Old May 24th, 2013, 09:38 PM   #1
RandomPhantom
The Motorcycle Newb!
RandomPhantom's Avatar
Motorcycle(s): 2010 Ninja 250R (Red/SOLD), 2008 Ninja 250R (Black/SOLD), 2005 ZX6R (Black)
Overfilled Oil Sight Glass
Just got my 2010 Ninja 250r out of the shop for its valve adjustments and i noticed the bike leaking. Upon further inspection i found the leak to be from the oil filter housing case on its edge, not from the bolt. It appears to be tight as i cant tighten it any more. Then i leveled the bike and told my brother to check to oil sight glass and found that the entire sight glass is filled with oil. Is that the cause of the oil leak at the oil filter housing?
RandomPhantom is offline   Reply With Quote
Old May 24th, 2013, 09:41 PM   #2
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
probably pinched the oring on the filter housing. if you can do it yourself, get a clean container to catch the oil, remove filter housing, inspect/adjust/replace oring and reuse oil.
Old May 24th, 2013, 10:22 PM   #3
tubarney
take it back to the shop and throw the oil filter at the f**ker's head. Then take a big wrench and beat him with it.
Old May 24th, 2013, 11:13 PM   #4
kirk595x
kirk595x's Avatar
Motorcycle(s): 03' Ninja 250ex
Perform Random Acts of Coolness!!ATGATT
kirk595x is offline   Reply With Quote
Old May 25th, 2013, 04:27 AM   #5
ChaoSS
Motorcycle(s): 2012 red 250 ninja
Overfilling won't cause a leak there.
Take it back and ask them to fix the issue. The o ring is leaking, or wasn't installed properly.
ChaoSS is offline   Reply With Quote
Old May 25th, 2013, 04:29 AM   #6
Leak and excessive level are not inter-related.
If the shop changed oil, they shouldn't be in business.
Check the oil level before each ride; it should become a habit.
Old May 25th, 2013, 06:11 AM   #7
ChaoSS
I wouldn't go that far, making a mistake on a gasket isn't the end of the world now.
Oil level sight glass adouglas General Motorcycling Discussion 53 May 16th, 2013 02:30 PM
Oil sight glass BlueHairSar 1986 - 2007 Ninja 250R Tech Talk 20 December 13th, 2012 01:23 PM
Oil sight glass needed. jonnyc Items Wanted 1 August 12th, 2011 07:25 AM
Foamy Oil in Sight Glass??? ScorpionNinja 2008 - 2012 Ninja 250R Tech Talk 19 May 17th, 2010 07:00 PM
Oil Sight Glass empyrean 1986 - 2007 Ninja 250R Tech Talk 7 June 25th, 2009 10:25 AM
