Old July 20th, 2012, 08:22 PM   #1
iplante
I ride like a granny
iplante's Avatar
Motorcycle(s): 2003 Ninja 250R - EX250F
Added lights to the rear pods - now having issue
I bought the correct sockets and the correct lights (2x2397 and 1x2357). All three sockets and bulbs work fine using the 9V battery test.
I 'bundled' together the blue wire with the brake light wires from those two new sockets. Did the battery test again and everything lights up.
I bundled the red wire with the running light wires and did the 9V battery test - everything works fine
I bundled the white cables (ground) from my new sockets to the white/black wire (ground) from the original light.
I used crimper connectors to connect it with the rest of the original wires (the one with the white connectors) but did not use heat to shrink the tubings yet. I connect the whole thing to the bike again.
Turn the key to 'on'. Lights don't come on. try the hand brake. nothing. same with the brake pedal.
I start the bike. Nothing.
I turn the key to 'P'. All three bulbs light up like a christmas tree!
Any idea what the F is happening? lol. I'm new to all of this and can't figure out what I did wrong
iplante is offline   Reply With Quote
Old July 21st, 2012, 08:02 PM   #2
iplante
iplante's Avatar
Figured it out in case anyone was wondering.
I blew the fuse.. I didn't know that 'P' didn't go through that fuse so I didn't think of that.
Also, when I first spliced the new sockets with the existing one, I didn't leave enough length.. so come to mount the light assembly back in the tail, and the wires were too tight for the screws to go through the bracket!!!
So I ended up buying some black and some white wire and more crimpers with heat shrink tubing around them and adding length to EVERY SINGLE wire.. lol. This project probably cost me twice what it should've, in addition to 3x the time i should've been spending on it.
But totally worth it!
Old July 21st, 2012, 08:04 PM   #3
YMCMB
YMCMBillionaire
YMCMB's Avatar
Motorcycle(s): 2008 Ninja 250R(Wrecked&Gone), 2004 Honda CBR1000RR (Trading back to dealer for 600cc)
Glad you got the fix today. I also solved an issue today on my ninja haha.
YMCMB is offline   Reply With Quote
Old July 21st, 2012, 08:06 PM   #4
iplante
iplante's Avatar
Thanks man and good luck with your issue!
Old July 21st, 2012, 08:15 PM   #5
YMCMB
YMCMBillionaire
YMCMB's Avatar
Was a simple 12 dollar flasher relay to make them blinkety blink
Old July 24th, 2012, 12:47 PM   #6
iplante
iplante's Avatar
Here's a before/after pic. I'm super happy with the results.
Issue with K&N pods parox91 1986 - 2007 Ninja 250R Tech Talk 8 October 28th, 2013 06:41 AM
Extra Brake Lights in pods = all other lights dimming CalvinAmI 1986 - 2007 Ninja 250R Tech Talk 23 October 16th, 2012 10:21 AM
rear lights onizthegnome General Motorcycling Discussion 11 November 26th, 2010 09:03 PM
Added driving lights gogiburn 1986 - 2007 Ninja 250R Farkles 8 July 25th, 2010 05:48 PM
Chopped fender & Installed lights in pods Snake 1986 - 2007 Ninja 250R Farkles 22 January 19th, 2010 12:48 AM
