Old September 1st, 2014, 02:24 PM   #1
WiffleBiscuit
Motorcycle(s): 2010 Ninja 250r, 2000 Honda CBR600F4
Throttle sticking, need help
Hello everyone, hoping I can get some insight from someone more knowledgeable than me. Just installed a full exhaust, k&n filter and removed snorkel. Rejetted the carb with dynopro 98 main jet and dynopro needles and spacers. The problem is that the throttle is sticking badly now. I have tried every idle adjustment from 2 turns to 4 turns, adjusted the throttle cables at both the carb and the grip multiple times, and made sure that the cables aren't getting hung anywhere. I have read a few places that a lean mixture will cause the throttle to stick, but I wouldn't expect that it would stick this badly. It takes about 4 seconds for the bike's rpm to drop from 5k to idle when reving in neutral. Any ideas from anyone that has gone through a similar issue? I appreciate any help, thanks.
WiffleBiscuit is offline   Reply With Quote
Old September 1st, 2014, 02:41 PM   #2
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
Cable sticking? Not hung up but no lube in tube!
Old September 1st, 2014, 03:16 PM   #3
WiffleBiscuit
I have lubed the cables and the throttle bracket on the carb returns to the neutral position when I let the throttle grip go, but the revs still fall very slowly. Is it possible that some part of the carb is failing to shut off after throttle? I'm not very familiar with the linkage of the carbs, could it be something with that?
Old September 1st, 2014, 03:59 PM   #4
Ninjinsky
Ninjinsky's Avatar
Its probably not the throttle sticking, its an air leak somewhere.
Loosen and resettle the rubber manifolds and also check all the vac hoses on the carbs.
Old September 1st, 2014, 05:11 PM   #5
WiffleBiscuit
Ok, I will reset all of the hoses and see if that remedies the problem.
Carb sticking 102dalz 2008 - 2012 Ninja 250R Tech Talk 3 November 2nd, 2014 02:37 PM
Front Brake is sticking...Help! skilletmo 2008 - 2012 Ninja 250R Tech Talk 19 October 25th, 2014 05:30 PM
Tank Pad Not sticking! Klondike1020 2013 - 2017 Ninja 300 Farkles 7 April 6th, 2014 10:24 AM
[crash.net - MotoGP] - Sticking throttle spoils Reddingâ??s debut Ninjette Newsbot Motorcycling News 0 March 20th, 2014 04:00 PM
2010 throttle sticking? wtfh4xx 2008 - 2012 Ninja 250R Tech Talk 5 June 1st, 2011 01:14 PM
