Old January 12th, 2009, 06:03 PM   #1
SF-Dug
SF-Dug's Avatar
Just got my new fairing to replace the one I broke but...
I notice it did not come with the insulation or foam padding like the original had on it. Does anyone know where I might find similar foam padding and insulation to slap onto the inside of the fairing?
P.S. I just realized that well nuts are important to order before hand. Oh well i discovered a site that sells them relatively cheap and ordered some.
Last futzed with by SF-Dug; January 13th, 2009 at 05:30 PM.
SF-Dug is offline   Reply With Quote
Old January 12th, 2009, 06:22 PM   #2
SF-Dug
SF-Dug's Avatar
Nvm..realized that the small place I ordered the faring from ( Babbittsonline.com) has it for sale as well.
Old January 13th, 2009, 02:19 AM   #3
Ichiro
Motorcycle(s): 2008 250r(sold). 2013 Kymco Super8 150
Why not just peel the insulation off the broken fairing and re-use it? It's kind of glued in, but comes off pretty easily.
Ichiro is offline   Reply With Quote
Old January 13th, 2009, 06:00 AM   #4
KnoxNinja
BRKDWN.
KnoxNinja's Avatar
Motorcycle(s): 89 GPX250R, 89 GPZ500S
If it's a fiberglass replica fairing then I wouldn't even worry about the insulation.
KnoxNinja is offline   Reply With Quote
Old January 13th, 2009, 08:30 AM   #5
M-Oorb
M-Oorb's Avatar
Motorcycle(s): 2008 250r (Fastest Color)
I had the same issue when I replaced my fairing...no insulation and no ninja sticker(lost 10hp ) I just removed the old insulation and used some good high strength glue to put it back on...pretty easy, fast, and cheaper than buying.
M-Oorb is offline   Reply With Quote
Old January 13th, 2009, 08:43 AM   #6
workdaddy
WORKDADDY
workdaddy's Avatar
Motorcycle(s): 2008 ninja 2fitty
Great Link... thanks
workdaddy is offline   Reply With Quote
Old January 13th, 2009, 05:33 PM   #7
SF-Dug
SF-Dug's Avatar
What kind of glue? I don't want to use the wrong type and have it eat up the fairing. Mine is stuck on pretty damn good. Did you use a hairdryer or something to remove it?
Update - The insulation on the right hand side seems to be there to protect the fairing from heat damage from the exhaust but what about the dark grey foam? I managed to remove the shiny insulation but not the foam padding because it's stuck on really well.
Last futzed with by SF-Dug; January 13th, 2009 at 11:00 PM.
Old March 2nd, 2009, 02:03 PM   #8
Buffalony
Buffalony's Avatar
I need this info aswell any help here would be mucho appreciated.
Old March 2nd, 2009, 03:19 PM   #9
OldGuy
Live Life
OldGuy's Avatar
Motorcycle(s): 2009 Green SE Ninja 250
Here is a link for the two pads you talked about(39156A and B) from Cheap Cycle Parts. May be others but here is a start.
- ATGATT -
Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots
OldGuy is offline   Reply With Quote
Old March 2nd, 2009, 03:30 PM   #10
Buffalony
Buffalony's Avatar
I'm sorry. I meant reusing the old ones. And what to use to adhere/install to the new fairings.
Old March 2nd, 2009, 05:13 PM   #11
Sound Wave
Ramen Rider
Sound Wave's Avatar
wow! the full set of fairing pads costs over $90. i would try to re-use it to if possible.
Old March 3rd, 2009, 02:17 PM   #12
Buffalony
Buffalony's Avatar
uh huh. Yeah at first I didnt care I would have to spend the extra 10-12 bucks on a sticker then I noticed that little surprise.
Old March 3rd, 2009, 04:33 PM   #13
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
Joe - Beast makes decals, along with another user on the forum - you could get them there for probably a little less, and if it isn't cheaper you'd at least be supporting a forum member instead of the big corps...
Old March 3rd, 2009, 05:54 PM   #14
Sound Wave
Ramen Rider
Sound Wave's Avatar
thanks for the info! i pm'ed him about possibly making me a "kawasaki" windscreen decal for my zg.
Old March 3rd, 2009, 06:27 PM   #15
noche_caliente
I did the same for mine I want to do it in reflective black though...
Old March 5th, 2009, 03:40 PM   #16
Buffalony
Buffalony's Avatar
I do like this Idea quite a bit. I'll let it simmer awhile. Thanks for the info. : )
Broke Down Takaa 1986 - 2007 Ninja 250R Tech Talk 9 March 25th, 2015 06:19 AM
Replace a Headlight Bulb w/out Fairing Removal? Avaholic88 2008 - 2012 Ninja 250R Tech Talk 12 May 8th, 2014 01:51 AM
How hard is it to replace a fairing? Rys 2008 - 2012 Ninja 250R Tech Talk 5 September 18th, 2011 07:07 PM
I broke it. Hadyn 1986 - 2007 Ninja 250R Tech Talk 31 October 6th, 2010 10:54 AM
[roadracingworld.com] - Thursday Video: It's Not Replace And Ride--It's Replace, Adju Ninjette Newsbot Motorcycling News 0 October 1st, 2009 01:10 PM
