Old November 21st, 2017, 11:51 AM   #1
Dustin5611
Motorcycle(s): 2012 Ninja 250
Fuel
Okay so it's something that I have been wandering for a while because I know that ethanol eats away at the carb how bad of an idea would it be to run 93 octane in a 250cc engine
2012 Ninja 250r
Dustin5611 is offline   Reply With Quote
Old November 21st, 2017, 11:55 AM   #2
It wouldn't make any difference, other than running slightly richer if it's non-ethanol gasoline.
Old November 21st, 2017, 12:41 PM   #3
You may actually lose power if running higher-than-designed octane fuel. This has been dyno-proven endlessly. You'll want to run lowest octane possible that doesn't cause knocking/pinging. These newgen bikes actually has lower-compression than previous pregen engines, and those run just fine on 87-octane.
Old November 21st, 2017, 12:55 PM   #4
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
What makes you think 93 octane has less ethanol in it?
(This may vary by location IIRC... here in Connecticut everything except race gas has ethanol.)
Old November 21st, 2017, 01:04 PM   #5
Not according to this comparison: https://www.superstreetbike.com/more...busters#page-2
Of course dynamometers can be made to prove about anything the operator wants to prove.
Old November 21st, 2017, 01:31 PM   #6
Yeah, on EFI engine, it's all a wash unless you re-program ignition-map with more advance to take advantage of higher-octane fuel. Which precludes going back to lower-octane without re-programming again.
I think dyno-comparisons I'm thinking of is +10yrs old on carb engines. NA engines make max-power around 13.5:1, richer or leaner on either side tends to drop power. The difference in AFR with running richer would account for loss of power. The primary octane-boosting hydrocarbon in higher-octane fuels is toluene which has higher specific-gravity than 87-octane gasoline mix, which causes richer mixtures.
If Dustin is worried about ill-effects on carbs, he should be looking more at RVP-Reid Vapour Pressure rather than Octane properties of gasoline. The winter-blends of gas tend to have higher RVP for easier evaporation and lower emissions. This causes gasoline sitting around to dry out faster and clog carbs easier during winter storage. Using some additives like Stabil-360 is a simple fix.
Old November 21st, 2017, 01:51 PM   #7
It can be toluene, xylene, benzene, and others, in any combination they feel like using at the time.
Old November 21st, 2017, 02:09 PM   #8
Kinda like floor-sweepings and leftovers? FDA allows up to 2% rat-droppings (and rats) in hot-dogs. So I guess EPA is just as corrupt as FDA.
Old November 21st, 2017, 02:32 PM   #9
taz
taz's Avatar
MOTM - May '17
Originally Posted by jacryann View Post
kinda like floor-sweepings and leftovers? Fda allows up to 2% rat-droppings (and rats) in hot-dogs. So i guess epa is just as corrupt as fda.
yup, its all about the all mighty dollar
Old November 21st, 2017, 03:03 PM   #10
I'll have to ask a friend of mine about it next spring at the 2-stroke meet. He works at a refinery in Louisiana, and is up on all the refining and distilling and blending of stuff.
Old November 21st, 2017, 06:32 PM   #11
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Motorcycle(s): '09 250 SE 'Booger'
Here in Iowa I can get ethanol free 87 and 91. It varies from station to station a bit.
Dave Wolfe is offline   Reply With Quote
Old November 21st, 2017, 11:43 PM   #12
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
try stabil 360
"trying not to get old"
Old November 22nd, 2017, 04:04 AM   #13
Ram Jet
Ram Jet's Avatar
Yeah, take denatured alcohol for example. It's basically ethanol (booze) mixed with methanol (wood alcohol). Why is it mixed with methanol? So you can't go to Home Depot and buy it to make drinks. Why, because our legislators would rather blind us, put us in a coma or kill us rather than lose a single penny in liquor taxes.
Bill
Old November 22nd, 2017, 08:17 AM   #14
I would say use the lowest octane you can get that doesn't contain ethanol.
Or you could try the Stabil additive designed to neutralize the effects of ethanol.
87 without ethanol will give you the best performance and economy in a stock Ninja 250 if you can get it.
I believe having excessive octane can lead to incomplete combustion and additional carbon build-up in the combustion chamber. It can also lead to hard starting in some engines.
In a carbed engine, gas with ethanol will produce a leaner mixture than gas without, so running ethanol-free gas can make a carbed engine run better (richer) if it hasn't been tuned.
Old November 22nd, 2017, 09:14 AM   #15
Ram Jet
Ram Jet's Avatar
There are other benefits to using a premium grade gasoline in your engine;
- Fuel detergents will protect against intake valve deposits
- Anti adhesion compounds prevent fuel detergents from forming a sticky
film on intake valves
- corrosion inhibitor helps prevent rust in the fuel system
- demulsifier helps prevent water from accumulating in your gas tank
allowing it to be separated and removed
I believe less expensive gasoline may not contain these added benefits.
Bill
Old November 22nd, 2017, 09:23 AM   #16
I may be wrong, but I think you're referring to so called "top tier" gasoline brands, as opposed to "premium" that means high octane. For example, all Chevron gasoline contains Techron, regardless of whether it's regular or premium.
Old November 22nd, 2017, 10:22 AM   #17
Ram Jet
Ram Jet's Avatar
Correct. Top Tier fuel is supported by BMW, GM, Honda, Toyota, VW and Audi. Which makes it good enough for my Ninja.
I didn't know Chevron gasoline contained Techron. Makes sense since Chevron manufactures Techron. I use it in my auto 2X/year and a few ounces my bike 1X/year. A friend of mine swears by the stuff.
Bill
Old November 22nd, 2017, 10:31 AM   #18
I know additives are not a cure-all, or even a cure-very-many, but last year my chainsaw was showing signs of a dirty carb. It was hard to start, and I had to keep adjusting the mixture screws. When I got it out this year to cut some firewood, it was getting worse. I got a bottle of Techron and added a little to the fuel, ran the saw long enough to get the stuff into the carburetor, and let it sit overnight. The next day it started easily, and I had to close the mixture screws way down to their original settings. I used it to cut about six cords of wood and it ran flawlessly the whole time.
I absolutely don't expect it to work that way on every dirty carburetor, but that bottle was worth the price for the time and effort it saved me on that one job.
Old November 22nd, 2017, 10:46 AM   #19
Ram Jet
Ram Jet's Avatar
Thanks for that feedback T.J. I use it because of the respect I have for the person who recommended it to me. You've added real-life experience.
Cheers,
Bill
Old November 22nd, 2017, 11:14 AM   #20
Adding Techron (active ingredients PEA) increases detergent cleaning ability significantly more than what’s in Chevron gas. So if you’re going to be adding it, really doesn’t matter what gas you get. Other cleaner that has high dose of PEA is Redline SI-1.
Old November 22nd, 2017, 12:35 PM   #21
Bill
As TJ noted - it's more of a "Top Tier" thing. The local "Top Tier" station says on the pump that it has maximum detergents in all grades, but some oil companies will try to sell you on their Premium gas even if you don't need it.
You are way ahead running a tank full of a strong fuel system cleaner (like Chevron Techron Concentrate - 1oz per gal) once every season than buying Premium gas thinking it's keeping the engine cleaner.
Old November 22nd, 2017, 10:29 PM   #22
Ram Jet
Ram Jet's Avatar
I can't worry about what I pay per gallon for fuel for a motorcycle that "sips" it's drink anymore that I lose sleep over what to do with 1/2 a can of brake fluid. Hell, I paid over $400.00 for my Yoshimura mufflers do you think I give a zit about a few gallons of gasoline? I will say that I have experienced greater gas mileage with premium fuel though.
"Run watcha brung."
Bill
Old November 23rd, 2017, 07:11 AM   #23
"Run watcha brung."
Bill
Only the high-ticket fluids and parts for your Ninja, but you said you can't consider a $40 balaclava to keep your head warm, instead going for the $3.29 or $5.39 model. You owe yourself better than that!
Old November 23rd, 2017, 09:08 AM   #24
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Has anyone ever done an experiment with this? not the official studies, but their own 8th grade science experiment, where you have some fun.
TEAM ALFALFA
www.apexassassins.com
Old November 23rd, 2017, 09:47 AM   #25
"Run watcha brung."
Bill
That wasn't my point.
I could care less about cost of fuel for the cycles as well, but running Premium (if it's not necessary) is giving you less performance and economy - even if the cost was the same as Regular.
Old November 23rd, 2017, 10:19 AM   #26
Ram Jet
Ram Jet's Avatar
Not for the two or three times a year I ride when it's 30-40 degrees out. What I owe myself is a set of Mikuni carbs off a Yamaha RD350/400.
Bill
Old November 23rd, 2017, 10:44 AM   #27
Ram Jet
Ram Jet's Avatar
I hear you. I'm more concerned that I run Tier One fuel than how quickly I can pick-up a loaf of bread. You racer cats have a whole different agenda than I.
Bill
Old November 24th, 2017, 08:01 AM   #28
RcTechnologies
Motorcycle(s): '12 EX250JC
RcTechnologies is offline   Reply With Quote
Old November 24th, 2017, 08:06 AM   #29
RcTechnologies
Ram Jet
...rather blind us and put us in a coma than miss out on a few dollars in taxes...
[American Motorcyclist Association] - Vetter Fuel Economy Challenge tests fuel mileag Ninjette Newsbot Motorcycling News 0 July 13th, 2014 10:40 AM
My video on how to fix the fuel sender for your fuel gauge Klint 2008 - 2012 Ninja 250R Tech Talk 1 November 2nd, 2013 09:04 PM
[RoadRUNNER] - Bazzaz Z-Fi Fuel Control Unit and Air Fuel Mapping Kit Ninjette Newsbot Motorcycling News 0 June 3rd, 2013 11:10 AM
[sportrider - latest stories] - Chicken Hawk Racing Cool Fuel Aluminized Fuel Can Cov Ninjette Newsbot Motorcycling News 0 May 3rd, 2011 11:50 AM
