January 16th, 2011, 01:15 PM | #1 |
Join Date: Mar 2010 Motorcycle(s): 2010 Ninja 250R Posts: 28
Aftermarket gauges, oil pressure?
Thinking of mounting some gauges for water temp and oil pressure in the void behind the gauge cluster.
The oil temp one is easy, just a straight sensor replacement, but not sure where or how to get the oil pressure. Anyone ever mount a oil pressure gauge on your 250? Last futzed with by J Walk; January 16th, 2011 at 11:55 PM. |
January 16th, 2011, 03:36 PM | #2 |
Join Date: Apr 2010 Motorcycle(s): Yahama v star 650 classic Posts: A lot.
Why do you want to do this? The stock cluster have lights for both these.?.
January 16th, 2011, 07:33 PM | #3 |
Rather have an actual gauge that I can read, then just an idoit light that comes on. Especailly the water temp, would be nice to know when the bike is warmed up.
January 16th, 2011, 08:44 PM | #4 |
Join Date: Mar 2009 Motorcycle(s): '09 Blue Kawasaki KLE650 Versys, '95 Ducati 900SS/CR (undergoing track conversion) Posts: 287
idiot lights are set to go off at a certain point, but what if your running half a psi off the low pressure on the oil, or 2 degrees before over heat in the coolant? You won't know, and won't know that a potential problem exists.
Because of how hot the summers get here, I want to add in my spare oil cooler, adding both a pressure AND temp gauge for the oil, and a temp gauge for the coolant.
2009 KLE650 LSL bars, Full Muzzy PC-V 1995 900SS/CR mildly modified |
January 20th, 2011, 01:00 PM | #5 |
Here is a h2o temp gauge I did: http://www.ninjette.org/wiki/DIY_Day...ter_Temp_Gauge
I'm not sure about an individual oil gauge, but I know the Koso clusters will read both (and come with sensors).
January 20th, 2011, 02:12 PM | #6 |
Yep there's where I saw how to do the water temp gauge, in your DIY (thanks by the way , I know there is a oil pressure sensor on top on the block but not sure if I want to replace that one, would probably have the oil light on all the time that way. Looking for a cheaper alternative to the koso gauge to monitor some of the engine. Worst comes to worst probably just install the water gauge and leave it at that.
January 20th, 2011, 05:34 PM | #7 | |
January 20th, 2011, 06:32 PM | #8 | |
IC2(SW)
More than likely, you would be disappointed in the psi reading. Also dont know if the little pump could support an oil cooler |
January 20th, 2011, 06:47 PM | #9 |
Then why does the light come on when you turn on the ignition...There is no pressure when the engine hasn't started and the light goes out once the minimum pressure has been reached.
January 20th, 2011, 08:42 PM | #10 |
Maybe I'm wrong but I thought it was an electrical sender??
So Hkr1 comment makes sense to me. If the connector is reading infinite resistance due to the sensor not being connected to it then the light should stay off. Don't know where the cooler came in though?? Just wanted an actual gauge instead of just a low pressure light. |
January 21st, 2011, 08:49 AM | #11 | |
I need the oil cooler, I have one, but have not seen a way to put it inline.
oil pressure light | contact148 | 2008 - 2012 Ninja 250R Tech Talk | 28 | June 21st, 2018 06:54 AM |
Tire pressure gauges | Soujyu | General Motorcycling Discussion | 44 | April 4th, 2015 07:20 PM |
Oil pressure light question... | Iffita | 1986 - 2007 Ninja 250R Tech Talk | 3 | October 9th, 2012 07:44 PM |
Oil pressure switch | randomwalk101 | 2008 - 2012 Ninja 250R Tech Talk | 13 | February 23rd, 2011 06:58 PM |
Low oil pressure during braking | Guinss | 2008 - 2012 Ninja 250R Tech Talk | 11 | May 29th, 2010 08:47 AM |
