Old April 6th, 2019, 10:32 PM   #1
59096
59096's Avatar
Motorcycle(s): GPX250 1989 model and 1990 model
Failed exhaust mod.
In a misguided attempt to improve exhaust gas flow I drilled four 3/8” diameter holes in the end plate of each muffler. It now sounded much, much better. Took the bike for a ride and found throttle response was noticeably worse from 4K to 7K. Took the bike back home, tapped a thread in each of the holes and blocked them all with screws. Took the bike out again and hey presto everything back to normal. Such a small change made such a noticeable difference? I learn something new everyday with this bike!
59096 is offline   Reply With Quote
Old April 7th, 2019, 06:19 AM   #2
I'm glad you recovered from the mistake.
You think it sounded better? Mine had the four rivets drilled out when I got it, and it sounded like a lawn mower engine. I did what you did and tapped the holes for screws, and it sounded like a nice quiet motorcycle engine.
Old April 7th, 2019, 11:58 AM   #3
There's mid-range lean-spot on these bikes. Anything you do that increase flow-rate makes it worse and bike gets even worse in mid-range.
Old April 7th, 2019, 02:09 PM   #4
You can compensate for the increased flow, and leaner mixture, by shimming the needles and changing the mixture adjustments and/or jets.
When making carb adjustments, think in terms of the throttle position (1/8, 1/4, 1/2, etc) instead of RPMs. That way it's easier to isolate the circuit that needs adjustment.
Too much gas, float needles failed, petcock failed Lazarus 2008 - 2012 Ninja 250R Tech Talk 29 April 4th, 2016 09:54 AM
Ninja 250r Stock Exhaust Mod Justin.E 2008 - 2012 Ninja 250R Tech Talk 2 March 20th, 2016 03:04 PM
Out with the old, in with the new!! exhaust mod!!!!! gantt Off-Topic 12 March 9th, 2015 05:52 PM
ZX-10 Exhaust Mod htdub 2008 - 2012 Ninja 250R Tech Talk 9 August 23rd, 2012 12:51 PM
ninja 250 undertail exhaust mod Klondike1020 1986 - 2007 Ninja 250R Tech Talk 13 March 30th, 2012 11:48 AM
