January 26th, 2014, 06:36 PM | #1 |
Join Date: Jan 2014 Motorcycle(s): ninja 250, used to own ninja zx6r, and drz 400 sm Posts: 28
ninja 250 keyless ignition
I was wondering if anybody knew how to make a keyless ignition for the new gen ninja 250. i dont know anything about how to do it, does anybody know where i could find a step by step guide? i tried searching on google and on ninjette .org but i couldnt find anything
thanks |
January 26th, 2014, 06:47 PM | #2 |
Jedi on Two Wheels
Join Date: Nov 2013 Motorcycle(s): 2010 Kawasaki Ninja 250r (Slightly Modded) Posts: 489
Just out of curiosity: why?
It's not that much of a hassle to put the key in and turn it. Plus, with a keyless ignition how do you plan on locking your forks?
May the force be with you and keep your rubber side down. |
January 26th, 2014, 07:14 PM | #3 |
its for my race bike, i want to loose weight, also the key i have is close to breaking off in the ignition from a crash, and ide rather get rid of the ignition than buy a new one
January 26th, 2014, 07:15 PM | #4 |
Track Clown
MOTM - Sep '15
January 26th, 2014, 09:00 PM | #5 |
January 26th, 2014, 09:31 PM | #6 |
Private Joker
MOTM - Mar '14
Hmm, I'd say to pull it and rewire the switches to an on/off power switch/button so you don't bleed battery power while sitting. I'd say that all that would be needed would be basic soldering skills and the ability to identify which wires to solder. It would be simpler for me since I could just give my older brother (certified electrician) a beer to do it "with" (read: for) me.
To actually do it would be easier with a wiring diagram, I think shop manuals have those. You should pick one up if you don't already own one. |
January 28th, 2014, 02:04 AM | #8 |
okay thanks alot, ill try that out tmrw
January 28th, 2014, 02:27 AM | #9 |
will that switch just replace the key switch? i was hoping to use just the ignition button and kill switch next to the throttle to start/ stop the bike
January 28th, 2014, 02:44 AM | #10 |
MOTM - Jan '18, Sep '13
You need a way to keep the bike from constantly drawing power from the battery unless you want to pull the fuse all the time.
January 28th, 2014, 03:26 AM | #11 |
could i just run the keyless power switch to the kill switch button and then get rid of the kill switch all togeather since turning off the keyless switch will cut the engine too
January 28th, 2014, 06:07 AM | #12 |
Join Date: Jan 2012 Motorcycle(s): Race bikes:08 Ninja 250,11 R6,16 ZX6,SV650.3 HD-1947,2-2003,2010. 1946 Indian and a lot of dirt bikes.2 Posts: 999
Post #5
January 28th, 2014, 01:02 PM | #13 |
la pussy gata
We just did this to my track bike too. Stopped by autozone and grabbed a 30v switch. @shane liberty should remember since it wasnt too long ago but we got rid of the colored wires that ran to blinkers etc and kept the rest to run to the kill switch.
CVMA #731/Sttars #731 Dmented Racing/NKB Motorcycles/Cycle Gear |
January 28th, 2014, 06:04 PM | #14 |
Yeah I'm running a switch in place of kit's ignition on her bike but Cyclemall ran everything to the normal kill switch on my bike. They soldered a resistor in the harness somewhere to make it work without killing the battery. I honestly don't know how to do that part so I didn't do it.
I can show you exactly how to wire up a separate switch like I did for Kit's bike, though. Simple deal really. We have a schematic of the wire harness. |
July 15th, 2014, 06:05 PM | #15 |
KAWASAKI GURU
Join Date: Jul 2013 Motorcycle(s): Turbo Ninja 250 Posts: 863
July 15th, 2014, 07:04 PM | #16 |
KAWASAKI GURU
Decided to take a look at the wiring diagram and the bike in the garage tonight. I did the same wiring as above but instead of putting it to a switch I removed the RED and RED/YELLOW pins from the RH control. That is for the Start/Stop switch and I connected the BROWN/GREY with 100ohm resistor to the RED and the WHITE with WHITE/BLACK to the RED/YELLOW. This will make the Start/Stop switch your ON/OFF "ignition" switch.
You just have to then connect the other side of the control plug's two wires together which is RED and BROWN/BLACK wires..... Following me? I'll post some photos soon if needed ;-) Enjoy! |
July 16th, 2014, 02:07 PM | #17 |
n00b with the b00bs
Join Date: Jan 2013 Motorcycle(s): 2007 EX250, 2008 EX250, 2001 ZR-7S, 2010 ZX-6R Posts: 470
I would love pictures of what you did. Also, what are you folks doing about the connector? are you re-using the old one or is there a work-around?
July 16th, 2014, 06:27 PM | #18 |
KAWASAKI GURU
October 4th, 2016, 08:00 PM | #19 | |
Join Date: Nov 2014 Motorcycle(s): 09 ninja 250r 09 ninja 250r stunt 2011 ninja 250r Posts: 7
09 Keyless Ignition | Chad4434 | 2008 - 2012 Ninja 250R Tech Talk | 15 | October 5th, 2016 04:12 AM |
DIY Keyless Ignition for 08 250 | garth285 | 2008 - 2012 Ninja 250R Tech Talk | 9 | July 18th, 2014 01:39 PM |
Is there a DIY for keyless ignition? | Triple R | 2008 - 2012 Ninja 250R Tech Talk | 8 | June 26th, 2014 02:53 PM |
FS : 08+ Ninja 250 SlingShot Racing Keyless Gold Gas Cap | abhijitz | Motorcycle-related | 2 | May 28th, 2013 02:30 PM |
Keyless ignition | Kevinnolde | 2008 - 2012 Ninja 250R Tech Talk | 3 | September 1st, 2009 08:31 AM |
