Old December 25th, 2020, 05:58 PM   #81
Thanky Mav. What massive piles of stuff comes offa these, consumed my entire workspace! These were truly challenging.
Old December 26th, 2020, 04:52 PM   #82
250 ninja with way oversize #50 pilot jets, returned to OEM 38
Ready to rock again!
Old December 28th, 2020, 07:22 PM   #83
refurbed a set of EX500 carpo-traitors today
Old December 29th, 2020, 03:24 PM   #84
Today sold and shipped the 500 carbs pictured above (were my property)
Old January 5th, 2021, 10:33 AM   #85
first of '21 a 250 Ninj set completed for another member here
Old January 5th, 2021, 10:59 AM   #86
Moto-Kafe
Motorcycle(s): ex250, 500R, zrx, GPz1100, vstrom
Wow!!!
Those look GREAT....wish I had a set like those...........
Moto-Kafe is offline   Reply With Quote
Old January 5th, 2021, 11:07 AM   #87
wishes often come true
as clean in as out...fully functional, set up, ready to bolt on. The owner must endure the extreme task of setting his idle, though.
Added a gut shot (make you envious of owner)
Old January 5th, 2021, 01:52 PM   #88
Moto-Kafe
Gordon........do you pack a spoon and a fork (or, perhaps a "spork") when you send them back to the rightfull owners....???
Old January 5th, 2021, 07:16 PM   #89
look good enough to eat out of, eh?
Old January 17th, 2021, 04:45 PM   #90
A "recheck" completed today on Holley carb model 1904 from a 1958 Ford F100 pickup truck
Found a shard of glass in fuel intake path, otherwise ready to go. Old reference material needed to confirm all components were accounted for and in proper placement.
Interesting old tech.... 1 main jet, accelerator pump, using various ball type check valves of various sizes, in multiple spots. Some use set/return springs, some "float" ...hence the need for an old 50's era manual.
Old January 22nd, 2021, 09:27 AM   #91
BloodFX
Motorcycle(s): kawasaki eliminator 250 d4
This is my carbs when I bought my el250 27 years old lol.
Not as clean as yours but a damn site better after hours of cleaning.
After
BloodFX is offline   Reply With Quote
Old January 23rd, 2021, 01:16 AM   #92
atsmurat
Motorcycle(s): r25
knocked this refurb off, will be long term reliable bolt-on fine runners
look great.. Nice !
atsmurat is offline   Reply With Quote
Old January 29th, 2021, 02:16 PM   #93
Moto-Kafe
Paging.........
Paging Dr. Ducatiman1 to the Courtesy White Phone......(in other words, check your home email, buddy!!)
Old January 30th, 2021, 03:03 PM   #94
EX500 carb refurb underway.
Beyond 2 clogged pilot jets, 1 carb pilot circuit was badly clogged, now cleared.
Some in process pics'll follow. I predict the owner will be pleasantly surprised, a dramatic transition underway, affecting both functional and visual levels.
Last futzed with by ducatiman; February 7th, 2021 at 10:28 AM.
Old February 7th, 2021, 10:22 AM   #95
ANOTHER snowstorm underway here...figured I'd complete these 250's I started yesterday. After full resto....look like they came outta the Keihin factory just a few days ago. I'll predict bolt on runners with a very long service life ahead. In addition petcock innards inspected and confirmed operational as well.
Old February 7th, 2021, 10:46 AM   #96
A few 250 observations. Of late I'm finding the mesh fuel strainers, which should be inserted into the black inlet rail, to be pushed out of place....crumpled and way up a few inches into fuel lines. These are no doubt causing fuel flow issues.
I've discovered the Kawasaki factory EX500 fuel rail filter to fit *much more snug* and not pulling out every time the fuel line is removed.
I stock them and will offer the install option within my services going forward.
But owners need to be aware, I'm finding this a common issue. FWIW...YMMV
Another 'trending" discovery, long term parking on sidestand. Within many carb services I'm encountering contaminants (damaging liquid additives as well as varnish) greatly affecting the LH carb moreso than the RH.
I'd suggest long term storage using centerstand (if so equipped) or an appropriate block of wood under sidestand to somewhat (safely) level the bike somewhat. I repeat....FWIW...YMMV.
Old February 7th, 2021, 11:21 AM   #97
Moto-Kafe
I'd suggest long term storage using centerstand (if so equipped) or an appropriate block of wood under sidestand to somewhat (safely) level the bike somewhat. I repeat....FWIW...YMMV.[/QUOTE]
Good info, Gordon........something every "current EX250 owner" should pass along if/when the bike is sold to the next owner.......
Old February 7th, 2021, 11:42 AM   #98
not limited to 250....i'd apply it to any carbed bike under long term storage, if not draining bowls entirely in anticipation.
Some lean way over too, due to suspension mods or various other reasons.
Old February 7th, 2021, 12:27 PM   #99
yeah, factory config leans way over. I park mine with sidestand on a brick
Old February 8th, 2021, 07:01 PM   #100
geeker
geeker's Avatar
Motorcycle(s): 2022 Honda CRF300L Rally, 2015 Ninja ZX6R 636, 2014 Ninja 1000, 2013 Ninja 300 (sold), 2011 Ninja 250R (sold)
Are these Joey’s? If so, I hear we’ll be seeing them soon and looking forward to it. I’d be interested in hearing what was troublesome with these. I put those in my ultrasonic cleaner when I bought the bike in 2018. The previous owner did some tinkering and it wasn’t running when I got it. I sold the bike to Joey in December 2019.
geeker is offline   Reply With Quote
Old February 9th, 2021, 05:51 AM   #101
harleystyles
Motorcycle(s): 2018 KTM Super Adventure, 2008 Ninja 250R
Yep they are mine. I'm looking forward to getting the bike back going again.
harleystyles is offline   Reply With Quote
Old February 9th, 2021, 06:03 AM   #102
geeker
geeker's Avatar
Old February 9th, 2021, 07:48 AM   #103
main issue included accrued varnish resulting in float valve and pilot circuit issues
pic= 1000 words (Joey is in possession of numerous in-process pics)
Old February 10th, 2021, 12:12 PM   #104
Today safely extracted this faulty pilot jet, replaced with brand new jet... thus saving the carb body.
Extracting stuck pilots from deep within always a heart pounding experience...though it came out in segments. Hey, whatever it takes.
Carb body threads verified undamaged, circuit confirmed clear and ready to roll again.
Note carbset received this morning, shipping back home this afternoon.
Same day service. Try that at your local HonZuKawi dealership.
Last futzed with by ducatiman; February 12th, 2021 at 09:37 AM.
Old February 20th, 2021, 06:15 AM   #105
Moto-Kafe
Thankyou.........
I never posted "publically", but need to say "Thankyou Ducatiman", my rebuilt carbs by you looked absolutely BRAND NEW!!! I have rebuilt carbs (mainly cleaned), but NEVER to the level that he takes his rebuilds. All guts are new, nothing just "cleaned and put back in". It was well worth the $$$ to have it done professionally, and the idle/running of my carbs now prove it!!
Old February 20th, 2021, 07:45 AM   #106
thank you for kind words, glad the refurb worked out so well. At your service during your next upcoming project, if necessary.
Last futzed with by ducatiman; February 20th, 2021 at 11:00 AM.
Old February 20th, 2021, 05:29 PM   #107
notunderweight
carb hater
notunderweight's Avatar
Motorcycle(s): 2006 Ninja EX250F
Wanted to briefly echo Moto-Kafe's sentiment here - This is now the second time that ducatiman has provided a fantastic, professional service for me. Both times - carbs look straight out of the factory, run straight away, and keep running... Not to mention his skillful surgery on my stripped pilot jet
1 day service!
Bike is running great now, looking forward to nice riding weather. Can't say enough good things.
notunderweight is offline   Reply With Quote
Old March 6th, 2021, 05:35 PM   #108
today finished a Honda CB360 twin carbset from 1975. Yep, 46 year old Keihin carbs there!
Old March 7th, 2021, 05:55 AM   #109
BloodFX
I'm gonna buy a soda blasting setup in next few weeks to blast carbs, got any tips for a beginner?
Old March 8th, 2021, 05:52 AM   #110
harleystyles
Update. I finally got off of my duff and put Nina the Ninja back together this weekend. Carbs went on and fired right up. No tuning required, although the next time I find a little time I will fine tune the idle circuit as Ducatiman instructed. She is a TOTALLY different bike now. Absolute hoot to ride.
Old March 8th, 2021, 09:13 AM   #111
glad it worked out! enjoy
Old March 25th, 2021, 10:58 AM   #112
leisurely doin' a refurb on a set of EX500 carbs today.
Unannounced, my neighbor brought his non-running pressure washer over, I found a clogged tiny main jet in the *plastic* carbed BRIGGS engine. Now a one pull start and runner.
Finished the 1st 500's, then onto a 2nd set in house.
Last futzed with by ducatiman; March 25th, 2021 at 04:31 PM.
Old March 25th, 2021, 06:05 PM   #113
myates92
myates92's Avatar
Motorcycle(s): 2006 Kawasaki Ninja, Haulmaster Huskee UTV
@ducatiman you wouldn't happen to have a spare one of these Main fuel intlet fittings I could buy off of you?
myates92 is offline   Reply With Quote
Old March 25th, 2021, 06:12 PM   #114
sorry...no, I don't.
Old March 25th, 2021, 06:19 PM   #115
myates92
myates92's Avatar
Ok, thanks.
Old March 26th, 2021, 12:37 PM   #116
another set of 500's knocked off today, multiple issues dealt with.
Old March 27th, 2021, 07:55 PM   #117
Refurbed and corrected faults found within these new gen 250's today.
All brass came out awesome, wet tested perfect, all should be a "go".
Old March 29th, 2021, 05:08 PM   #118
knocked off these 500 refurbs today, these my property, for sale
Old March 30th, 2021, 03:36 PM   #119
cool, windy ride on my SS800 this morning.
Old March 31st, 2021, 12:51 PM   #120
Red Max EB7001 blower dropped off today. To be serviced, picked up tomorrow, at which time something else will be dropped off.
Back to normal with my landscape contact.
[roadracingworld.com] - â??Racers Edge Performance Hosting Track Day/ Practice Day Ap Ninjette Newsbot Motorcycling News 0 March 25th, 2015 02:20 PM
