Old September 13th, 2013, 03:07 AM   #1
boomer187um
Motorcycle(s): 2012 250R CLG
how to tell if this will fit??
https://www.denniskirk.com/k-and-s/l...prd/213801.sku
boomer187um is offline   Reply With Quote
Old September 13th, 2013, 06:26 AM   #2
PartsNinja
Ninja Parts Master
PartsNinja's Avatar
Motorcycle(s): 2011 Ducati Streetfighter 1098, 2014 Honda CB1100 Cafe, 2007 SV1000S, Quite a few 2008-2012 Ninja 250s
It wont fit on a Ninja 250 handle bar. You would need to get aftermarket clip ons such as Woodcrafts to mount that. You need a bar thats hollow in order to install the rubber bushing into. Stock handlebars have a threaded nut that allows you to mount the stock barends. Many other stock 7/8" bars ARE hollow though, so maybe they WILL work for you if you are talking about a bike other than a Ninja 250.
See my video here:
http://youtu.be/1khhRhv4_6c
At the end of the video where we hold the end of the bar towards the camera you can see what im talking about.
Add me on Instagram: @d_jalb Or follow me on eBay: PartsNinja
PartsNinja is offline   Reply With Quote
Old September 13th, 2013, 06:41 AM   #3
dooby
Motorcycle(s): '11 250R SE (FI), '14 Daytona 675, '14 Sprint 1050 GT SE
Yes, I found out about the welded-in nut to my disappointment when I tried to fit these Oberon indicators:
http://www.oberon-performance.com/ac...ndicators.html
My solution was to saw off the portion of the nut that protrudes past the end of the handlebar, then drill out the remainder of the nut to find the 19mm internal diameter pipe.
I then drilled a small (5mm?) hole in the underside of the pipe at the triple tree end for the wire to come out of.
It's possible, if you don't mind butchering your stock bars. It would be easier with clip-ons :-)
HTH, Pete
dooby is offline   Reply With Quote
Old September 13th, 2013, 09:27 AM   #4
boomer187um
thanks, i think i'll give it a shot
Old September 13th, 2013, 12:41 PM   #5
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
if you can't beat it in with a hammer then I say it's a no go
How do you know the right fit? NinjaCowgirl Motorcycle Gear 21 January 10th, 2014 05:30 PM
Do these mirrors fit? quarterliter 1986 - 2007 Ninja 250R Farkles 13 May 12th, 2013 04:08 PM
Lower Cowling... To Fit or Not To Fit? darqyn 2008 - 2012 Ninja 250R Farkles 4 April 11th, 2012 05:56 AM
how should your gear fit? massacremasses Motorcycle Gear 2 September 15th, 2011 06:46 PM
How to Fit a Helmet kkim Motorcycle Gear 1 January 20th, 2010 01:24 AM
