September 7th, 2009, 09:48 AM | #1 |
Join Date: Apr 2009 Motorcycle(s): 07 ninja 250 Posts: 20
having alot of problems :(
the other day i got on my bike and it would only run with full choke if i moved the choke lever it would die almost instantly. Today i tried starting it and it wont start unless its on full choke. it instantly goes to 5k rpms and if i give it throttle it dies. sometimes it will start without choke but if it does it will fail to idle and just die after a few mins unless i am constantly feathering the throttle. When it dies also i notice there is a weird sound like air being released from the front end if that makes any sense. so as of now i cant ride it i dont know whats going on. I didnt ride it for 11 days before this because i went out of state. But yea any help is appreciated.
September 7th, 2009, 09:54 AM | #2 |
how long was it between the time the engine was actually started between your trip out of state? was it 11 days between the times you started the bike or was your trip 11 days?
sounds like your pilot jets are clogged. flush your gas, refill with fresh gas and try adding some seafoam to the tank. |
September 7th, 2009, 09:56 AM | #3 |
yea i was out of state for 11 days and it wasnt started at all. Ill try that where can i get seafoam auto parts store?
September 7th, 2009, 10:00 AM | #4 |
yes, most autoparts stores have Seafoam. call them first, though. I've also seen it at Walmart recently.
could you have gotten a bad batch of gas? |
September 7th, 2009, 10:03 AM | #5 |
alrite ill check it out kkim thanks and i dont know my bro in law thinks its either bad gas or water in the fuel
September 7th, 2009, 11:04 AM | #6 |
well its started raining, and unfortunately dont have a garage so gonna hold off til it stops raining which will hopefully be soon. weather isnt looking good all week
September 10th, 2009, 06:40 PM | #7 |
Join Date: Nov 2008 Motorcycle(s): 2007 Ninja 250 Posts: 469
KKim is right...get 'yer SeaFoam in there.
That's step one. Then come back and report.
"This is my Ninja. There are many like it, but this one is mine..." ~ Purspeed (ca. Nov, 2008) |
September 10th, 2009, 06:57 PM | #8 |
started it up today and it ran fine no problems at all
September 10th, 2009, 07:12 PM | #9 |
Preventative action that was your warning put some cleaner in there
-Dave |
September 12th, 2009, 10:57 AM | #10 |
self wrencher
Instead of 2 zipties and messy superglue, you can use 3M double layered sticky tape and put it under the zip-tie. It'll adheres to the throttle tube (thus no glue). Apply the second layer of tape to the middle portion of the zip-tie instead of the entire length like the first layer creating the tappering effects.
riding to work alot lately....question | max-r95 | General Motorcycling Discussion | 19 | July 1st, 2012 07:46 PM |
So, I haven't posted alot here, but thought I'd share. | Strange | The Ex-Ninjetters Lair | 24 | April 11th, 2012 01:35 PM |
FS: 2011 SE pearl/ebony 250r .. Delaware .. alot of aftermarket! | greatwhiteninja | Motorcycle-related | 11 | September 30th, 2011 07:20 AM |
Started My Mods.. Alot More to come.. | Tims250R | 2008 - 2012 Ninja 250R Farkles | 44 | June 4th, 2009 02:27 PM |
