August 23rd, 2010, 05:40 PM | #1 |
Join Date: Mar 2010 Motorcycle(s): 09' Blue Ninja 250R and 07' Honda 919 Posts: 605
Oil Change
Changed the oil today for the second time since getting the bike, dang its soo much easier with the rear stand. The first oil change @ 600 miles I didn't have my stands yet and it wasn't bad but this one @2k went soo much smoother with the stand that extra room underneath makes all the difference.
August 23rd, 2010, 05:42 PM | #2 |
/moved to new-gen tech
August 23rd, 2010, 05:51 PM | #3 |
why move it, was more of a comment on bike stands, guess I should have titled it bike stands instead.
August 23rd, 2010, 05:56 PM | #4 |
It's about a tech topic in maintenance, so I felt it was a better fit in the tech section. Maintenance was easier with the stands, right? If you feel that strongly I can move it back, but the only reason to leave something in General is if it doesn't fit anywhere else, and this fits pretty well?
August 23rd, 2010, 06:49 PM | #5 |
ex-ninjette.org guru :o
Join Date: Jun 2010 Motorcycle(s): 2003 SV1000 S Posts: 475
I have to agree, just did my first oil change tonite, and with that rear stand it was stupidly easy...same with lubing the chain. I'm actually looking forward to washing it cause cleaning the wheels is going to be a breeze.
as far as I'm concerned, bike stands should be standard equipment for every owner because they are, in my opinion the 3rd best thing about having a motorcycle (first is riding the bike itself, and second is how a fresh tank of gas makes the balls feel chilly ) |
August 23rd, 2010, 07:46 PM | #6 | |
Posted via Mobile Device |
August 23rd, 2010, 07:49 PM | #7 | |
August 24th, 2010, 06:56 AM | #8 |
Join Date: Jul 2010 Motorcycle(s): Black '11 ZX-6R Posts: 209
I filled the oil up to the top line after running the bike for a couple of minutes but now when i llok at the gauge it above the line and im worried about running it with too much oil. Any advice? Should i start to take oil out until it gets under the line?
My 250 is mine and mine alone, you may see better you'll definitely see worse but mine, she's one of a kind!!!!btw, SHE'S SEXY!!! |
August 24th, 2010, 07:00 AM | #9 |
Is it over the line with both wheels on the ground and the bike straight up?
August 24th, 2010, 09:00 AM | #10 |
You're checking the level when the bike is off, and sitting straight up and down, right? If you can see any air at all in the sight glass, you're fine. Even if it's just above the sight glass, no harm either. If it's much above that, or if it's much below the fill line, only then worrying about adjusting it.
August 24th, 2010, 09:12 AM | #11 |
The bike is up on the stands, i drained it and then filled a little bit. Turned bike on and ran for a couplpe of minutes, turned off and looked at gauge. Then filled up until about top line. Turned on and then was low. Left alone but then when i looked at it again it was totally full. I didnt check for air bubbles but i will check when i get home. You know i'm pretty mechanically inclinced but this bike has me seriously doubting myself on things that are so simplistic. It's changing oil, it should not have solicitated me posting but i guess dealing with a bike will be a learning experience for me. Thanks for all you help btw.
August 24th, 2010, 09:23 AM | #12 |
Is it on rear stand only? If so could that make the oil appear higher?
August 24th, 2010, 09:28 AM | #13 |
Join Date: May 2009 Motorcycle(s): 2015 V-Star 950 Tourer (Deep Blue) Posts: 570
Just a creative draining method my dad came up with when I overfilled it... Windex bottle, the sprayer, if you put the part that sits inside the bottle, inside your oil filler hole, and squirt, guess what, oil comes out! I really didnt want to have to open the drain again.
August 24th, 2010, 09:30 AM | #14 |
Whenever you turn on your engine, it'll appear low since the oil gets sucked down. The way you should check is on level ground (off your stands) and after you had your engine running for a few minutes and then turn it off. You also want to wait a few minutes for the oil to settle back down. Did you also measure how much oil you used? 1.7 L with a filter change.
August 24th, 2010, 09:30 AM | #15 |
or a syring type thing with a tube (just a bit neater than the sprayer, but the sprayer is cool McGyver way of thinking). or a crazy friend and a strawer (not endorsed or recommended by ninjette.org, Kawasaki USA, or Major League Baseball).
August 24th, 2010, 10:35 AM | #16 |
now consider that if i take it off teh stands, do i check after running and allowing to settle straight up or on the side stand?
August 24th, 2010, 10:47 AM | #17 |
You can run the engine and have it stopped on the sidestand. The oil sight will look emptyish on the sidestand, but when you pull it towards you the sight should start filling up. As long as you see some air (it'll be hard to be exact where straight up is), you're fine. If you lean it either side and some air isn't shown, it might be too full.
Is it normal for oil to increase a bit in the crankcase after an oil change? | cadd | 2008 - 2012 Ninja 250R Tech Talk | 10 | May 15th, 2014 08:38 PM |
Synthetic oil at 300 mile oil change? | anacron | 2013 - 2017 Ninja 300 Tech Talk | 14 | July 29th, 2013 04:58 PM |
Oil drain plug gasket for oil change. | tsdexter | 2008 - 2012 Ninja 250R Tech Talk | 8 | July 10th, 2012 01:00 PM |
Oil Change | Honko | 2008 - 2012 Ninja 250R Tech Talk | 10 | July 17th, 2011 08:58 AM |
change oil filter, without draining oil? | peter330 | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 30th, 2010 01:08 PM |
