Old December 30th, 2009, 09:08 AM   #1
whylee
Motorcycle(s): 2 2009 Ninja 250's Honda VTX 1800
Anyone removed left hand controls
I am setting up my bike for the track and have removed all lights and installed race plastic. I want to remove the switch controls on the left bar but I need to mount the choke lever somehow. Anyone have any ideas on mounting a choke lever, this bike will not start without it when cold.
whylee is offline   Reply With Quote
Old December 30th, 2009, 09:46 AM   #2
HKr1
IC2(SW)
HKr1's Avatar
Some bicycle shifter levers look kinda nice, think a few people have gone that way.
We always changed carbs, then had to reach down in there if the choke was needed.
Old December 30th, 2009, 12:33 PM   #3
whylee
I will look into the bicycle shifter idea
Old December 30th, 2009, 07:23 PM   #4
RaceBikeRentals
Pimpin
RaceBikeRentals's Avatar
Motorcycle(s): Bunch of em
Careful.... Production rules require those switches to be left in place.
-Richard
MotoList.com <<<List your stuff!
RaceBikeRentals is offline   Reply With Quote
Old January 1st, 2010, 01:27 AM   #5
whylee
Im sure the rules stated the headlight, turn signal and horn switch could be removed but the throttle and kill switch had to remain stock. That was from the AFM rule book.
Yep, just double checked the rules and it states you can remove the left handle bar switch controls. Maybe thats not for all clubs, but for AFM its legal.
But I am interested in a set of your rearsets for my bikes.
Old January 2nd, 2010, 04:41 PM   #6
ROADandTRACK
R&T Suspension
ROADandTRACK's Avatar
We run safety wire from the choke out to the left side of the bike w/ a rubber/aluminum grommet on the end of it. Use that to engage choke and then it will never get stuck on; and there is less on the left bar to have to mess w/ if you crash.
ROADandTRACK is offline   Reply With Quote
Old January 2nd, 2010, 06:12 PM   #7
whylee
So the choke is spring loaded, you dont have to push it in to disengage.
Old January 5th, 2010, 04:07 PM   #8
ROADandTRACK
R&T Suspension
nope
Old January 12th, 2010, 05:06 PM   #9
2WheelGuy
2WheelGuy's Avatar
Thumbs up
That is what I do except I use coat hanger wire and just bend a loop in the end to pull on.
AFM #278
Old August 25th, 2012, 10:15 AM   #10
CopperKid
Motorcycle(s): Cb750 supersport cafe, cb650 bobber, HD 1200 screaming eagle.
This video might come in handy for you left control removal.
CopperKid is offline   Reply With Quote
Old August 26th, 2012, 10:10 AM   #11
Rexbo
CVMA / AFM / M1GP #250
Rexbo's Avatar
Motorcycle(s): 2009 Ninja 250r, 2011 Zero S, 2009 KLR 650
or a brightly colored high-temp zip tie
Rexbo is offline   Reply With Quote
Old August 26th, 2012, 08:36 PM   #12
slolee
Motorcycle(s): 2009 Kawasaki ninja 250r (sold), 2008 Triumph speed triple, 2004 Suzuki SV650, Kawasaki 2006 kx65
removal of left hand controls. . .
I had FasterMotorSports in Denver set up my bike and we removed the left hand controls. They left me with the choke cable which I had to pull by hand. Very awkward and it wouldn't hold open because of the spring. I found a choke lever and mounted it on the stays for my windshield. Works great. Here is the info: I got it from Italy. 10.30 EU Easy to deal with. redracingparts.com
slolee is offline   Reply With Quote
Old August 26th, 2012, 10:43 PM   #13
htdub
Motorcycle(s): triumph
I did mine today. Been meaning to get around too it. Removed the controls, left the 2 wire connector for the clutch lever.
For the clutch cable, I ran a safety wire to the choke bracket, mine is spring loaded. Ran a bright blue zip tie to make a easy loop.
Pretty simple mod (idiot level for me), didn't have to remove the entire tank, just propped it up with a 2x4.
htdub is offline   Reply With Quote
Left handle bar controls change 87-07 MFNcody 1986 - 2007 Ninja 250R Tech Talk 4 September 5th, 2014 02:43 AM
Left handlebar controls on new gen? IF13 2008 - 2012 Ninja 250R Tech Talk 17 August 22nd, 2013 03:52 PM
[motorcycle-usa.com] - Kuryakyn Launches Kinetic Hand/Foot Controls Ninjette Newsbot Motorcycling News 0 April 26th, 2013 03:00 PM
left hand controls 95 bike 05 controls mapolley07 1986 - 2007 Ninja 250R Tech Talk 12 December 22nd, 2011 10:05 AM
[crash.net - MotoGP] - Elias has screws removed from hand, ankle Ninjette Newsbot Motorcycling News 0 December 1st, 2010 06:40 AM
