Old November 16th, 2011, 05:38 AM   #1
wardie
Motorcycle(s): 06 KLR 650,12 250 Ninja, 86 DR 125, 07 CRF 100, 09 Tomos Streetmate LEL Record Holder, 88 K100 RT
Clutch slipping isssues
This 92' I recently bought has some issues and I'm fixing them one at a time as I find them. One issue is the clutch is slipping. I've adjusted it per manual and it slips on power shifts. I have the fairings off doing some other things and thought maybe this would be a good time to swap the clutch. I saw EBC has one for $60, factory one is like $140. Anyone can share clutch replacement tips and best souce/best porice for clutch replacement? Thanks in advance.
wardie
wardie is offline   Reply With Quote
Old November 16th, 2011, 06:44 AM   #2
cbdallas
cbdallas's Avatar
Motorcycle(s): 2007 Ninja 650R
I got the fibers / plates & springs for my '94 at CheapCycleParts. Once I tore into it, I found that the clutch parts were fine (there was no perceptible difference between them and the brand new ones), but the springs had gotten weak over time. I could've gotten away with just changing the springs, but all the parts were there, so I just changed out the whole thing.
Make sure to soak the fibers in a bath of oil before installing them. Naturally, don't use oil that has the "Energy Conserving" starburst on the bottle, or you'll be replacing the whole setup again.
http://www.cheapcycleparts.com/model...semblies/25307
cbdallas is offline   Reply With Quote
Clutch slipping... how to fix? walty87 2008 - 2012 Ninja 250R Tech Talk 35 September 10th, 2022 06:33 AM
How to tell if your clutch is slipping? Hero Danny 2008 - 2012 Ninja 250R Tech Talk 29 July 29th, 2014 09:13 AM
Slipping clutch The_big_dill 1986 - 2007 Ninja 250R Tech Talk 11 July 29th, 2013 05:43 PM
{HELP} Clutch Slipping sprtonyy 2008 - 2012 Ninja 250R Tech Talk 20 April 21st, 2010 05:42 PM
back tire slipping/clutch slipping???? help? richierich781 2008 - 2012 Ninja 250R Tech Talk 17 June 19th, 2009 07:13 AM
