July 20th, 2009, 11:04 AM | #1 |
Join Date: Jun 2009 Motorcycle(s): Black 2009 Kawasaki Ninja 250R Posts: 153
Can I just cut the brake hose shorter to fit Woodcraft rearsets?
I installed my rearsets last week, and I noticed the brake hose to the reservoir was a little pinched, so I turned the hose to relax it some..
now when I sit on the bike, it comes very very close to the rear tire, and so I know for sure if there is a passenger, it will rub. I saw that someone made an extending bracket to move the reservoir back a few inches, but I am a lazy ass that doesn't want to.. Could I simply cut the hose at one end (I was planning on the reservoir end since I may not do a perfectly smooth cut), so that it won't be near the tire or be pinched? I am mostly confident this shouldn't affect anything since it's not pressurized in the hose, but figure I would throw it out there to make sure
Black 09 Ninja 250R|Shogun Crash Kit|Woodcraft Full Rearsets|Proton Flush LEDs|De-Snorkeled|Shimmed|K&N|Red Rim Tape|ProGrips|Puig|10K HIDs|15T Front |
July 20th, 2009, 11:55 AM | #2 |
I believe that would work fine. You'd most likely have to bleed the brakes though after re-attaching the hose.
July 20th, 2009, 12:07 PM | #3 |
July 20th, 2009, 12:26 PM | #4 |
i was thinking the same, i was going to suck out the fluid from the reservoir, then just a little bit from the hose and while holding it upright, chop off 1-2 inches with a super sharp serrated kitchen knife lol
July 20th, 2009, 12:30 PM | #5 |
I nice big, sharp set of scissors would work great and give you a cleaner cut.
If it doesn't work, the worst is that you'll need to bleed the brakes. I'd caution about being sure not to get any dirt of pieces of the hose in to the brake line. That's where a pair of scissors would make a nice clean cut w/o having to worry about rubber bits from cutting. |
July 20th, 2009, 01:59 PM | #6 |
true, will do that
do u know how hard it is to find 3mm washers in a noname area?? i had to have a store order them, which only cost $1 for 100, but $5 for shipping.. dammit! who needs 96 3mm washers??
July 20th, 2009, 02:11 PM | #7 |
lol... tons of people seem to have problems finding those washers. You might consider posting them up for a SASE to help others who can't get those washers when they shim their carbs.
yeah... and I live in one of those no name areas, too. |
July 20th, 2009, 02:20 PM | #8 |
SASE = self addressed stamped envelope?
i looked up SAE at first and one def said sexual assault examiner hahaha
July 20th, 2009, 02:30 PM | #9 |
July 20th, 2009, 03:57 PM | #10 |
If you're cutting the hose up at the res end and keep the fluid in the hose still attached to the master cylinder you won't need to bleed the brakes. Some guys use nothing but a short piece of tube as their reservoir.
July 21st, 2009, 11:17 AM | #11 |
Join Date: Jun 2009 Motorcycle(s): Ninja 250 x2, Ninja 650R Posts: 165
Yes, you can cut the line to the shorter length you want. Also, you will want to bleed the rear brake. It's impossible to remove the line and not get air into the line.
July 21st, 2009, 11:24 AM | #12 |
i didnt remove the line, i just bent if half way and drained some out.. cut the line and plugged the reservoir back in.. i watched the air pocket come up, so i should be good
woodcraft rearsets 88-07 | Major_Paine | Motorcycle-related | 0 | December 1st, 2013 02:29 PM |
Pre-gen Woodcraft rearsets complete with Brake and Shift Levers | 2WheelGuy | Motorcycle-related | 0 | June 25th, 2013 10:28 AM |
Woodcraft Rearsets Never Used | Zyconic17 | Motorcycle-related | 3 | April 3rd, 2013 10:47 PM |
Woodcraft Rearsets | cuz | Items Wanted | 0 | April 29th, 2012 03:48 PM |
Woodcraft Rearsets | smcbride11 | 2008 - 2012 Ninja 250R Farkles | 10 | March 8th, 2009 09:04 PM |
