Old December 23rd, 2014, 06:23 AM   #1
Linkin
Down Under
Linkin's Avatar
Motorcycle(s): Kawasaki ZXR250C Ninja
Has anyone done a starter motor change? (Update: I changed it out)
As in title. Mine isn't cranking (have to clutch start all the damned time!) and I have a starter motor from a '11 model to fit to my '08.
From what I can see it's held in place with 2 bolts. Should just be a matter of undoing those and the cable to the solenoid.
If anyone here has removed their starter motor please let me know if you ran into any trouble getting it off or back on.
Thanks.
Last futzed with by Linkin; December 26th, 2014 at 09:29 PM.
Linkin is offline   Reply With Quote
Old December 23rd, 2014, 06:40 AM   #2
garth285
KAWASAKI GURU
garth285's Avatar
Starters normally take a little extra effort to get them back in the hole. I suggest cleaning the o-rings on the end of the starter and then putting a nice thin layer of grease on them to help it sit right back in.
Also I have had issues when installing a starter and it just wont budge.... sometimes the teeth are lined directly up with the starter clutch gear that it wont fall into place, if that happens just pull it back out and with your hands turn the gear on the starter a little and try again.
Patience is always the key when working on motorcycles :-)
Old December 23rd, 2014, 07:21 AM   #3
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Definitly clean the area with compressed air. Dirt and rocks settle under the starter. When you remove the bolts the starter needs to move toward the right side of the bike befor moving up at all. The rocks can hold it in place.
Also once the starter is out the hole is right there leading to the inside of the engine. That is one place you don't want rocks to fall into.
Did you try jumping the starter solinoid?
Worlds fastest 250 ninja
Old December 23rd, 2014, 09:45 AM   #4
cuong-nutz
cuong-nutz's Avatar
Check the fuse?
HalfFast Racing Team
Old December 26th, 2014, 09:28 PM   #5
Linkin
Down Under
Linkin's Avatar
Today has been a productive day. I've replaced the starter motor with a new one. The old one is well and truly cactus, I'd say. It doesn't feel anything like the new one when hand turning. The new one also doesn't spin/crank when you cut the ignition, the old one did. Free spinning or something.
It took me 3 hours to do the work. Real bastard of a spot! Hmmm.... bastard motor!?
There was lots of crap underneath the starter because I park outside...
Also had to take this thing on the left off to actually remove the starter
Old December 31st, 2014, 08:17 AM   #6
Foxrider64
Hello Moto
Foxrider64's Avatar
Motorcycle(s): 1975 RD350; 2001 KX125; 2003 Z1000; 2003 KDX50; 2009 ZX6R; 2011 Ninja 250R; 2014 KX250F
Cam Chain tensioner?!
You shouldn't have needed to remove that- it's kind of a really important part. Please put it back in carefully and do not turn the big, middle bolt.
Foxrider64 is offline   Reply With Quote
Old December 31st, 2014, 11:36 AM   #7
krolinked
Nerd
krolinked's Avatar
You need to reset that cam chain tensioner as your putting it in!
Look up how to reset it because you will ruin something if you simply try to put it back in as it is right now!
Old December 31st, 2014, 11:37 AM   #8
krolinked
Nerd
krolinked's Avatar
I use a flathead screw driver from a glasses repair kit. It's the only thing that seems to fit.
Old December 31st, 2014, 08:52 PM   #9
Linkin
Down Under
Linkin's Avatar
Ummm... CCT went back in fine, I didn't mess with the middle screw. Bike runs fine
Old December 31st, 2014, 08:55 PM   #10
garth285
KAWASAKI GURU
garth285's Avatar
Your lucky the bike didn't jump timing. Not a smart thing to do!
Old December 31st, 2014, 10:12 PM   #11
Linkin
Down Under
Linkin's Avatar
I did RTFM regarding the CCT though, I know how to put it back in and keep the timing
Starter motor GREY NINJA 1986 - 2007 Ninja 250R Tech Talk 47 July 12th, 2013 01:29 AM
Starter motor clutch drphils87 2008 - 2012 Ninja 250R Tech Talk 3 June 21st, 2013 04:39 PM
replacing starter motor deanomyte 1986 - 2007 Ninja 250R Tech Talk 4 June 20th, 2013 06:22 PM
Starter motor Boom King 2008 - 2012 Ninja 250R Tech Talk 2 October 8th, 2012 05:03 PM
