July 26th, 2009, 03:56 PM | #1 |
Join Date: Apr 2009 Motorcycle(s): '04 sv650s Posts: 438
crooked swingarm?
First of all, this isn't about the kink(normal) in the swingarm.
So right now, I'm wondering if this is an optical illusion or not, my tire is almost to the point of requiring change, and I realized the wear marks indicators are more worn on one side than the other..so I jacked the bike on its stand, and it seems like the wheel crooked!(the camber..which should be 0). I adjusted the alignment the best I could again with the string method, tighten all the bolts, re-checked adjustment and it still seems crooked...So at this point..I'm wondering is that some kind of factory tolerance crookness or what? That bike has never been in an accident.. The pic is my problem but exagerated by alot...
There's 2 types of people in this world, those who complain and those who act. |
July 26th, 2009, 05:08 PM | #2 |
It should look straight. Can you get pics of yours for us?
July 26th, 2009, 06:21 PM | #3 |
If your tire is wearing unevenly then it is a good indication that you have a problem with alignment or as seems to be your case that the swingarm may be bent. Is the bike still under waranty? If so take it back to the dealer for them to fix.
July 26th, 2009, 06:23 PM | #4 |
my bike is old , its out of warrenty.
July 26th, 2009, 06:30 PM | #5 |
Since your bike is out of wananty what you need to do is remove the swingarm and lay it on a flat surface. Both arms should lay flat and paralel with eachother. If this is not the case then you will have to order onother swingarm.
July 26th, 2009, 06:47 PM | #6 |
I'll post a pic shortly, its dark and raining now.
July 26th, 2009, 07:35 PM | #7 |
worn swingarm bearings?
July 26th, 2009, 07:36 PM | #8 |
or worn rear wheel bearings?
July 26th, 2009, 07:45 PM | #9 |
You will be able to check those two items when you take the swingarm off. |
July 26th, 2009, 08:00 PM | #10 |
Hppowdercoating
One of these two or Both...
1. Bad wheel bearing 2. Bent wheel
HP-POWDERCOATINGS.COM http://i52.photobucket.com/albums/g2...100_3312-1.jpg |
July 27th, 2009, 06:10 PM | #11 |
Join Date: Jan 2009 Motorcycle(s): 05 GSX-R 600 2003 EX250: Woodcraft Bars, Levers, Mirrors, Shim'd Mixture, Synthetic, '08 Rear Shock Posts: A lot.
those would be my guesses as well..
Remember when sex was safe and motorcycles were dangerous? |
[superbikeplanet.com] - Stoner's Aim Crooked? | Ninjette Newsbot | Motorcycling News | 0 | January 29th, 2013 01:20 PM |
Crooked Fairings | FollyUFO | 2008 - 2012 Ninja 250R Tech Talk | 5 | August 11th, 2011 11:47 AM |
[topix.net] - 'Steel Stampede' Cruises To Crooked River Ranch | Ninjette Newsbot | Motorcycling News | 0 | May 2nd, 2011 04:30 AM |
crooked steering | b_eastep | 1986 - 2007 Ninja 250R Tech Talk | 6 | July 5th, 2009 09:30 AM |
Crooked handle bars | Rawr | 2008 - 2012 Ninja 250R Tech Talk | 11 | April 26th, 2009 04:54 PM |
