January 16th, 2013, 07:39 AM | #1 |
Join Date: Jun 2010 Motorcycle(s): 2008 Kawasaki Ninja 250R-J, 2005 Honda Superhawk VTR1000 Posts: 95
Yoshimura rearsets with braided brake lines?
Got an '08 with braided brake lines (I strongly recommend this mod btw). I find I need some rearsets for clearance in cornering as I'm hitting the footpegs pretty often when riding in a "spirited" fashion (my '05 VTR1000 Superhawk might be a culprit as my other bike [for sale btw]).
So, the instructions on a Yoshi rearset says you have to cut the rear brake line to get it to fit so it doesn't kink. What is the recommended procedure for braided brake lines? |
January 16th, 2013, 08:04 AM | #2 |
Join Date: Dec 2008 Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike Posts: 890
My guess is the cut they are talking about is to the hose for the reservoir.
January 16th, 2013, 08:05 AM | #3 |
Fast-Guy wannabe
MOTM - Jan '13
Cut?
Your description of yoshimura instructions leave me a bit You can't just cut and shorten or adjust brake lines without special tools and fittings. Although if you have Spiegler lines then those are made to be rotated with an included tool to prevent line twists. If your just putting on rearsets and keeping the brake components the same then you shouldn't need to do anything to the line. |
January 16th, 2013, 08:08 AM | #4 | |
Fast-Guy wannabe
MOTM - Jan '13
Because your master cylinder is being raised up toward your reservoir you need to cut the amount your raising it from the line between the reservoir and master cylinder so it doesn't have to kink. Ill snap a pic of mine. |
January 16th, 2013, 08:16 AM | #5 |
The hose with the large silver clamp on it.
This picture is how my reservoir hose was setup when I had rearset adjusters installed. I ended up just making a simple aluminum bracket to move the reservoir back. |
January 16th, 2013, 08:25 AM | #6 |
Fast-Guy wannabe
MOTM - Jan '13
Just remembered I didn't ride my bike today so here's an old pic I found. Zoom it above the left foot peg and look at the right side of the bike. Right I front of my exhaust hanger is the hose we're talking about. It's like 5/8" thick with a slight s curve to it. The pic shows mine after I cut it.
January 16th, 2013, 04:14 PM | #7 |
Ah yes, the reservior. Thanks guys!
Stainless steel braided brake lines install | Bob2010 | 2008 - 2012 Ninja 250R Tech Talk | 8 | June 11th, 2016 07:01 AM |
question about steel braided brake lines | adouglas | General Motorcycling Discussion | 8 | March 31st, 2015 08:53 AM |
FS Pre gen braided brake lines and steering nut | Mark Cook | Motorcycle-related | 7 | May 9th, 2014 04:56 PM |
steel braided brake lines | james250ninja | 1986 - 2007 Ninja 250R Tech Talk | 4 | October 10th, 2013 07:07 AM |
[roadracingworld.com] - Video: Installing Braided Stainless Steel Brake Lines On The | Ninjette Newsbot | Motorcycling News | 0 | November 15th, 2010 12:40 PM |
