Old April 28th, 2015, 05:11 PM   #1
sreisig1
sreisig1's Avatar
2009 Ninja 250 Won't Start, oil change smelled like gasoline
Ok. So I did an oil change and changed the oil filter on my and my wife's 250's. Oil change went smoothly on my bike. When I did the oil change on my wife's bike, the oil came out very thinned out and smelled strongly of gasoline. I replaced the oil filter and put in some new oil. Started the bike up and ran for 5 minutes and it was fine. Two days later it kind of smells like gasoline in my garage and went to start up her bike and it won't kick over and makes a loud noise. Anyone know what could be wrong. It's been one problem after the next with this bike. Bike stalled a couple weeks back and we thought it was due to the battery. Replaced the battery and bike was running fine, but now this issue, so guessing it was this issue all along. Going to try and find a mechanic but idk how to even get the bike there.
sreisig1 is offline   Reply With Quote
Old April 28th, 2015, 08:58 PM   #2
Originally Posted by sreisig1 View Post
............. Two days later it kind of smells like gasoline in my garage and went to start up her bike and it won't kick over and makes a loud noise. Anyone know what could be wrong.........
When the float valves and petcock leak, fuel can slowly overflow the carburetors and flow into the admission valves into the cylinder and down into the oil in the crankcase.
As the oil is contaminated, its lubricating properties are diminished and you could damage the engine very much if keep working with that oil.
Ask your mechanic to verify those two elements against fuel leak when the engine is off and the bike is parked.
Old April 29th, 2015, 04:21 AM   #3
sreisig1
sreisig1's Avatar
Well the new oil in the bike hasn't been run that long and the new oil shouldn't be gas contaminated so soon should it?
It's the old oil that I changed out that was run in the bike for god knows how long. Bike started up fine with new oil, but two days later now it won't. So you think the old oil damaged the engine? But why not work now just two days after adding new oil. It was working with the old gasoline smelling oil, I wouldn't have even known unless I did the oil change to find it. Probably was just an issue waiting to happen I guess?
Old April 29th, 2015, 04:45 AM   #4
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
How many miles on bike?
I say do a simple check of the petcock. Yank off those two little hoses from the petcock and leave it in the "on" position to see if any gas drips out of it.
Riding it like I financed it.
Old April 29th, 2015, 05:12 AM   #5
sreisig1
sreisig1's Avatar
Best way I can describe the sound is it sounds like something is hitting or clanking into something else.
Old April 29th, 2015, 05:22 AM   #6
sreisig1
sreisig1's Avatar
Like 5,200 miles
Old April 29th, 2015, 09:07 AM   #7
accumack
accumack's Avatar
Motorcycle(s): honda crf230l & 2013 ninja 300se wife has Honda crf230l & honda cbr250r repsol
Hopefully gas didn't run down into the cylinder and cause a hydraulic lock damaging the piston and rod. Liquid does not compress. Trailer it to the mechanic.
accumack is offline   Reply With Quote
Old April 29th, 2015, 10:25 AM   #8
Ghostt
Ghostt's Avatar
Test the Petcock for proper operation, then turn your attention to the carburetors, New float valves for sure, for your carburetor needs PM @ducatiman
year of bike? History, modifications? Maintenance schedule?
violente et ignorantia
ZX-2R BLOG
Old April 29th, 2015, 01:58 PM   #9
cookiebug79
n00b with the b00bs
cookiebug79's Avatar
Motorcycle(s): 2007 EX250, 2008 EX250, 2001 ZR-7S, 2010 ZX-6R
If the float in the carb is stuck, gas can slowly leak into your engine. It can happen over the course of a few days or as fast as a few hours, meaning that the new oil might already have gas in it. Is the fuel level lower than it was when you did the oil change?
If gas leaked into the cylinder, you can try:
1. removing the tank
2. removing the spark plugs
3. put the bike in gear
4. roll the bike forward and see if gas shoots out of the spark plug holes
This will prevent it from hydrolocking.
cookiebug79 is offline   Reply With Quote
Old April 29th, 2015, 03:16 PM   #10
Only you can determine what is going on regarding contamination of the old and new oil charges.
Again, it is never good to have fuel mixed with the oil that lubricates both your engine and your transmission, because oil dissolves in gasoline and gasoline is not a lubricant.
The old oil could have been good for long time and contamination could have started just recently before the oil change, who knows.
Now that you have mentioned engine noise, you need to determine what is the source, which could be a bigger problem than the presumable fuel leak into the oil.
Hopefully it is nothing major, in which case, your next step would be testing the petcock and the float valves in order to verify if fuel has actually been leaking down.
Old May 26th, 2015, 08:54 AM   #11
sreisig1
sreisig1's Avatar
Well, I had a mechanic look at it. Couldn't find anything wrong with it. I had him clean the crabs and sync them. Bike seems to be running fine and haven't had any issues in the past couple weeks. Thank you all for all your help and quick responses.
Old May 26th, 2015, 09:17 AM   #12
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Is the bike red by any chance? My friend purchased and sold a 2009 in South Jersey within the same month because he complained about making the garage smell like gasoline. He too, took it to a shop and they said nothing was wrong with it.
Old May 26th, 2015, 09:20 AM   #13
sreisig1
sreisig1's Avatar
No, it is blue.
2009 ninja 250r won't start jpiz224 2008 - 2012 Ninja 250R Tech Talk 7 February 23rd, 2015 06:35 AM
05 Ninja 250 won't start on its own - help! AmyF 1986 - 2007 Ninja 250R Tech Talk 59 July 8th, 2014 11:46 AM
Ninja 250 won't start! please help me! Black knight 2008 - 2012 Ninja 250R Tech Talk 4 May 23rd, 2013 03:22 PM
2001 Ninja 250 - Won't start AGFE0914 1986 - 2007 Ninja 250R Tech Talk 28 April 11th, 2013 06:09 PM
06 ninja 250 won't start wolfpuss 1986 - 2007 Ninja 250R Tech Talk 7 February 21st, 2012 05:57 PM
