Old March 23rd, 2014, 08:58 AM   #1
bannr35
Motorcycle(s): kawasaki ninja 250r
rear turn signals
hello everyone
im a female just started riding kawasaki ninja 250r . i want to be able to learn atleast to do little maintenance on my bike. i tried changing rear turn signals i ordered them online not knowing about LED so i did change them and they would not blink after changing so then i found out about relay so i changed relay and they blink now but blink like hazards so found out online about diode kit so i ordered and installed diode fit ok now with changed electric relay and diode kit one light right light blinks normal but when turn left blink on it blinks both lights like hazards and also the green indicator light on dash does not work at all. please please help.
bannr35 is offline   Reply With Quote
Old March 23rd, 2014, 09:07 AM   #2
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Welcome!
In 5 minutes, you'll get all kinds of advice. Something about adding a diode in the circuit.
Old March 23rd, 2014, 09:13 AM   #3
bannr35
ok
i already did diode kit
Old March 23rd, 2014, 09:15 AM   #4
dcj13
Participant
dcj13's Avatar
Are the diodes (added into the circuit and LEDs in turn signals) all wired up so the current flows in the correct direction?
(I'll step aside, as I run old-fashioned filament bulbs in all my vehicles, but look forward to the ensuing discussion and advice).
Old March 23rd, 2014, 09:20 AM   #5
bannr35
lol lost me
i connected diode kit same as video showed on this site removed i think the green wire place in the diode kit wire then connected all wires basically
Old March 23rd, 2014, 09:24 AM   #6
bannr35
i used this video
http://www.ninjette.org/forums/showp...17&postcount=1
Old March 23rd, 2014, 09:31 AM   #7
bannr35
i used this video
Old March 23rd, 2014, 10:37 AM   #8
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
That's @CThunder-blue's video so I'm presuming you bought thr diode off modmy250.com?
Are the front lights also LEDs?
Which relay did you buy (brand and number)?
I can't help much on the specific problem but maybe knowing some more details can help those who are cleverer than me.
<-- Linky
Old March 23rd, 2014, 10:42 AM   #9
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
I am unable to view the video, but can say that cutting wires and making new connections in the wiring under the cluster is required for the diode modification to work. Was this kind of work shown in the video?
Old March 23rd, 2014, 12:46 PM   #10
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
No. My kit does not require cutting any wires. I check all my diode kits before shipping. What kind of relay did you buy?
The www.ModMy250.com guy
Old March 23rd, 2014, 02:08 PM   #11
FrugalNinja250
I use a solid-state fixed-rate relay, or flasher module, that I got from CycleGear. However, that has nothing to do with your problem.
The Ninja turn signal circuit is really simple. Power goes to the flasher relay, from there it goes to the switch. From the switch it goes to whichever side is selected, left or right. From there, power goes to ground and back to the negative side of the battery. What cases flash rate problems is the flasher relay, or module. LEDs draw far less current than incandescent filament-style bulbs, and the way the module is designed the rate of flash is dependent on the power drawn by the bulbs.
Problems with four-way flashing are caused by the way Kawasaki wired the cluster flash indicator bulb. That bulb is simply connected from the right side circuit to the left side circuit. Whenever one side is flashing, power from that side travels to the cluster bulb, and from there to the off side where it goes through the off-side bulb filaments and to ground. Since the cluster bulb draws almost no power, not enough current can flow through it to light the off-side filaments even though that power is going through the filament. Think of the cluster bulb acting like a voltage restriction.
In order for any diode kit to work, it must do one thing at a minimum: It must isolate the left and right side circuits. That involves cutting wires, because you must take on of the cluster bulb wires and connect it to ground, and you must take the left and right circuit wires and connect them to the other side of the cluster bulb. The new circuit would have each side, whichever side was active, sending power through a diode to one side of the cluster bulb, and the power would leave the bulb on the other side and go to ground.
It's a really simple modification to do.
AFAIK, there is no "plug-in" solution to deal with the cluster bulb/four-way flash problem.
Old March 23rd, 2014, 02:17 PM   #12
/moved to new-gen tech
Old March 23rd, 2014, 03:02 PM   #13
CThunder-blue
ModMy250.com
Sorry, but I beg to differ. I've been selling a no-cut diode kit for 2 years for the 08-12 ninja 250R.
Old March 23rd, 2014, 03:04 PM   #14
kennetht
kennetht's Avatar
Agreed. I purchased my diode kit from him, and I did not have to cut any wires at all whatsoever.
Best, and easiest install.
kennetht is offline   Reply With Quote
Old March 23rd, 2014, 04:23 PM   #15
FrugalNinja250
Post a schematic of what you did, I'm always interested in new ideas.
Old March 23rd, 2014, 06:11 PM   #16
CThunder-blue
ModMy250.com
watching the video will give you an idea of what I did.
Old March 23rd, 2014, 06:30 PM   #17
CThunder-blue
ModMy250.com
So, did you installed the blue wire in the connector that the green wire came out of? Can you pm me your paypal address so I can see who you are? I can send you another kit to test in case one of the diodes is not working right.
Old March 23rd, 2014, 07:03 PM   #18
FrugalNinja250
I can't watch videos due to technical limitations at my end. Do you have a schematic you can post?
Old March 23rd, 2014, 07:09 PM   #19
ForceofWill
Blind 250 Loving Whore
ForceofWill's Avatar
Tri did all the work to figure the solution out and produce a plug and play kit. I wouldn't blame him if he didn't post a schematic.
Old March 23rd, 2014, 07:35 PM   #20
bannr35
i bought
EP 34. ELECTRIC RELAY front lights not led
Old March 23rd, 2014, 07:42 PM   #21
bannr35
the diode kit i got
2008-2012*Kawasaki Ninja 250R*EX250 No-CutDiode Kit*: Amazon*
Old March 23rd, 2014, 07:45 PM   #22
bannr35
C thunder blue
i follow steps to a T . will send you my pay pal name
Old March 23rd, 2014, 07:50 PM   #23
ForceofWill
If you bought the custom led kit you should contact them.
Old March 23rd, 2014, 09:16 PM   #24
CThunder-blue
ModMy250.com
Oh, you bought from CustomLED, not me. Although they sell the same kit, it might have been a faulty kit. I would suspect one of the diodes is either not working, or facing the wrong direction.
Old March 23rd, 2014, 09:25 PM   #25
CThunder-blue
ModMy250.com
The link above isn't a video as the OP suggested. It's a link to my DIY page on this forum. Basically, what I did was trace back the two leads coming off the bulb connector. One lead ends up in a 9 pin harness and the other is in a 3 pin harness. The 3 pin harness has only 2 used connections. As my instructions go, you take out the 1 lead in the 9 pin harness and insert it into the 3 pin harness on the bike. My kit, which includes diodes, then connects between the leads and harnesses. It also includes a ground wire. Hope that clears it up. If you read that link above, it has pics and you'll probably get a better idea.
Old March 24th, 2014, 09:27 AM   #26
bannr35
Thanks you guys
problem not completely solve yet but i email where i got diode kit they gave me number to call he said he never sold a defective kit before so he help me trouble shoot took off the 3 pin connector blinkers work fine except green indicator on dash. so he said something maybe backwards like you said so he is going to mail me another kit. so will see if that works. Thanks will post again after install new kit..
Old March 24th, 2014, 10:59 AM   #27
FrugalNinja250
Ah, so it does isolate the left and right sides, but does it at connectors elsewhere in the harness. Nice and elegant, that's a good way to do it.
Thanks for the information! I'm not planning on doing mine that way as I'm a DIYer who loves hacking into harnesses and modifying things for fun. Mine I'll do up in the cluster wiring.
Old March 24th, 2014, 04:30 PM   #28
linkinpark9812
Motorcycle(s): Black 2012 Ninja 250R
It actually is done up at the cluster wiring. Its right where the cluster plugs into the main harness of the system. Actually quite clean looking too since it uses stock connectors in between.
linkinpark9812 is offline   Reply With Quote
Old March 24th, 2014, 07:52 PM   #29
CThunder-blue
ModMy250.com
I think he meant where the harness plugs into the gauge cluster.
Looking for 09 oem rear turn signal and front turn signals and tail fairings mbbernas Items Wanted 1 September 11th, 2013 10:48 AM
Rear turn signals don't blink, front turn signals don't turn on andyuc88 2008 - 2012 Ninja 250R Tech Talk 3 March 23rd, 2012 02:47 PM
Rear Turn Signals gogiburn 1986 - 2007 Ninja 250R Tech Talk 0 July 8th, 2010 06:59 AM
