Old February 20th, 2014, 10:57 PM   #1
Josh_kcco
Josh_kcco's Avatar
Motorcycle(s): '04 Ninja 250R
diodes..
is there a no cut diode for the pregen bikes or do i have to do it the ol fashion way?
any one have any other ideas on how to fix all for led turn signals flashing at same time. there then whats stated in this page..
http://faq.ninja250.org/wiki/My_LED_...27t_work_right
Josh_kcco is offline   Reply With Quote
Old March 23rd, 2014, 03:30 PM   #2
Did you ever figure this out?
Old March 23rd, 2014, 03:56 PM   #3
Jammerkiller
lurking about........
Jammerkiller's Avatar
Motorcycle(s): 2004/2005 Ninja EX250, VFR750, Shadow ACE750, NC700X
Hi Josh,
The "diode method" looks like it's a good bet. Not difficult to do. It's very similar to what I did on my VFR to add hazard lights to it. Two diodes joined together to let voltage go through both in one direction, but stop at one diode only with voltage going the opposite direction.
Just like the pic in that post, you have to create a new ground to one side of the turn signal indicator, and the other goes to the 2 diodes. That will eliminate the "all 4 lights" going on at once and just isolate the requested circuit that you are calling for. (left or right) You could use 1N4004 diodes as an alternative, they just have a higher voltage limit than the 1N4001 diodes.
Fast....Cheap.....Reliable...... You can only pick two.
Jammerkiller is offline   Reply With Quote
Old March 23rd, 2014, 04:25 PM   #4
fast1075
Motorcycle(s): 2006 Ninja 250, 2004 Buell XB12s, Honda 110 Elite
Josh, I did mine following the article you linked. Only took 1/2 hour. If you don't have any heat shrink tubing. You can get a box of it at Harbor Freight for just a few bucks. Get the "marine' type, it has sealant inside to keep moisture out.
That will fix the "all four lights at once problem" Then you have to deal with the flash cycle rate problem. When I did mine, I added sockets to my tail light and used standard bulbs in the rear. Resistors work, but if you forget to turn the signals off, they get very hot quickly. You can get a useable flasher at Cycle Gear if you have one nearby.
"They don't pay me enough to ride this thing!" Kenny Roberts after winning the Indy Mile on the TZ750 powered Grand National bike.
fast1075 is offline   Reply With Quote
Old March 24th, 2014, 11:06 AM   #5
Josh_kcco
Josh_kcco's Avatar
hey guys. yea I actually did what was in the article. I figured to do it the right way then to be lazy. I didn't/don't have any heat shrink so for now I just used electrical tape. been on for about 2 weeks now or so and has failed yet. I have all four turn signals LED lights so I used an electronic relay to fix the rapid flash. the only draw back from that is that it makes a loud BEEP noise. sounds like a truck backing up lol
but all in all it was easier then I thought it was. =]
Old March 24th, 2014, 04:21 PM   #6
Jammerkiller
Awesome! Glad it worked for you.
