November 6th, 2013, 05:10 PM | #1 |
Join Date: Aug 2013 Motorcycle(s): CRF450X, CRF250R/SM, Husky 630 SMS, Ninja 250R Posts: 144
Lower profile clipons
I'd like to mount clipons above the triple, and don't want to use riser type setup (like Woodcraft). Vortex seem to have a very low profile clamps, about 13mm-20mm ... is this the best option? Other versions floating around are as tall as 40mm with two bolts, no way I can slide the fork up that much.
November 6th, 2013, 05:21 PM | #2 |
the problem with those types of clipons is that they hit the bodywork on the side. so you either have to cut bodywork lower or run naked
November 6th, 2013, 05:59 PM | #3 |
Bodywork will be cut to fit, not a problem with race glass.
Profile Picture | THE BIG SITT | Help | 1 | December 30th, 2011 04:13 PM |
for the ones with clipons???? | mike_sema | 2008 - 2012 Ninja 250R Tech Talk | 13 | September 8th, 2009 07:35 PM |
Profile Picture | HA-Y-N NINJA | Off-Topic | 4 | August 12th, 2009 06:39 PM |
Profile | mikedabike64 | Help | 1 | June 26th, 2009 12:01 PM |
