June 19th, 2020, 04:10 PM | #1 |
Join Date: Jun 2020 Motorcycle(s): 1999 Kawasaki Ninja EX250 Posts: 39
WANTED Fairing, air box cover and strap, OEM tool kit.....
I have a 1999 Ninja 250 and I'm looking for the upper Fairing with turn signals, the cover for the air box and the strap that holds it closed. The OEM tool kit and I know this is a long shot a matching set of keys and all the locks, gas cap and ignition switch. I really only need a gas cap cause the key works for everything else. The gas cap doesn't lock and the key doesn't fit. Also need the brake foot lever. I could probably find some of this stuff on eBay or something but I would rather see if someone here has what I'm looking for.
June 21st, 2020, 03:26 PM | #2 |
I may have upper-fairing and tun-signals for you. Yellow OK?
Cover for airbox... The cap with two tubes? If key doesn't even fit, it's most likely aftermarket cap. Get OEM cap and you can re-do wafers s inside to match existing key. Or any locksmith can do it for ~$50. |
June 21st, 2020, 03:41 PM | #3 |
COOL!! Yeah yellow is fine. I'm planning on painting my bike anyways. Do you think I need a new air box cover because I think the PO had a K&N cause the cover is cut in the inside and it looks like that is what holds the air filter in?? The gas cap was drilled out by the PO so I don't think I'll be able to get a key made.
July 11th, 2020, 04:15 PM | #4 |
Join Date: Jul 2020 Motorcycle(s): 1999 Ninja 250 Posts: 43
If you are still interested I have the upper fairing in green. Has a crack by the turn signal and missing one lower tab but paint still shines on it and has all decals. I am in the process of parting out a 99 and have the air box cover as well. My ignition is keyed different than the gas cap and other locks so can't help you there. I do have the brake foot pedal as well of great shape.
If interested, I also have a Muzzy 2:1 full exhaust. Pipes are in great shape and can has some scuffs and scratches but not too bad. If interested or if you need anything else, PM me. I have pics and lots of parts. |
July 12th, 2020, 08:27 AM | #5 |
Here is the lower fairing pictures you asked about. There is a small area deformed from the heat of the Muzzy which previous owner never modified to accommodate.
July 12th, 2020, 08:29 AM | #6 |
Here are pictures of the gas tank, gas cap, and other lock sets you asked about. All are keyed to the same key.
July 12th, 2020, 08:31 AM | #7 |
Here are pictures of the petcock, front turn signals, and airbox you asked about.
'04 Tool kit box | Guaire | 1986 - 2007 Ninja 250R Tech Talk | 3 | January 13th, 2019 12:22 PM |
My replacement airfilter cover/ battery box Strap | burnrich | 1986 - 2007 Ninja 250R Tech Talk | 2 | June 23rd, 2014 02:32 AM |
