April 10th, 2017, 07:28 PM | #1 |
Son in law will be along shortly.
My son in law is stationed in Grands Forks. Wanted a bike since I met him. Well after his last deployment my daughter relented and he got ninja 250. Don't know much about it. I have and have had a zrx 1200.
Got text this afternoon. Sounds like idle jet is clogging up. We will start trying to do this long distance. Talk to guys soon. |
April 10th, 2017, 07:31 PM | #2 |
Hello and welcome to you and to your son in law. Tell him congratulations on the new bike and we thank him for his service.
April 10th, 2017, 11:13 PM | #3 |
hey sounds like the son-in-law can't be TOO bad, right?
jets on these carbs are a little b#%$h. poke em all the way through with some wire and get it nice and clean.
April 11th, 2017, 04:11 AM | #4 |
He might try the non-invasive route first, if only because it's less hassle and who knows... it might work.
Head down to the local Pepzone Advance Boys Auto Parts and pick up some Chevron Techron fuel system cleaner. Use as directed and see if the system de-gums itself. Can't hurt, right? PS: If he does get to the point of disassembling the carbs and poking the jets, better to use a copper wire so as not to scratch things.
April 11th, 2017, 05:29 AM | #5 |
I am very pleased with them. Wish they were somewhere else. 7 years in the NODAK is a bit much. Though it did get them close for my daughters college years.
I suggested Berrymens B-12 in the fuel run 10 min and let sit until he gets to it this weekend. Then I suggested a wire off of a wire brush. As that fits well in the ZRX idle jets. In my mind I am doing math ... 1200cc divided by 4 = 300cc which should equal wire from brush bought at Wal-Mart. Thanks for the welcome guys. |
April 11th, 2017, 05:58 AM | #6 |
Join Date: Feb 2016 Motorcycle(s): 2007 ninja 250, 14 ninja 300, 09 1125CR Posts: A lot.
MOTM - May '17
welcome
April 11th, 2017, 07:02 AM | #7 |
MOTM - Sep '14
Alan
Keep calm and ride on -Motofool Never quit on a rainy day -ally99 |
April 11th, 2017, 07:32 AM | #8 | |
FYI the stock pilot jet in a Ninjette is a Keihin #38, which AFAIK means the orifice is 0.38 mm in diameter, or about 0.015 inch in old money. Dial calipers are cheap and easy to find at your local Home Lowe Tractor Ace Depot Supply store.
April 11th, 2017, 07:54 AM | #9 |
I like to use one or more strands from electrical hookup wire. One for very small openings, and several twisted strands for larger openings.
April 11th, 2017, 10:29 AM | #10 | |
Join Date: Apr 2014 Motorcycle(s): 1978 Z1R, 1999 EX250 Posts: A lot.
MOTY - 2018, MOTM - Oct '16
It's not just the jets that get plugged, but also the passage under (on top of) the jet. That's where mine gave me the most problems, that crap was in there like mortar.
April 11th, 2017, 05:13 PM | #11 |
Steel guitar strings can be sourced by the thousandth of an inch and work great to clear clogged pilot jets (but not the transfer ports) Do your math to calculate size required...
Ask any guitar player...for example..the posted .015" will be a "B" (second) string The #38 Keihin is .38mm= .0149".....I'd suggest stick with a .014" string (a fourteen in guitar speak) followed by carb spray bath and compressed air. I'd dissuade going larger. Guitar strings, sold by the set (6 strings) are commonly identified by size of the top "E" string....twelves (.012") thirteens are considered thick, by guitar standards usually used with acoustic guitars. Individual strings, sold by size, should also be available at your local music store. Hot tip....boil the pilot jets before "poking" to soften the clog. Another hot tip...using the right chemicals...heated ultrasonic is another highly effective method to clearing pilots AND the invisible, unreachable ports. Another hot tip...don't force oversized, unidentified wire into the jets...avoid "hogging them out" Know what size you are supposed to be jammin' in there....no larger. Brass before and after...YES they are from the same owner, same EX500 carb set I did 2016. No tricks, just effort.
April 13th, 2017, 03:46 PM | #12 |
sammich maker
MOTM - Apr '15
Welcome
https://www.brocksperformance.com/VZ...0035+C450.aspx |
[crash.net - MotoGP] - Iannone hoping to get lab Ducati 'shortly' | Ninjette Newsbot | Motorcycling News | 0 | June 26th, 2013 10:10 AM |
[topix.net] - France: ATGATT Shortly Mandatory? | Ninjette Newsbot | General Motorcycling Discussion | 7 | February 22nd, 2013 07:05 AM |
Please hold. We'll be with you shortly... | fyv0h | 2008 - 2012 Ninja 250R Tech Talk | 8 | June 11th, 2011 01:31 PM |
[kropotkin thinks...] - MotoGP Valencia Day 2 Test Times, Shortly After Noon | Ninjette Newsbot | Motorcycling News | 0 | November 10th, 2010 04:50 AM |
[kropotkin thinks...] - MotoGP Valencia Day 1 Test Times, Shortly After 2PM | Ninjette Newsbot | Motorcycling News | 0 | November 9th, 2010 07:00 AM |
