Old August 17th, 2017, 10:21 PM   #1
Ram Jet
Ram Jet's Avatar
Tail Light
Does anyone know in what year Kawasaki last delivered a Ninja with three bulbs in the tail light assembly. My two outboard sockets/lights have a provision for bulbs and sockets but there are none. Cost cutting measure?
Bill
Old August 18th, 2017, 04:39 AM   #2
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
I not sure they ever did in the US (or anywhere else), but I put sockets in mine and turned them into tail lights and the turn signals.
Old August 18th, 2017, 06:47 AM   #3
I think most states require the turn signals to be farther away from the tail/brake like than the outer sections of that assembly. As Roger said, my impression is that the US versions never got anything in those outer chambers.
I added LEDs (no sockets) to mine and tried them as turn signals, but wasn't happy with the visibility of them, so I got separate amber LED signals and wired the outer tail light LEDs to the brake light. Now when using the brake, the brake light grows much wider and lights brightly, which I like a lot.
Old August 18th, 2017, 07:16 AM   #4
Ram Jet
Ram Jet's Avatar
Thanks Z1R and TJ. I think I found some sockets at a local auto parts store that will fit the 20mm hole in the outboard lights. I'm going to try some incandescent single contact bulbs and wire them into the brake light circuit. I'm glad to hear, Z1R, that the brake light switches can handle the extra load. I'm going to use 7.5W bulbs. I guess I can't let a good hole go to waste.
Thanks again.
Bill
Old August 18th, 2017, 02:49 PM   #5
Z1R rider
Z1R rider's Avatar
Thanks again.
Bill
I didn't hook mine to the brake, just turn signal and running lights. Just used a dual element bulb and socket, I think the bulbs are 1157's.
Old August 18th, 2017, 03:13 PM   #6
Ghostt
Ghostt's Avatar
https://faq.ninja250.org/wiki/I_want...y_rear_sockets
https://faq.ninja250.org/wiki/I_want...er_brake_light
https://faq.ninja250.org/wiki/I_want...s_%26_contrast
I myself have gone the LEDs route, I have a 1157 80w Cree led in the tail/brake, and 1156 7.5w COB amber LEDs in the outer spaces for turn signals.
Below is an, example of the LEDs in sunlight
Also note the 2 small Cree LEDs under the licence plate which are tied into the brake light for added brightness and safety. And the Ninja logo in red reflective on the brake light itself for added visibility due to I did the fender chop, which does away with the OEM reflectors, so I added it to make up of their loss.
It's worth noting that it's not a change in brightness that effective, but it's a change of shape that's most effective, if your after safety then turn the two outer pods into brake lights as well, this will change the shape, and also the brightness. That's why I added the 2 smaller LEDs to the licence plate, kinda like a 3rd brake light.
Another option is adding a brake light modulator, which I have on both of my bikes
https://faq.ninja250.org/wiki/Where_...brake_light%3F
There is law about the distance between the turn signals, which is no closer than 9", but if the cop is pulling you over for that, he's fishing for something bigger, or you've pissed him off, either way it's not going to end well. If the cops in your area are picking on bikes anyway, you might want to take that into consideration as well.
It's all about being seen, and attracting attention, which in the modern world is getting harder, and harder to do.
violente et ignorantia
ZX-2R BLOG
Old August 18th, 2017, 03:55 PM   #7
Ram Jet
Ram Jet's Avatar
Very clever set-up Scott. Where did you get the clear lenses? No matter, I'm just turning my outboard light sockets into brake lights. I'm keeping my rear fender and stuff. Thanks for the info.
Bill
Old August 18th, 2017, 05:36 PM   #8
Ghostt
Ghostt's Avatar
Bill
Got them off eBay
ZX-2R BLOG
Old August 18th, 2017, 08:05 PM   #9
Ram Jet
Ram Jet's Avatar
Got them off eBay
That's really wild, eBay huh? Somebody must have access to injection molding equipment or they made a silicone rubber mold from an original lens and poured some sort of plastic resin into the mold. Regardless, pretty cool.
Bill
Old August 18th, 2017, 08:41 PM   #10
Ghostt
Ghostt's Avatar
Bill
Use to be a very common part years ago, but now that model hasn't been made in 10 years the aftermarket parts are drying up.
ZX-2R BLOG
Old August 18th, 2017, 09:27 PM   #11
Ram Jet
Ram Jet's Avatar
Just F.Y.I. the cam cover (cylinder head cover) is now unavailable for a new purchase. Not that much can go wrong with one.
On the model that used the clear light cover I wonder what the lights were used for? No matter I have no use for them.
Bill
Old August 18th, 2017, 09:51 PM   #12
Ghostt
Ghostt's Avatar
Kawasaki never made clear lens, they are aftermarket made. In other countries the outer lens are deleted with just black plastic, not even the red lens.
GPX250 tail light note the lack of outer lens, also in some countries Kawasaki put amber lens in those spots, hence the holes for the sockets where these were used for turn signals.
ZX-2R BLOG
Old August 18th, 2017, 10:50 PM   #13
Ram Jet
Ram Jet's Avatar
Great info Scott. My tail light is almost ready to go. When I was removing the tail light one of the nuts was corroded enough to twist the stud embedded in plastic. The light was removed with the stud and nut still sitting in the gromet on the frame. I used some heat to remove the nut, That's why I ALWAYS lubricate threads upon reassembly of anything. Anyway I used some JB Weld to secure the stud back into the tail light housing and JB'd the new light sockets into the tail light housing. I'll give it 12 hours to set-up pretty well and reinstall the light. I did test the unit and if anyone runs into the back of my bike they will have to be stinkin' drunk or asleep. Gawd, the brake light now is super BRIGHT!!!!
Bill
Old August 18th, 2017, 10:52 PM   #14
Ghostt
Ghostt's Avatar
Good deal, can't wait to see the pictures.
ZX-2R BLOG
Old August 19th, 2017, 02:27 AM   #15
Ram Jet
Ram Jet's Avatar
Pictures of my tail light? I think you're asking me for pictures - Ram Jet. If so it's a good time to ask. My light isn't installed yet so I can get you photos of the wiring and the light in operation if you want. If you weren't posting to me . . . never mind (as Lilly Tomlin would say).
Bill
Old August 19th, 2017, 04:19 AM   #16
Ghostt
Ghostt's Avatar
Pictures of when it's all done and working on the bike.
ZX-2R BLOG
Old August 19th, 2017, 04:55 AM   #17
Ram Jet
Ram Jet's Avatar
OK, I'll wait till dark for dramatic effect.
Steven Spielberg here.
Old August 19th, 2017, 08:42 PM   #18
Ram Jet
Ram Jet's Avatar
Here ya go. The photo on the left is tail light only, on the right the brakes are applied.
Bill
Old August 19th, 2017, 09:05 PM   #19
That's what I was going for... brighter and bigger when brake applied. Very nice.
Old August 20th, 2017, 08:09 AM   #20
Ram Jet
Ram Jet's Avatar
I installed the same bulbs that are in the turn signals. They are only 7.5 watts but I didn't want to install say 10w because I wasn't sure how much load the brake light switches could handle. I was driving me nuts having those two provisions for lights in the housing and nothing was being done with them. If someone runs into the back of me now it will have to be Stevie Wonder.
This is a quote from the instructions that came with my rear sets for my 1982 Honda FT500, "The makers of this kit want you to avoid a disease known as "Cadillacanalinsertus" - a malady afflicting motorcyclists without brake lights." I consider this preventive medicine.
Bill
Last futzed with by Ram Jet; August 20th, 2017 at 07:17 PM.
Old August 20th, 2017, 10:45 AM   #21
A.J.
A.J.'s Avatar
Motorcycle(s): 2001 Kawasaki Ninja 250r(SOLD) 2006 Kawasaki Ninja 250r full Muzzy(my pride and joy)
Looks great UB. Cars have no excuse not to see you breaking!
"A car or truck will get you from point A to B. But a motorcycle, that is the point." -unknown
A.J. is offline   Reply With Quote
Old August 20th, 2017, 11:19 AM   #22
Ghostt
Ghostt's Avatar
Nicely done sir
ZX-2R BLOG
Wire integrated tail light such that the brake light stays off while signal flashes? CZroe 2008 - 2012 Ninja 250R Tech Talk 6 March 4th, 2012 06:36 PM
FS: Original brake light or FDB integrated tail light (current generation) CZroe Motorcycle-related 9 September 11th, 2011 06:23 PM
WTB: Rear OEM 2008+ Ninja250 Tail Light/Brake Light FerociousNINJA Items Wanted 5 March 29th, 2010 08:52 AM
OEM Tail/Brake Light Comparison to LED Tail/Brake Light g21-30 2008 - 2012 Ninja 250R Farkles 19 November 7th, 2009 12:08 PM
[usridernews.com] - New Universal Tail Light/Brake Light Set from Motolight Ninjette Newsbot Motorcycling News 0 May 20th, 2009 08:00 PM
