Old June 10th, 2013, 10:49 PM   #1
47ninja
Tail light and dash light both not working
I was riding back from work last night and noticed that my dash light was not working. I figured the bulb must have burnt out and put it on my to do list to check it when i got home. When I came to a red light after exiting the freeway, the car next to me told me my rear tail light was not working. Kind of freaked me out that I had ridden the whole time in the dark with no tail light. I got home and sure enough it was out. Does not light up even when using the brakes.
I'm not too familiar with the wiring, but from what I understand, the dash and tail lights are connected. I think the issue may have something to do with a set of screw bolt license plate lights I had previously installed on the bike, that I took off because the screws were not strong enough to secure the license plate. The wires were stripped as shown in the picture. These are really small incisions, but could this be causing the issue? And if so, will electric tape fix it? Thanks in advance for the help!
47ninja is offline   Reply With Quote
Old June 10th, 2013, 10:53 PM   #2
47ninja
Btw this is for a 2010 model...
Old June 11th, 2013, 07:41 AM   #3
Chicagobob
Chicagobob's Avatar
Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B
You probably blew a fuse. You should tape, or splice out, the butchered wires, anyhow.
Chicagobob is offline   Reply With Quote
Old June 11th, 2013, 08:07 AM   #4
It is possible that during removal of those extra lights, a short happened and the 10 Amp fuse #4 blew up.
I would check that fuse first and then the integrity of those cut wires and finally tape those.
The blue is for brake light only (+). It comes from both brake switches.
The red is for tail light (+). It comes from the ignition switch.
The black-yellow is ground (-). IT comes from the (-) of the battery.
See the attached electric diagram.
Old June 12th, 2013, 05:12 PM   #5
47ninja
Turns out that it was indeed a burnt out fuse. Swapped the bad one for a new one and now everthing is good! Thank you for the replies.
Rear tail light not working. Twitchy Stitch 1986 - 2007 Ninja 250R Tech Talk 2 November 2nd, 2014 07:47 PM
Tail Light + Brake Light Not Working (Bulb Replaced) JayZE302 2008 - 2012 Ninja 250R Tech Talk 11 August 8th, 2012 05:03 PM
Wire integrated tail light such that the brake light stays off while signal flashes? CZroe 2008 - 2012 Ninja 250R Tech Talk 6 March 4th, 2012 06:36 PM
WTB: Rear OEM 2008+ Ninja250 Tail Light/Brake Light FerociousNINJA Items Wanted 5 March 29th, 2010 08:52 AM
Tail Light Not Working Betlog 2008 - 2012 Ninja 250R Tech Talk 7 January 11th, 2010 07:01 AM
