Old July 29th, 2023, 07:15 AM   #1
jagdge1
Question What is this thing? Broken part within alternator assembly? (Pics)
Hey there,
I just bought a new to me 2010 ninja 250. It had charging issues that I knew of, and I'm trying to fix it up. Replaced the stator and successfully got headlights working again. But I am concerned about the following, which I removed from being wrapped around the crankshaft behind the flywheel.
Pictures:
https://imgur.com/a/zVK6Ih6
Question: What is this sheared bolt, and what are these wires from?
edit:
Answer: the ignition pulser ( pickup coil ) got destroyed. ugh.
Last futzed with by jagdge1; July 29th, 2023 at 07:59 AM. Reason: found the answer
jagdge1 is offline   Reply With Quote
Old July 29th, 2023, 09:46 AM   #2
Yup!!! Good job tracking that down!
Best to use some blue Loctite threadlocker and torque-wrench on anything that attaches to engine. Otherwise, vibration shakes bolts loose and whatever's attached falls off.
Old July 29th, 2023, 10:39 AM   #3
jagdge1
Thanks for the info!
The JIS screws on the initial pulse igniter was gotcha #1.
when I replaced the stator (whose 3 yellow wires had been completely demolished, an easy drop in replacement), there was no spark.
gotcha #2:
I installed the pulse igniter with the magnetic side facing away from the rotor
gotcha #3:
I failed to install the JIS screws with blue lock tite when I had it facing the right way. The rotor caught the magnetic pickup head and all the wiring came along for the ride.
I must have installed and removed the alternator cover, and removed & added sealing gaskets, at least 5 times.
Through trial and error I found an easy way to take off the alternator / stator cover without damaging the mating surfaces:
There's one screw hole on the alternator / stator cover that does not mate with the body, that you can insert a lever ( i used a spoon ) to gently overcome the magnet and pop the cover off.
When the cover is on and facing the bike, front wheel to your left.. This screw mount is on the right most - I believe it's for the engine sprocket cover. When all the stator cover bolts are on, it's the only hole that won't have a screw in it. It's a great fulcrum point. I spent too much energy trying to remove the cover from the top tab, it looks too inviting.
[kropotkin thinks...] - Joan Mir Interview, Part 1: "The Most Difficult Thing Is The Ninjette Newsbot Motorcycling News 0 January 16th, 2020 03:38 AM
[crash.net - MotoGP] - PICS: Riders take part in â??Waterfallâ?? test Ninjette Newsbot Motorcycling News 0 July 10th, 2014 11:00 AM
Where to buy broken part from? Flawed Items Wanted 13 May 10th, 2013 03:25 PM
Fine throttle cable adjustment assembly broken. setasai 2008 - 2012 Ninja 250R Tech Talk 2 June 18th, 2011 09:10 PM
Skittles Pop Demand: thing on shoulder pics (loads) EngrNewf Off-Topic 20 August 5th, 2009 12:17 PM
