Old July 20th, 2009, 11:04 AM   #1
Hokie11
Motorcycle(s): Black 2009 Kawasaki Ninja 250R
Can I just cut the brake hose shorter to fit Woodcraft rearsets?
I installed my rearsets last week, and I noticed the brake hose to the reservoir was a little pinched, so I turned the hose to relax it some..
now when I sit on the bike, it comes very very close to the rear tire, and so I know for sure if there is a passenger, it will rub. I saw that someone made an extending bracket to move the reservoir back a few inches, but I am a lazy ass that doesn't want to..
Could I simply cut the hose at one end (I was planning on the reservoir end since I may not do a perfectly smooth cut), so that it won't be near the tire or be pinched?
I am mostly confident this shouldn't affect anything since it's not pressurized in the hose, but figure I would throw it out there to make sure
Black 09 Ninja 250R|Shogun Crash Kit|Woodcraft Full Rearsets|Proton Flush LEDs|De-Snorkeled|Shimmed|K&N|Red Rim Tape|ProGrips|Puig|10K HIDs|15T Front
Hokie11 is offline   Reply With Quote
Old July 20th, 2009, 11:55 AM   #2
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
I believe that would work fine. You'd most likely have to bleed the brakes though after re-attaching the hose.
k-os is offline   Reply With Quote
Old July 20th, 2009, 12:07 PM   #3
maybe not. if you work fast and don't get air into that supply line, you should be fine. The fluid is only gravity fed to the brake hydraulic assembly.
Old July 20th, 2009, 12:26 PM   #4
Hokie11
i was thinking the same, i was going to suck out the fluid from the reservoir, then just a little bit from the hose and while holding it upright, chop off 1-2 inches with a super sharp serrated kitchen knife lol
Old July 20th, 2009, 12:30 PM   #5
I nice big, sharp set of scissors would work great and give you a cleaner cut.
If it doesn't work, the worst is that you'll need to bleed the brakes. I'd caution about being sure not to get any dirt of pieces of the hose in to the brake line. That's where a pair of scissors would make a nice clean cut w/o having to worry about rubber bits from cutting.
Old July 20th, 2009, 01:59 PM   #6
Hokie11
true, will do that
do u know how hard it is to find 3mm washers in a noname area?? i had to have a store order them, which only cost $1 for 100, but $5 for shipping.. dammit! who needs 96 3mm washers??
Old July 20th, 2009, 02:11 PM   #7
lol... tons of people seem to have problems finding those washers. You might consider posting them up for a SASE to help others who can't get those washers when they shim their carbs.
yeah... and I live in one of those no name areas, too.
Old July 20th, 2009, 02:20 PM   #8
Hokie11
SASE = self addressed stamped envelope?
i looked up SAE at first and one def said sexual assault examiner hahaha
Old July 20th, 2009, 02:30 PM   #9
yes, SASE. people that can't find 3mm washers would really appreciate it.
I changed it from SAE after a bit so not to confuse people.
Old July 20th, 2009, 03:57 PM   #10
rockNroll
rockNroll's Avatar
Motorcycle(s): black
If you're cutting the hose up at the res end and keep the fluid in the hose still attached to the master cylinder you won't need to bleed the brakes. Some guys use nothing but a short piece of tube as their reservoir.
Old July 21st, 2009, 11:17 AM   #11
M
Motorcycle(s): Ninja 250 x2, Ninja 650R
Yes, you can cut the line to the shorter length you want. Also, you will want to bleed the rear brake. It's impossible to remove the line and not get air into the line.
M is offline   Reply With Quote
Old July 21st, 2009, 11:24 AM   #12
Hokie11
i didnt remove the line, i just bent if half way and drained some out.. cut the line and plugged the reservoir back in.. i watched the air pocket come up, so i should be good
woodcraft rearsets 88-07 Major_Paine Motorcycle-related 0 December 1st, 2013 02:29 PM
Pre-gen Woodcraft rearsets complete with Brake and Shift Levers 2WheelGuy Motorcycle-related 0 June 25th, 2013 10:28 AM
Woodcraft Rearsets Never Used Zyconic17 Motorcycle-related 3 April 3rd, 2013 10:47 PM
Woodcraft Rearsets cuz Items Wanted 0 April 29th, 2012 03:48 PM
Woodcraft Rearsets smcbride11 2008 - 2012 Ninja 250R Farkles 10 March 8th, 2009 09:04 PM
