April 11th, 2012, 10:19 AM | #1 |
Join Date: Feb 2012 Motorcycle(s): 2002 Ninja 250 and '85 Yamaha Virago 700 Posts: 9
fuel inlet tube on carb cracked or loose? Leaks gas!
I changed the gas filter between the petcock and the fuel inlet (that black L shaped fitting) on the left side of the left carb. Now it leaks gas from the fuel inlet, dripping down the fuel hose and down the carb...really gushing fuel. The hose is securely clamped. Maybe I tightened it too much?
Is the inlet tube replaceable or fixable or am I screwed?? Sherwiner 2002 Ninja 250 Sherwinb@aol.com Last futzed with by sherwiner; April 11th, 2012 at 10:20 AM. Reason: additional info |
April 11th, 2012, 10:36 AM | #2 |
Just replace it with a fuel hose from Autoparts; they sell it by foot
April 11th, 2012, 12:05 PM | #3 |
Join Date: Nov 2011 Motorcycle(s): 2007 Ninja 650R Posts: 317
He's referring to the inlet tube, not the hose itself.
I'm not seeing it with its own part # on any of the diagrams, which may mean you need to buy a whole carb & rob it. Check Ebay to see if anyone is parting out a carb, otherwise, pick up a whole used one & rob the tube off it. |
April 11th, 2012, 12:35 PM | #4 |
It may not be the fitting but the hose what leaks onto it.
If it wasn't cracked before, what made it start leaking now? You could try repairing it with epoxy, in case it is actually a cracked fitting.
April 11th, 2012, 12:50 PM | #5 |
You may be able to replace it with a automotive hose fitting. You will need to find one that matches the thread size of the original. Something similar to this-
http://www.jegs.com/i/JEGS-Performan...ductId=1123904 |
April 11th, 2012, 02:57 PM | #6 |
I replaced the spring hose clamps with screw type...
after I pulled the fuel lines off to replace the filter and that's when it started leaking - after I tightened the screw type hose clamp onto the fitting on the carb. I will have to check to see if it screws into the carb like the example Dablue posted or if it is a press fit and if I can stop the leaking with oil/gas resistant sealant. Not looking to buy a carb to get the part.
I repair more than I ride |
Fuel line came loose from somewhere? | Kurgan | 2008 - 2012 Ninja 250R Tech Talk | 9 | November 22nd, 2014 08:46 PM |
CARB Dropped and Busted Fuel Inlet - Suggestions? | Road Dawg1 | 2008 - 2012 Ninja 250R Tech Talk | 9 | July 18th, 2014 07:12 PM |
Broke Carburettor Fuel Inlet | indr | 2008 - 2012 Ninja 250R Tech Talk | 4 | May 1st, 2013 01:30 PM |
Carburetor Fuel Overflow Tube Replacement | Jim Moore | 1986 - 2007 Ninja 250R Tech Talk | 6 | June 18th, 2012 05:07 AM |
Loose Tube under bike | The_beanz | 2008 - 2012 Ninja 250R Tech Talk | 20 | September 11th, 2010 07:54 PM |
