 20th, 2014, 06:56 AM   #208
Rassie
Rassie's Avatar
I just finished mounting a 06 ZX6R radial mount caliper and radial master cylinder (as part of a ZX6R front end swap, to be posted later). The lever feels wooden and it takes quite a bit of pressure to stop the bike. Having said that I have only gone up the road once, so it may be that it is required to be "broken in" so to speak since I am using the stock front wheel and rotor.
I think the radial master cylinder may be overkill for the one caliper. Anyone here have experience with this sort of thing to advise on what to do. I will try the stock master cylinder (since I have it) next.
Old August 20th, 2014, 07:04 AM   #209
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Please note, for a radial caliper the radial master is a must have
Old August 20th, 2014, 09:00 AM   #210
Rassie
Rassie's Avatar
Hows that? A radial caliper is just like any other caliper in design except the way that it is mounted. Radially mounted means it bolts up in a radial fashion meaning the same direction the wheel and rotor is traveling. Otherwise they are the same. The radial master means the same thing, the piston travels in the same direction, front to back as opposed to a regular master cylinder that travels from right to left. So the leverage is different, essentially with a radial master you have more leverage and control, meaning more accurate braking. Therefore you also measure the force they exert on the piston differently.
Having said that I have found out that I have a way to large master cylinder piston size for just the one caliper. You calculate 2 things. The amount of hydraulic leverage , Pi X Radius Squared, and also hydraulic ratio and mechanical to arrive at an overall ratio. See the article below. Interesting read it was, took me a few times to get it but now I am all set. Based on my calculations the stock master cylinder is closer to ideal, so I will try that first and if it does not work I will buy a Brembo adjustable.
http://www.mcnews.com/mcn/technical/Nov2012Tech.pdf
Old August 20th, 2014, 11:03 AM   #211
Rassie
Rassie's Avatar
So I figured out through some basic math that the stock master cylinder will work better than the radial master. Just taking into account the hydraulic pressure ratios.
ZX6R Master cylinder bore seems to be 18mm (based on what I could find online)
The ZX6R calipers pistons are 32mm.
Using the formula quoted above then.
3.1416 x 9 x 9 = 254.46
3.1416 x 16 x 16 = 804.25 x 8 pistons = 6434.
6434 / 254.46 = 25 to 1 ratio.
The 300 MS bore is 12.7mm
3.1416 x 6.35 x 6.35 = 126.68
3.1416 x 16 x 16 = 804.25 x 4 pistons (using single caliper) = 3217.
3217 / 126.68 = 25.39 to 1.
So 25 to 1 is about the right number for this application. I have to factor in lever travel and such but I think it is close enough to try it without further math.
Old August 20th, 2014, 11:44 AM   #212
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
Originally Posted by ninja250r81 View Post
Some more ideas
I have the same set up with the 4pot brembo and a 320mm rotor and I did it all including the new rotor and new pads for under $300
don't even need to do math to tell you that 18mm MC is way to large for a single caliper even if it is radial.
15 is probably where you want to be maybe even the stock 13.
There are a few threads around about caliper swaps, don't be afraid to check out the ones in the new gen section as the brakes are the same.
I have a brembo axial 4 pot on my bike and the stock 13 was not working well at all. I went to the adjustable brembo RC15 or whatever it is called and it is great for my set up
Other members who are using Tokico axial 4 pot calipers on stock rotors seem to have no problem with the stock MC.
Old August 20th, 2014, 01:40 PM   #213
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
The stock master does suck though, no doubt. But there are plenty of people that make me look really really stupid on the brakes with stock caliper/rotor/master so - its not a necessity
Old August 20th, 2014, 09:37 PM   #214
Somchai
Freedom for Germany
Hows that?
I think the way I said it in my answer wasn't correct all the way, since english isn't my native language so sometimes I'm not using the right word and I hope you could forgive me for that.
I'd better said 'you should better use' or in a way like that.
But please let me remind you about another thing (and I hope to find the right words for that), since the front fork of the Ninjette could become the weakest point of the system at all when you are using a strong brake(-system) made for a SS.
Let me try to explain this: a SS normally has a front fork with 50mm diameter and also it is USD, so the triples are tight at the strong 50mm outside of the fork and the inner tube is a real short part of the whole fork only, also this while braking is ?diving? and so it becomes shorter at least - so nothing dangerous and not to mention that the triples are made from aluminum.
Now the Ninjette: she got a 37mm front fork (the lowest level) where the triples are tight to the much longer inner tube which means at the weaker part of the whole fork. With heavy braking this could mean that the tube itself can bend what must not and normally will not result in breaking, but at least that's not good and could be dangerous.
So when you mount bigger rotors and/or calipers from a SS, better don't exaggerate.
By the way, I'm using a Brembo caliper and at least I think that only this is already more then enough for this little bike.
Old August 21st, 2014, 04:16 AM   #215
micoulisninja
modaholic junkie
I've seen it happen on my friend's 250 when we had to brake hard while speeding because of bumps and holes on the pavement...
he got into a quite large hole while still heavy on the brakes and left fork got bent by a bit... I got lucky, no damage but instead of using his 320mm rotor+brembo 4-pot+ huge master, I am only using yamaha R1 04 brembo master(radial) and 4-pot sumitomo caliper, stock rotor...bites quite a lot but just not enough to damage anything...
this keeps making me wonder what can be done to improve stiffness down there... I was thinking of some kind of supermoto clamp stuff but there is just not enough room there... I tried fitting a second front fender holder (the metal pieces that hugs the tire in front of the tubes but it would take a lot of work and bending at other points and it didn't look strong enough again...
any ideas ?? because I believe it is a key thing in order for that mod to be of result under any condition without need to alter the whole front system...there must be some way...
Last futzed with by micoulisninja; August 21st, 2014 at 05:41 AM.
Old August 22nd, 2014, 10:37 PM   #216
Somchai
Freedom for Germany
Hey Nick,
nice to read from you and I hope your well also you're having success with your project.
I'm sorry to have no clear answer to your question about the fork, the only tipp i'd have is to watch here https://www.ninjette.org/forums/show...&postcount=151
At least an usd would be the best way to go and this one for 250 Euro could be a solution http://empiremotoshop.com/products/186/0/Upside-Down/
Good luck and have a nice weekend
Old August 23rd, 2014, 06:33 AM   #217
micoulisninja
modaholic junkie
Hey Nick,
Hi Roland...
well, yeah I'm back and re-designing piece by piece a new whole exhaust system for my new project and so far I am just about to finish welding primary pipes down to link... I am now routing it like stock 300, left of the oil pan, then turn to the right... probably will be ready by end of next week so by 1st September I'll be taking apart the new engine for the modifications...
Anyway, nice and shiny and probably stiffer than stock those upside-down forks... but I have no feedback on anyone having them tested with aftermarket springs and stuff in the track and under extreme conditions to say HOW stiff and well performing they really are when braking hard say from 100mph down to 40 on the front wheel... or how they work while flicking the bike from one side to the other, then speeding and braking hard again while going through a few bumps on a road... have you tried it ?? I would take your opinion very seriously into account if your bike is already equiped with that...
As I have mentioned about a year ago, the european choice for upgrade is the good and tested whole front system from a 2-stroke aprilia rs125 that is almost "plug and play".... only problem is hard to find, a bit pricey as well and wheel travel is by a hair shorter...
However, what I was pointing out (and looking for any ideas) is what can be done to the STOCK front system to make it more rigid under heavy braking....
Old August 23rd, 2014, 09:37 AM   #218
Roland, I see what you're saying about fork flex under braking. However, it's a moot point.
You can lock the front wheel and nose-wheelie with the stock brakes if you so desire. The limiting point of your braking power, regardless of the brake rotor, is the tires. The large aftermarket rotor and stock rotor provide the same ultimate brake force, the difference is in the effort required by the rider at the lever, the amount of modulation available to the rider, and the ability to dissipate heat during repeated heavy braking.
What I'm saying is, since the tires limit the ultimate braking power, a larger rotor and better caliper setup will make no more fork flex than the stock setup.
Old August 23rd, 2014, 10:19 AM   #219
Rassie
Rassie's Avatar
I am way ahead of you guys. Take a look at my posted pictures. I do not think I will have any problems. As a matter of fact I rode the bike about 30 miles this morning and everything is working great even rear wheel lofting stoppies are no problem. The forks are day and night difference and the handling has much sharper but more secure turn in. I did notice my tires are at the end of their life though.
Old August 23rd, 2014, 10:34 AM   #220
Nice! Is it an entire ZX6 front end? Swap bearings and install it, right? Any oddities to keep in mind while doing so?
That looks great. Did you check to make sure the geometry is the same? What spring rate? How do you like having adjustable damping?
Old August 23rd, 2014, 10:55 AM   #221
micoulisninja
modaholic junkie
goodness Rassie !! how on earth did that fit so perfectly there ?? that looks really I want want want !!!
beautiful and simple !! give as some feedback... how does it handle? what about clipons, which did you use ? other mods ? what about length and wheel travel ? spring stiffness ?? I really envy that mod !!
which zx6 model is the donor ? and how on earth did you fit the stock fender so nicely ?
Old August 23rd, 2014, 10:58 AM   #222
Rassie
Rassie's Avatar
Nope had to make a section of the lower stem that could press into the the ZX6R lower triple clamp after I pressed the old one out, then weld it to the upper section of the 300/250 stem. Then it bolts right up with some new tapered bearings.
Geometry is the same except the wheelbase is now about 18mm shorter. Have not adjusted anything yet but backed out the preload all the way. Spring rates seem to be spot on for my weight (185lbs).
Old August 23rd, 2014, 01:35 PM   #223
Rassie
Rassie's Avatar
You Ninjitsu will be pleased to know that I plan to produce a few of these as kits, strictly for racing purposes only off course.
All donor parts are from a 2006 ZX6R. So here are pictures of some of the parts that make the triple clamp work. You will see that the part that was welded onto the original stem was turned from a solid piece and there is overlap where the one pushes into the other so I had plenty of material to run a very deep penetrating weld around it. After welding it was checked to make sure it is true. The wheel required some spacers to be made and I used the original axle. The caliper mounts were too long for the stock rotor so I machined them down some. I had to make a jig to hold it while machining it. I had to space out the rotor as well with 5 spacers. On the left fork I just cut off the caliper mounts. Did not want the extra weight of 2 rotors and 2 calipers since the one produces more than enough stopping power.
I cut the ignition mount off of the top triple clamp and made my own mounting plate, waiting for carbon fiber to arrive so I can dress it up. I wanted to use as many stock parts as possible to keep cost down. However you can use an 07 to 09 top triple that has the ignition mount in the right place.
Initial riding impressions are that it is much more planted than stock. Very little diving under braking, very stable when leaned over. Tip in is faster. I did drop the forks 5mm earlier today so will ride it tomorrow to test it out. I have also not checked the settings on the forks yet. I can however tell that the spring rates feel perfect for my weight and my preference. Stiff, yet compliant. I am writing a blog entry that will show everything in detail and it will be posted on my website when finished.
Old August 23rd, 2014, 04:13 PM   #224
micoulisninja
modaholic junkie
I can't express myself in words about that piece of work so....
about time you fit some decent kawasaki-ss-swingarm too...
I am already saving some pennies... I really want that on my bike !
Old August 23rd, 2014, 06:13 PM   #225
Somchai
Freedom for Germany
Wow @Rassie a big compliment from me, well done and great looking
Old August 25th, 2014, 10:58 AM   #226
Rassie
Rassie's Avatar
Interesting..I am duly intrigued..where can I get hold of said SS swingarm that is a bolt on for the 300?
I have a VFR750 swingarm and wheel sitting on my shelf but it is heavy as shyte..heavier than stock....
Old August 26th, 2014, 06:04 AM   #227
micoulisninja
modaholic junkie
yeah, I know what you mean... I have a honda bros 400 proarm and it just isn't the thing for the ninjette...
how about measuring a ZX6 swingarm ?? I've seen them fitted on Z-750 without any serious mods and I believe it's gonna be a matter of narrowing down the pivot area to get that in place.... or even better an RS 250 s/a....
options are Beet swingarm and some by empireshop but I guess you prefer messing around with other models' stock parts....
Old August 26th, 2014, 06:32 AM   #228
willi777
Motorcycle(s): Ninja 500, VFR750
Awesome job Rassie on the front end swap- looks factory and bad-ass at the same time. Either the VFR400 or RVF400 swingarms, aka nc30 and nc35 i believe, swingarm pivots of 192mmm and 202mm, or thereabouts, but pivot diameter will not match... have a feeling that won't be an issue for you
willi777 is offline   Reply With Quote
Old August 26th, 2014, 07:17 AM   #229
Rassie
Rassie's Avatar
Maybe I will just add some bracing to my stock swingarm. Honestly the Ninjette swingarms have never caused me any issues in handling. The front ends are a different story. I will fit a GSXR750 rear shock in the coming weeks to fix the rear end. I will also see if I can find a ZX6R swingarm I can try or maybe a Versus one, they look bad ass.
Old August 26th, 2014, 10:18 AM   #230
micoulisninja
modaholic junkie
brilliant idea !! but what about shock mounting on the side ??
Old August 26th, 2014, 12:50 PM   #231
Rassie
Rassie's Avatar
Good point, may require some serious frame mods..probably not worth it.
Old August 28th, 2014, 06:55 AM   #232
old3
SV Racing emailed me today, their version of the brake caliper mount is in stock, ready to ship. Email Blair for ordering info as I don't see it on his site yet.
old3 is offline   Reply With Quote
Old August 28th, 2014, 11:39 AM   #233
old3
From Blair at SV Racing...
Thanks, have people Email me Directly at b.layton@svracingparts.com for now and I will set up a direct purchase link very soon on the website,
Enjoy the ride, and best regards,
Blair
Old August 29th, 2014, 07:27 AM   #234
sharky nrk
sharky nrk's Avatar
good to hear, although I figured this had fallen off lol
Old September 4th, 2014, 08:06 PM   #235
old3
First pic of the SVR brake bracket.
Old September 5th, 2014, 07:57 AM   #236
Rassie
Rassie's Avatar
Can't see the picture.
Old September 5th, 2014, 08:29 AM   #237
allanoue
allanoue's Avatar
MOTM - Sep '14
HTTP Status 500 - AUTHENTICATION_REQUIRED
type Status report
message AUTHENTICATION_REQUIRED
description The server encountered an internal error (AUTHENTICATION_REQUIRED) that prevented it from fulfilling this request.
Apache Tomcat/6.0.24
Old September 6th, 2014, 07:50 PM   #238
old3
Blair is sending more pics. I have one in hand today and I'll take a pic in a few minutes too. It is a great looking and very light piece. I'm tempted to remove my 320mm rotor to be able to use it.
Old September 6th, 2014, 07:58 PM   #239
SV Racing Parts
SV Racing Parts's Avatar
Thumbs up
Should be in your inbox any moment now,
I hope you like the look of the Ninja Brake Caliper Adapter Brackets, if they are well received at all I can make them a permanent stocking part for all of our benefit,
Thanks and best regards,
Blair
W.Blair Layton
SV Racing Parts
www.svracingparts.com
SV Racing Parts is offline   Reply With Quote
Old September 6th, 2014, 08:21 PM   #240
old3
This is the one I got today!
Support a company who is willing to support us! The SV Racing Ninjette rear sets are awesome too. I'm trying to convince him to build us a fork brace next!
http://www.svracingparts.com/
I know it took a long time to come, but this is a nice piece and if the market is there, I'm betting we see more Ninjette stuff from Blair.
(fork brace--fork brace--fork brace--fork brace)
2002 GSXR 600 TELEFONICA street/track bike, w/ lots of goodies in CA chugs Motorcycle-related 0 November 13th, 2013 06:17 PM
Mounted Her today ;D StephenA 2013 - 2017 Ninja 300 General Discussion 40 October 12th, 2012 10:41 AM
Where to get tires mounted? Betlog 2008 - 2012 Ninja 250R Tech Talk 4 December 28th, 2009 01:59 AM
