Old July 8th, 2009, 08:35 AM   #1
tlhamon
tlhamon's Avatar
Motorcycle(s): None Yet
Locked the Rear Tire Twice in Two Days
It's not like I'm riding fast (about 45 mph) but I had to make a quick stop for a light the last couple of days and locked the rear tire both times. Not complaining, but a bit surprising as I never had it happen on my heavier bikes. The Ninja is so light that it has a lot of idiosychrocies I didn't experience before. Like, don't ride on a windy day. I do love that I can actually walk it around (I only weigh 120 lbs) and that it is super easy to control, no issues with the tire locking up as the bike stayed straight and true.
It's not worth doing if you aren't completely stressed out about it.
tlhamon is offline   Reply With Quote
Old July 8th, 2009, 08:49 AM   #2
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
Thomas, sounds like you need to be a little lighter on the rear brake - a bit less pressure and it should help keep it from locking up on you - pick any one of the 2 or 3 threads and there are lots of opinions on the issue
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old July 8th, 2009, 08:49 AM   #3
Snake
Snake's Avatar
I am not sure if you can adjust the pedal pressure on the rear brake but I will check and see.
Old July 8th, 2009, 08:55 AM   #4
billmi
billmi's Avatar
Motorcycle(s): 82 XV750, 99 DR200SE, 04 DR200SE, 08 DR200SE, 95 EX250
The rear brake pedal is directly linked to the rear master cylinder. It is adjustable, but the adjustment sets the position of the piston at the start of the brake pedal's stroke.
The only way you could adjust the pressure it delivers to the brake relative to the pressure applied to the pedal would be to change the diameter of the master cylinder (i.e. replace it with a narrower cylinder to provide less force) so that the ratio between its piston and the caliper pistons changed.
I think it would be easier to just get the feel of the brake through practice, since the pressure level that can cause the rear tire to loose traction with the street varies with the road surface, the tire, and anything in-between (sand, water, oil, etc.)
billmi is offline   Reply With Quote
Old July 8th, 2009, 08:56 AM   #5
You need to stop doing that. Much more front brake. Much less rear brake.
Thread 1
Thread 2
If you're locking up the rear tire, you don't just have a rear braking problem, you have a braking problem that is keeping you from stopping the bike in the shortest distance. Just using less rear brake doesn't fully fix the issue.
Old July 8th, 2009, 10:48 AM   #6
Verus Cidere
Verus Cidere's Avatar
Motorcycle(s): '91 Honda CBR600 F2
Generally in situations like that, I hit the front brake fairly hard, but ease onto the rear brake. It makes it easier to keep it from locking up on you.
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail.
Verus Cidere is offline   Reply With Quote
[crash.net - MotoGP] - Iannone: Rear wheel locked at 230kph Ninjette Newsbot Motorcycling News 0 April 26th, 2014 09:40 AM
[crash.net - MotoGP] - Iannone: Rear wheel locked at 300kph Ninjette Newsbot Motorcycling News 0 April 26th, 2014 06:21 AM
[crash.net - MotoGP] - Iannone: Rear wheel locked at over 300kph Ninjette Newsbot Motorcycling News 0 April 26th, 2014 03:10 AM
[crash.net - MotoGP] - Iannone: Rear wheel locked on the straight Ninjette Newsbot Motorcycling News 0 April 25th, 2014 03:20 PM
so my rear brake locked... SafetyPaws Riding Skills 3 July 2nd, 2012 10:58 PM
