Old May 19th, 2015, 01:11 PM   #1
Xata27
Xata27's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250R
Doesn't Want To Run
So the story is I decided to put in a gallon of gas into my Ninja and it ran okay for a little bit. All of a sudden it just died out of the blue. Now it will only want to run if the choke is on all the way and even then if you pull on the throttle just a little bit the bike dies. It does run but only if the choke is on and you're in neutral.
Could there be water in the tank or is this another issue?
Xata27 is offline   Reply With Quote
Old May 19th, 2015, 02:15 PM   #2
spooph
spooph's Avatar
Motorcycle(s): '08 Ninja 250R
MOTM - Oct '15
was the tank partially full, or completely dry when you put in 1 gal of gas? Has it been sitting for a while?
Old May 19th, 2015, 02:59 PM   #3
Xata27
Xata27's Avatar
The tank was almost empty.
Old May 20th, 2015, 08:02 AM   #4
spooph
spooph's Avatar
MOTM - Oct '15
has it been sitting for a while?
Old May 20th, 2015, 08:14 AM   #5
Xata27
Xata27's Avatar
It was sitting for two days since it last ran.
Old May 20th, 2015, 08:19 AM   #6
spooph
spooph's Avatar
MOTM - Oct '15
How long will it run like that?
If you leave the choke on, does the idle eventually get faster? Say, after 3-5 min of idling?
I assume the bike was ridden 2 days ago and everything was operating as normal? or was it just able to idle and wasn't being ridden?
Have you checked all of the fluids? Oil, coolant?
Could you provide a video?
Where in Colorado are you?
Old May 20th, 2015, 09:20 AM   #7
Was there a truck supplying fuel to the gas station's tanks when you were putting gas?
Other than refilling the tank, what work has been done to the bike lately?
Old May 20th, 2015, 10:51 AM   #8
I would start by completely draining the tank and emptying the floatbowls - catching the gas to see what comes out.
Refill with fresh 87 octane (without ethanol if possible) or the lowest grade you can get without ethanol (sometimes that's Premium). I'd add 1oz per gal of Techron Concentrate fuel system cleaner to the fresh gas.
Once you've done that you can cross off any possible fuel-related issues from the list and move on.
If you have bad gas, or water in the gas, no amount of other work you do will make it run right.
It's the most basic thing to do before starting any significant troubleshooting.
Also check the airbox snorkel for obstructions and the condition of the air filter.
If the idle mixture screws are accessible (caps removed) check that they are set to 2 1/2 turns out (base) and set the idle (once it's running and warmed-up) to 1300. Once it's running fairly decent I would also sync the carbs.
Old May 21st, 2015, 05:28 PM   #9
Xata27
Xata27's Avatar
I believe I figured it out. There was water in my gas tank and in the carburetor. I drained it and ran it several times. Now the bike runs a lot better. There is this strange whistling sound now though. Its sounds almost like a high pitched: "whip wheep wheep wheep wheep" sound. Not a constant whistling.
Old May 21st, 2015, 06:38 PM   #10
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
Is the sound only after you've done run the bike?
Old May 21st, 2015, 09:45 PM   #11
Xata27
Xata27's Avatar
Yes, only after the bike runs.
Old May 22nd, 2015, 03:32 AM   #12
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
This is almost always a pressurization issue that is prevelant with these bikes. Nothing damaging or catastrophic, just your Ninja singing to you. There is a gas cap modification you do to alleviate and reduce it. Check the DIY or search. Involves drilling an existing hole slightly larger. Something to check to be sure it's only this is to make sure all vacuum and fuel lines are routed in such a way that doesn't pinch them.
Old May 22nd, 2015, 08:11 AM   #13
spooph
spooph's Avatar
MOTM - Oct '15
Nice! Glad you got it figured out! And yea, the whistling is the Kawi tea kettle - nothing to worry about.
[motorcyclemonster] - Garberville, CA - Kiwanis Pre-Redwood Run Poker Run May 17, 201 Ninjette Newsbot Motorcycling News 0 April 28th, 2014 02:10 PM
[hell for leather] - What happens when you run from the cops and run out of gas Ninjette Newsbot Motorcycling News 0 December 11th, 2012 08:10 PM
[faster and faster] - EBR1190RS doesn’t have traction control, doesn’t need it Ninjette Newsbot Motorcycling News 0 November 3rd, 2011 02:10 AM
Bike doesn't run properly after sitting only 2-3 days shiftdrift06 1986 - 2007 Ninja 250R Tech Talk 15 April 23rd, 2011 05:06 PM
another one that doesn't start ride2rideagain 2008 - 2012 Ninja 250R Tech Talk 25 April 15th, 2011 01:19 AM
