Old March 16th, 2011, 06:42 PM   #1
danjaho
two ninjas, no regrets.
danjaho's Avatar
Motorcycle(s): RED 2009 Kawasaki Ninja 250R... Special Edition 2009 Kawasaki Ninja 250R
throttle or carb issue!!!!!
mechanical question for you that you might not know the answer to but im just asking anyways.... i jetted my 250r with a dynojet kit put on a full yoshimura TRC carbon fiber exhaust, and its sitting without a cluster right now because i just got my koso rx2.. we re-installed the carb and we went to turn it on and hear the exhaust but she wouldnt turn over for 2 days so i put heaters all around it to warm it up over night and then i put it on primer and tried turning it on.. she finally turns over and jumps right to max rpm i have NO throttle control what so ever, throttle is closed and the second it starts up, she just starts screaming. turned down my idle and yep still screams. starts without a choke either.. weird? put the gas back on and now she wont turn over got maybe one or two shotgun decibel back fires out of it. i mean the throttle is making a weird clicking sound too and im just worried if i turn it back on im going to blow it up.. any ideas?
danjaho is offline   Reply With Quote
Old March 16th, 2011, 07:48 PM   #2
/moved to new-gen tech
Old March 16th, 2011, 08:44 PM   #3
DaBlue1
DaBlue1's Avatar
Sounds like you have not finished your assembly. Put everything (the gauges) together, then reinspect your work. Hard to tell exactly what you did or did not do.
Old March 16th, 2011, 09:13 PM   #4
wayanlam
wayanlam's Avatar
Motorcycle(s): 2014 Z250
maybe you got the 2 throttle cables back to front, and its holding the carbs totally open? lol... sometimes its some really silly mistakes that just kill the bike.
the bike runs fine without the dash, so its probably something mechanical, with the throttle cables, vacum pipes, or carb assembly. like Blue said, take apart and reassemble, making sure its all hooked up correctly.
Kawasaki Z250, Bored up to 300cc with 12.8 CR, 41hp at wheel 27nm torque, Two bros full exhaust with DB killer
Dynojet Power Commander V, KnN Open filter, intake and exhaust ported, Puig Windshield
wayanlam is offline   Reply With Quote
Old March 23rd, 2011, 07:33 PM   #5
danjaho
danjaho's Avatar
solved it afew days ago, turns out the spring on the throttle was jammed just had to fiddle around with it for a bit hooked it back up worked perfect. no idea how it happened probably when i was putting the two wires back on i got something stuck in it.
Yet another Carb issue Foxrider64 2008 - 2012 Ninja 250R Tech Talk 7 October 2nd, 2013 09:38 AM
Strange Carb issue n4mwd 1986 - 2007 Ninja 250R Tech Talk 42 August 26th, 2013 06:05 AM
Carb issue zach 2008 - 2012 Ninja 250R Tech Talk 4 May 24th, 2013 10:54 AM
carb issue. justin_ninja 1986 - 2007 Ninja 250R Tech Talk 8 January 19th, 2013 07:16 PM
Possible Valve or Carb Issue? schmdty420 1986 - 2007 Ninja 250R Tech Talk 25 June 20th, 2012 09:12 AM
