Closed Thread
Old November 12th, 2017, 07:55 PM   #1
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Bolts
I am in need of water pump housing bolts and the drain plug bolt. My manly strength broke two bolts while putting the cover back on and installing the drain bolt.
TEAM ALFALFA
www.apexassassins.com
cbinker is offline
Old November 13th, 2017, 05:57 AM   #2
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Ah yes.... German torque (gutenteit).
Not sure what you're asking for here, but....
1) There are numerous online purveyors of OEM motorcycle parts. Google is your friend. Be prepared to pay stupid-high shipping charges if you don't buy enough stuff. Check in-stock status carefully... it can be tricky.
2) Kawasaki has a dealer network that stocks OEM parts for your bike.
3) There's this truly amazing invention called a "torque wrench." Widely available at local home improvement stores as well as online. Check it out.
PS: The maintenance manual has torque specs for every nut and bolt on the bike. Also available at your local Kawasaki dealer. They'd be happy to serve you.
Maintenance manuals and torque wrenches cost money. I leave it to you to determine whether the cost in time, inconvenience and potential further damage to the bike (e.g. stripped holes) offsets the cost of doing it right in the first place.
adouglas is offline
Old November 14th, 2017, 05:41 AM   #3
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
I was looking to see if any had any sitting in a box in the garage. my dealer shut down. the torque required for those parts are super low, I have a torque wrench, but doesn't go that low. The added water on the bolts added a little "lube" causing less friction..
also no need to spend money with this:
https://faq.ninja250.org/torque/ex250f/
TEAM ALFALFA
cbinker is offline
Old November 14th, 2017, 11:56 AM   #4
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
go to harbor freight and buy 1/4” drive inch pound torque wrench. they cost bout $17-20. the size is perfect for all jobs that r needed on the ninja. ok, beer time. 🍺
"trying not to get old"
maverick9611 is offline
Old November 14th, 2017, 12:55 PM   #5
adouglas
adouglas's Avatar
Originally Posted by maverick9611 View Post
go to harbor freight and buy 1/4” drive inch pound torque wrench. they cost bout $17-20. the size is perfect for all jobs that r needed on the ninja. ok, beer time. ��
I have two torque wrenches. The small one goes from 25-250 in-lbs (about 2.1-21 ft-lbs). The other goes from 20-100 ft. lbs. Both are 3/8" drive, so I don't have to carry additional sockets.
Have yet to find a fastener on any bike that doesn't fall within this range.
adouglas is offline
Old November 14th, 2017, 04:53 PM   #6
Even less with coupons available here: http://www.hfqpdb.com
Sometimes, they have 1-day specials with 25% off coupons and you can get torque-wrenches for $15!!!
I test their calibrations yearly and replace them if they’re more than +/-15% off. So far, I’ve only had to take one back for replacement in past 10-yrs.
DannoXYZ is offline
Old November 14th, 2017, 07:35 PM   #7
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
closest harbor freight is an hour away, and a smaller torque wrench hasn't been a priority. I am still buying parts to fix the bike from the crash.
TEAM ALFALFA
cbinker is offline
Old November 14th, 2017, 10:03 PM   #8
I may have some bolts for you. I get back tomorrow and I’ll check my stash.
DannoXYZ is offline
Old December 13th, 2017, 09:10 AM   #9
TonyKZ1
TonyKZ1's Avatar
Motorcycle(s): 1975 Kawasaki KZ400D (Sold), 1989 Kawasaki Ninja 250 (sold), 1997 Yamaha XJ600s Seca II
I'm sure I've still got those bolts on a used engine or two. Do you still need these?
1997 Yamaha Seca II - mostly stock, Racetech upgraded forks, FZ6R rear shock, Oxford Heated Grips, Barkbusters Blizzard Handguards, a Scottoiler vSystem chain oiler. My Mileage Tracker Page.
TonyKZ1 is offline
Old January 8th, 2018, 02:04 PM   #10
CTarna
Ghost...
CTarna's Avatar
MOTM - Oct '17
I might still have a box full of bolts from taking apart my EX500 motor. I'm sure the cover bolts were in there. If you still need this, I will go into the -30° garage to take a look.
CTarna is offline
Old January 8th, 2018, 06:28 PM   #11
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Im good on bolts, this thread can be locked. @Alex
TEAM ALFALFA
cbinker is offline
Closed Thread
Stripped bolts Christofini 2008 - 2012 Ninja 250R Tech Talk 9 June 12th, 2013 04:28 PM
7 fairing bolts and 3 windscreen bolts for pregen. Monkeytofu Free stuff! 5 November 29th, 2012 11:03 AM
bolts akcalhoun 2008 - 2012 Ninja 250R Tech Talk 3 July 20th, 2012 06:58 AM
WTB PreGen Fairing bolts and other misc bolts xlatinox Items Wanted 1 June 8th, 2011 05:32 AM
