Old December 21st, 2021, 02:42 PM   #1
john pierson
john pierson's Avatar
Motorcycle(s): '00 SV650,'02 EX250,'15 EX300
Chinese gaskets
As I'm a frugal (cheap?) old Norwegian the $40-$70 cost of a valve cover gasket put me off. Of course Ebay saved the day w a $21 price. It arrived and I discovered some issues. It is flat surfaced rather than having the sealing ridges molded in and the lower edges that go over the sides of the head have no cutouts. This is no biggie as I'm a retired mechanic. With a little trimming and a coating of sealer I'm not worried about leaks. GJ
GUZZI JOHN
john pierson is offline   Reply With Quote
Old December 21st, 2021, 02:57 PM   #2
Of course the advantage of the Kawasaki version is that it seals without sealer, and can be reused many times when doing valve adjustments without having to clean the sealer off each time.
Old December 21st, 2021, 06:21 PM   #3
shspvr
Motorcycle(s): 07 Kawasaki Ninja 250
I never had that problem and rebuild many motors even hop-up big bore
shspvr is offline   Reply With Quote
Old December 21st, 2021, 06:26 PM   #4
shspvr
Sound like a reject part that end up hand eBay seller this not uncommon in most case the part can still be useable
Old December 24th, 2021, 03:14 PM   #5
BoBO
BoBO's Avatar
Motorcycle(s): SC28 Fireblade
If it works it works, glad you saved some money.
94 900RR
04 BMW Z4 2.5 M Package
01 R170 AMG Sport Package
BoBO is offline   Reply With Quote
Old December 25th, 2021, 03:02 AM   #6
Regardless of origin, I put tiny bit of FIPG sealant (Toyota, Yamabond-3, Permatex Grey) on flat mating surface and nothing on grooved side. Found this allows to remove and re-install cover without ripping gasket off or apart. Goes back together easily without leaks.
Engine gaskets 94droptop 1986 - 2007 Ninja 250R Tech Talk 12 February 6th, 2018 12:39 PM
Gaskets The_big_dill 1986 - 2007 Ninja 250R Tech Talk 10 November 6th, 2013 06:27 AM
Make your own gaskets cuong-nutz General Motorcycling Discussion 4 October 11th, 2013 03:09 PM
Petcock gaskets? MasterCylinder 1986 - 2007 Ninja 250R Tech Talk 15 September 12th, 2013 06:02 AM
Chinese Motorcycle Purse Snatchers vs Chinese Mob akima Videos 10 May 23rd, 2012 09:34 AM
