Old June 29th, 2013, 12:10 AM   #1
KrazyWalle
KrazyWalle's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250R (Passion Red, Ca Model)
Need some advice...
So I need some advice.. I just installed my 15T sproket, and I like the bike feels good, i shift less and RPM's are not as high anymore, only issue is I feel like i needs more power in 6th gear... It feels like it needs a little more oomph.. I haven't rode much since the swap though. I have 2 shims on the needles, Area P exhaust, snorkel removed, and Iridium plugs. I was thinking about doing the pods. But from what I've read most people who put the pods on replace the needles, adjust the idle screws. Seems like a lot of fine tuning is needed.. Should i just put in the K&N replacement filter? Or get use to the new gearing? I don't really want decreased fuel economy and have to mess alot with fine tuning the carbs. Is swapping the jets really necessary with the pods or would I be able to get away with just two shims? The bikes finally running good how I have It set up right now.. Ill try riding it and get use to the new sprocket and take it from there. Just trying to get different opinions from people who have messed with replacing the stock filter and getting rid of the airbox. I also want to get rid of all the Ca emissions crap, but that's kind of irrelevant..
Anyways thanks in advance for any help or advice..
KrazyWalle is offline   Reply With Quote
Old June 29th, 2013, 04:25 AM   #2
tubarney
If you install pods you will need to change your jets. It can be a bit of a pain to get it right.
40 pilot,110 main.
Old June 29th, 2013, 06:00 AM   #3
DaBlue1
DaBlue1's Avatar
Originally Posted by KrazyWalle View Post
.... Should I just put in the K&N replacement filter? Or get use to the new gearing?
Pipercross Air Filter or Hurricane Racing Performance Air Filter are better IMO.
http://www.ninjette.org/wiki/Air_filters_for_newgens
A 15/43 sprocket set up has a good balance of acceleration and top end speed
Old June 30th, 2013, 08:02 PM   #4
KrazyWalle
KrazyWalle's Avatar
Thanks you guys, ill look into the other filters. And I do agree getting the carbs out was time consuming..
On another note i took her out for a long ride down the hwy, I managed to pull 105 indicated, with a annoying crosswind, going down a slight hill. It still had another 800-1000 rpm left but it just wouldn't go or i would reach an uphill... Overall pleased with the set-up, but in the end it's still a 250... So I can't cry over not enough power...
Need help and advice please? Kiid-_-Buru 2008 - 2012 Ninja 250R Tech Talk 7 January 17th, 2015 03:56 PM
I need your advice on this ad. RiderOnTheStorm General Motorcycling Discussion 14 October 4th, 2012 05:15 AM
Need Advice ryan.chin General Motorcycling Discussion 17 August 28th, 2012 08:25 PM
Could this be the one?!... Advice please Prime General Motorcycling Discussion 4 June 9th, 2011 02:39 PM
need some advice tinng321 Off-Topic 12 July 29th, 2009 06:44 AM
