June 20th, 2010, 10:48 PM | #1 |
Join Date: Jun 2009 Motorcycle(s): 09 EX250 LE Posts: 117
Dynojet Stage 2 with Airbox Removed?
Hi all,
So I just pulled my carbs out because I had to drill out a few stripped screws (this is why you don't over tighten) and I thought "this would be a REALLY good time to pull the air box out since the carbs are out" HOWEVER, I hadn't planned on doing this (I only pulled the carbs out because the screws got stripped) and only bought a Dynojet stage 2 kit which, as the box says, is supposed to be used with bikes that have their snorkles removed, and aftermarket exhaust system installed (I have a full yoshi system). The question is.... do I NEED a stage 3 kit or will my stage 2 kit be sufficient? I figure I can just use the largest jet the kit came with and instead of putting the e-clip on the 3rd notch like the instructions say, maybe I'll put it on the 4th or 5th? Whats the worst that could happen if I do this? I'm thinking I'll go ahead with the removal... If things turn out too lean, at least I have a bike to ride while I wait for the stage 3 kit... Plus once the kit comes, It'll be a breeze to remove those bloody carbs again Thanks for reading that gargantuan post. Any advice is appreciated. |
June 20th, 2010, 11:36 PM | #2 |
buy some larger main jets. take a look in the jetting database to see what size dynojet main jets you'll need to order.
w/o the larger jets, you stand a chance of seizing your engine. wouldn't recommend running it w/o the larger jets needed with the airbox removed. the needles are the same in all their kits. |
June 20th, 2010, 11:55 PM | #3 |
Hmm... wouldn't want a seized engine.
I can't seem to find a vendor that sells the jets by themselves..... althought I've only been searching for 15 mins *edit* Actually... Dynojet doesn't seem to sell at stage 3 kit for the 08-09 ninja 250r. Should I use a jets/kit made for the pregen? |
June 21st, 2010, 12:05 AM | #4 |
June 21st, 2010, 11:13 AM | #5 |
My local motorcycle shops have Keihin jets in larger sizes.... Not sure what the difference is between that and the Dynojet ones besides the sizing chart numbers. Should I just go with Keihin jets or are Dynojets somehow better?
Also, I don't need to touch the pilot jets right? Just the main jets? |
June 21st, 2010, 11:31 AM | #6 |
yes, just use the conversion chart and order the equivalent Keihin main jets. They will work. Just make sure they are the correct small round type and not the larger hex ones... there are 2 types of Keihin main jets that I am familiar with. I would recommend you order a set of (2 each) 112 and 110 Keihins.
Correct, no need to change out the pilot jets if what you have already works well. |
Dynojet stage 3 needle | joeybaila | Items Wanted | 0 | January 24th, 2015 04:47 PM |
DynoJet Stage 2 | THE BIG SITT | Motorcycle-related | 4 | October 10th, 2011 07:54 PM |
DynoJet Stage 2 Kit | lonewolf05 | Motorcycle-related | 0 | June 30th, 2011 05:06 PM |
Has anyone removed the airbox and kept the stock exhaust? | JMcDonald | 2008 - 2012 Ninja 250R Tech Talk | 19 | December 23rd, 2010 12:55 PM |
Stage-2 Dynojet Sale $67.99 | g21-30 | Motorcycle-related | 3 | May 3rd, 2009 07:45 AM |
