#1 |
Boy Racer
Join Date: Oct 2013 Motorcycle(s): 08' NINJA 250R, 2013 BMW HP4 Posts: 41
Okay guys I have an issue on my ninja 250r. My tail light works fine, but my Brake light does not work at all for either Front or back brake, I have replaced the bulb, but that does not work, any suggestions?
I have looked at the fuse box and that seems to be in order, I have tried adjusting my rear switch but this is fine as only one filament is lit so its not like the brake is permanently on, I really hope this is not a short in the wiring as that will take forever to find...and Then I need to go buy a multi-meter, also help me ASAP please, this bike is my only transport...I have tomorrow to fix this :/ its my only day off
Ride List: Current: 09' Ninja 250r Previous: 99' ZZR250 |
#2 |
Join Date: May 2013 Motorcycle(s): '75 CB550:.'82 XV920:.'00 KLR650:.'00 EX250:.'08 Ninja 250 Posts: A lot.
MOTM - June '15
check the fuse, actually pull it, replace it.
they can be bad and not look bad. verify voltage at connector for brake circuit. if both switches will not activate it, you most likely have a break in wiring, or a blown fuse
'82 XV920: Soon to be tracker--'00 KLR685:adv --'04 DRZ400E--'12 Super Tenere --'13 Versys Ride more, worry less. |
#3 |
Join Date: Jun 2014 Motorcycle(s): kawasaki ninja Posts: 8
The brake lights will be the two red wires and the tail (running) should be blue along with the black as ground. Check the connection where the 4 wires become 3 at the pigtail connection. Maybe it is loose.
#4 |
Wannabe Reborn
For what it's worth, my 08 had an issue where the brake light would not light from using front or rear brake. I did fuse and bulb replacement, nothing. Ended up having a bad switch on front brake lever ($10 part) and my rear brack switch was out of adjustment.
Wire integrated tail light such that the brake light stays off while signal flashes? | CZroe | 2008 - 2012 Ninja 250R Tech Talk | 6 | March 4th, 2012 06:36 PM |
FS: Original brake light or FDB integrated tail light (current generation) | CZroe | Motorcycle-related | 9 | September 11th, 2011 06:23 PM |
WTB: Rear OEM 2008+ Ninja250 Tail Light/Brake Light | FerociousNINJA | Items Wanted | 5 | March 29th, 2010 08:52 AM |
OEM Tail/Brake Light Comparison to LED Tail/Brake Light | g21-30 | 2008 - 2012 Ninja 250R Farkles | 19 | November 7th, 2009 12:08 PM |
Brake light works but tail light doesn't | DirtyBoy | 2008 - 2012 Ninja 250R Tech Talk | 19 | May 27th, 2009 07:18 PM |
